Expected bed temperature not reached
I have a problem with Repetier 1.0.6 (Linux version). When I start a 3D printing, the bed temperature is rising. But it does not reach the minimal temperature expected. Find below the logs. The sequence is :
- starting Repetier Host
- loading a STL file
- reseting the extrudeur by clicking on "home"
- slicing the object
- starting the job
I removed in the logs OpenGL Extensions.
09:06:46.662 : OpenGL version:3.0 Mesa 10.1.3
09:06:46.666 : OpenGL extensions:GL_ARB_multisample
09:06:46.667 : OpenGL renderer:Mesa DRI Intel(R) Ivybridge Desktop
09:06:46.667 : Using fast VBOs for rendering is possible
09:06:54.334 : start
09:06:54.335 : echo: External Reset
09:06:54.335 : Marlin 1.0.0
09:06:54.335 : echo: Last Updated: Nov 18 2014 14:25:15 | Author: (Adaptations pour Tobeca - Adrien Grelet - Tobeca SARL)
09:06:54.335 : Compiled: Nov 18 2014
09:06:54.335 : echo: Free Memory: 5022  PlannerBufferBytes: 1488
09:06:54.335 : echo:Hardcoded Default Settings Loaded
09:06:54.335 : echo:Steps per unit:
09:06:54.335 : echo:  M92 X66.84 Y66.84 Z4000.00 E152.00
09:06:54.335 : echo:Maximum feedrates (mm/s):
09:06:54.335 : echo:  M203 X500.00 Y500.00 Z3.00 E60.00
09:06:54.335 : echo:Maximum Acceleration (mm/s2):
09:06:54.335 : echo:  M201 X5000 Y5000 Z100 E12000
09:06:54.335 : echo:Acceleration: S=acceleration, T=retract acceleration
09:06:54.335 : echo:  M204 S2000.00 T4000.00
09:06:54.335 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s),  Z=maximum Z jerk (mm/s),  E=maximum E jerk (mm/s)
09:06:54.335 : echo:  M205 S0.00 T0.00 B20000 X15.00 Z0.40 E5.00
09:06:54.335 : echo:Home offset (mm):
09:06:54.335 : echo:  M206 X0.00 Y0.00 Z0.00
09:06:54.335 : echo:PID settings:
09:06:54.335 : echo:   M301 P37.77 I3.58 D99.63
09:06:54.778 : N1 M110 *2
09:06:54.778 : N2 M115 *4
09:06:54.778 : N3 M111 S6 *68
09:06:54.785 : N4 T0 *30
09:06:54.785 : N5 M20 *52
09:06:54.786 : N6 M80 *61
09:06:54.786 : N7 M105 *0
09:06:54.806 : N8 M220 S100 *73
09:06:54.806 : N9 M221 S100 *73
09:06:54.807 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/pyroboynroses/Tobeca/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Tobeca EXTRUDER_COUNT:1
09:06:54.807 : N10 M111 S6 *118
09:06:54.809 : echo:Active Extruder: 0
09:06:54.809 : N11 T0 *42
09:06:54.824 : echo:Active Extruder: 0
09:06:57.867 : N12 M105 *52
09:07:00.967 : N13 M105 *53
09:07:04.067 : N14 M105 *50
09:07:07.068 : N15 M105 *51
09:07:09.508 : Starting object analyser ...
09:07:09.531 : Object is manifold.
09:07:09.533 : Analysing finished.
09:07:10.074 : N16 M105 *48
09:07:13.174 : N17 M105 *49
09:07:16.275 : N18 M105 *62
09:07:18.285 : N19 G28 *11
09:07:19.276 : N20 M105 *53
09:07:22.376 : N21 M105 *52
09:07:25.475 : N22 M105 *55
09:07:27.586 : CuraEngine command:/home/eric/dev/tobeca/RepetierHost/plugins/CuraEngine/CuraEngine -p -v -c "/home/eric/.local/share/RepetierHost/cura.ini" -s posx=0 -s posy=0 -o "/home/eric/.local/share/RepetierHost/composition.gcode" "/home/eric/.local/share/RepetierHost/composition0.stl"
09:07:27.653 : <CuraEngine> Cura_SteamEngine version 14.09
09:07:27.653 : <CuraEngine> Copyright (C) 2014 David Braam
09:07:27.653 : <CuraEngine> This program is free software: you can redistribute it and/or modify
09:07:27.653 : <CuraEngine> it under the terms of the GNU Affero General Public License as published by
09:07:27.653 : <CuraEngine> the Free Software Foundation, either version 3 of the License, or
09:07:27.653 : <CuraEngine> (at your option) any later version.
09:07:27.653 : <CuraEngine> This program is distributed in the hope that it will be useful,
09:07:27.653 : <CuraEngine> but WITHOUT ANY WARRANTY; without even the implied warranty of
09:07:27.653 : <CuraEngine> MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
09:07:27.653 : <CuraEngine> GNU Affero General Public License for more details.
09:07:27.653 : <CuraEngine> You should have received a copy of the GNU Affero General Public License
09:07:27.653 : <CuraEngine> along with this program.  If not, see <http://www.gnu.org/licenses/>.
09:07:27.653 : <CuraEngine> Default config 'default.cfg' not used
09:07:27.661 : <CuraEngine> Loading /home/eric/.local/share/RepetierHost/composition0.stl from disk...
09:07:27.662 : <CuraEngine> Loaded from disk in 0.001s
09:07:27.662 : <CuraEngine> Analyzing and optimizing model...
09:07:27.675 : <CuraEngine>   Face counts: 9220 -> 8677 94.1%
09:07:27.675 : <CuraEngine>   Vertex counts: 27660 -> 4337 15.7%
09:07:27.675 : <CuraEngine>   Size: 16.599000 16.255000 19.998000
09:07:27.675 : <CuraEngine>   vMin: 91.700000 91.872000 0.000000
09:07:27.675 : <CuraEngine>   vMax: 108.299000 108.127000 19.998000
09:07:27.676 : <CuraEngine>   vMax: 108.299000 108.127000 19.998000
09:07:27.676 : <CuraEngine>   Matrix: 1.000000 0.000000 0.000000
09:07:27.676 : <CuraEngine>   Matrix: 0.000000 1.000000 0.000000
09:07:27.676 : <CuraEngine>   Matrix: 0.000000 0.000000 1.000000
09:07:27.676 : <CuraEngine> Optimize model 0.013s
09:07:27.676 : <CuraEngine> Slicing model...
09:07:27.676 : <CuraEngine> Layer count: 99
09:07:27.743 : <CuraEngine> Sliced model in 0.067s
09:07:27.743 : <CuraEngine> Generating support map...
09:07:27.743 : <CuraEngine> Generating layer parts...
09:07:27.751 : <CuraEngine> Generated layer parts in 0.008s
09:07:27.838 : <CuraEngine> Generated inset in 0.087s
09:07:27.943 : <CuraEngine> Generated up/down skin in 0.105s
09:07:28.101 : <CuraEngine> Wrote layers in  0.16s.
09:07:28.101 : <CuraEngine> Wrote 1005.1 kilobytes.
09:07:28.101 : <CuraEngine> Total time elapsed  0.44s.
09:07:28.101 : <CuraEngine> Print time: 847
09:07:28.101 : <CuraEngine> Filament: 606
09:07:28.101 : <CuraEngine> Filament2: 0
09:07:28.482 : N23 M105 *54
09:07:31.487 : N24 M105 *49
09:07:34.587 : N25 M105 *48
09:07:37.687 : N26 M105 *51
09:07:40.787 : N27 M105 *50
09:07:43.887 : N28 M105 *61
09:07:46.888 : N29 M105 *60
09:07:49.988 : N30 M105 *52
09:07:53.088 : N31 M105 *53
09:07:56.188 : N32 M105 *54
09:07:59.288 : N33 M105 *55
09:08:02.289 : N34 M105 *48
09:08:05.389 : N35 M105 *49
09:08:08.489 : N36 M105 *50
09:08:11.589 : N37 M105 *51
09:08:14.689 : N38 M105 *60
09:08:17.690 : N39 M105 *61
09:08:20.790 : N40 M105 *51
09:08:22.896 : N41 M117 ETE 00s *22
09:08:22.942 : N42 G28 *5
09:08:22.942 : N43 G1 Z15 F100 *22
09:08:22.943 : N44 M107 *53
09:08:22.943 : N45 G90 *1
09:08:22.943 : N46 M82 *11
09:08:22.944 : N47 M190 S40 *79
09:08:22.945 : N48 M104 T0 S200 *63
09:08:23.799 : N49 M105 *58
09:08:24.212 : N50 G92 E0 *82
09:08:24.212 : N51 M109 T0 S200 *58
09:08:24.216 : N52 M107 *50
09:08:26.899 : N53 M105 *49
  • The host has send
    N47 M190 S40 *79
    meaning set bed to 40°C. If it does not reach the temperature it is a firmware/hardware problem nit a host problem. Host just sends the commands.
