How to make drawing, cnc & laser gcode?
Hi repetier,
How to make drawing, cnc & laser gcode with repetier host?
Thx
Kusuma
  • You can't. For laser we have a inkscape plugin that would do that. For cnc you need a cam solution that allows twisting generated gcode as needed and you then only send the gcode with host/server.
  • I wonder how to do this
  • I think it is doable with a inkscape plugin as well. You need to add z hop between strokes here except that it is similar. Problem is to get the strokes for infill if they are solid. The repetier plugin converts lines in moves with laser on and that can be done similar.
