Automatically start print
I have tried a couple of methods to automatically start a print job without any success.
1. auto0.g
2. in the startup_gcode in the firmware - M23 filename.gco M24
Method 2 does load the file however does not start the print. If i type in M24 from Repetier host the print starts.
I have a X,Y only corexy mechanism that needs to run the same gcode every day when the machine is started.
MArlin has this feature using the auto0.g however as i'm running a due board and radds i'd like to stick with Repetier.
Would any one be able to point me in the right direction to accomplish this please.
