Repetier Server and Mixing extruder
Im currently running 2 3d Printers with repetier server. Until now everything worked fine. But now i m currently in the process of building a 3 rd . 3d printer with an mixing extruder. And i wasnt able to find the ability of repetier server to controll a mixing extruder. +
Are there any possibilities to use a mixing extruder with repetier host.
  • No special settings required for mixing extruder at least the way they are implemented in repetier-firmware. There you have virtual extruders instead with set mixing ratios. So you would simply set 16 extruders with same diameter.
  • Thank you for your reply... repetier server with the pro licence key is almost perfect for my needs
