Prusa i3, Z probe, repetier firmware and problems...
Hi all,
I have a prusa i3, with an inductive probe on Z.
With the Marlin firmware, the probe is also used as the Z endstop, and it works well.
As I modified the printer with a dual extruder, I wanted to switch with Repetier firmware (known to handle multiple extruders) , but I can't get the Z probe to work as an endstop.
I have been trying for two days to configure Repetier, but nothing works.
Has anyone got an idea?
  • You need to set z min endstop = z probe to get that. Homing order must by XY first! If endstop at home dposition does not work (no bed ) you need to use the version setting temperature. There you can also set probing position and simply set temperature to 0.
  • edited December 2016
    Thank you for your answer.
    I already defined as your recommended, now the probe works as an endstop
    the probe is connected on the pin 12 so I modified this line:
    #define ORIG_Z_MIN_PIN          12
    but my problem was that pin 12 was already used with  #define ORIG_PS_ON_PIN     so I set it to -1 and it solved the Z endstop problem.
    Because of ORIG_PS_ON_PIN 12 , the probe stopped working when I connected repetier host on USB
    Now I try to activate the autolevel feature so it can also work with the endstop
  • I am completely lost about the z leveling.
    Seems the probe interferes between the fact it is used as endstop and as bed detection...
    The probe is about 1 mm up the nozzle.
    When I home z, the nozzle nearly touch the bed
    When I launch a print task, after auto leveling, the nozzle start to print 3 or 4 mm away of the bed.
    I am missing something, but I can't tell what.
    Here's a copy of my configuration.h
    If someone can have a look at it it would be nice.
    #define NUM_EXTRUDER 2
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define FAN_THERMO_PIN -1
    #undef Z_MIN_PIN
    #define Z_MIN_PIN 12
    //#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define BLUETOOTH_BAUD  115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 160
    #define ZAXIS_STEPS_PER_MM 1600
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define DECOUPLING_TEST_MAX_HOLD_VARIANCE 30
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define SHARED_EXTRUDER_HEATER 1
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 85
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_MAX_ACCELERATION 2000
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define EXT1_X_OFFSET 0
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 85
    #define EXT1_TEMPSENSOR_TYPE 1
    #define EXT1_TEMPSENSOR_PIN TEMP_0_PIN
    #define EXT1_HEATER_PIN HEATER_0_PIN
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_MAX_ACCELERATION 2000
    #define EXT1_HEAT_MANAGER 3
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_Z_ADD  2
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    #define MIN_DEFECT_TEMPERATURE 5
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define Z_PROBE_BED_DISTANCE 1
    #define Z_PROBE_PIN 12
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 0
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 40
    #define Z_PROBE_Y1 40
    #define Z_PROBE_X2 140
    #define Z_PROBE_Y2 40
    #define Z_PROBE_X3 40
    #define Z_PROBE_Y3 140
    #define BED_LEVELING_METHOD 1
    #define BED_LEVELING_GRID_SIZE 3
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 2
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 0
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 1
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_ANIMATION 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
  • #define Z_PROBE_HEIGHT 0
    is wrong. You need to set this to the distance of the nozzle to bed when the probe triggers. This is also in eeprom so changing it there is enough.
    Since it triggers before touching you need to disable ALWAYS_CHECK_ENDSTOPS as well or it will prevent z move down.
    Last is you need to start at a height where probe is not triggered. I think I need to add a test here that it moves up if probe is triggered before going down.
  • Thanks a lot for the precision.
    I just had the time to change the parameters and I saw the nozzle had already a better position.
    Didn't have the time to launch a test print, but I ll tell you when I will.
  • So I tried to launch a print test, leaving the probe untriggered as you said, but I am getting an error at the moment the automatic bed level gets its first point.
    For information, my homing is good with the value Z-probe height = 0.950
  • You know G29 does not autolevel bed but only measure z height using an average?
    Short time ago someone had the same error. Reason was that M119 shows a "h" for z max preventing it from succeeding.
  • I think  I solved my problem.
    I added  the command G1 Z20 in the custom start GCODE of Silc3r and it made it!
  • Hi,
    As I still have little problems, I'll continue with this thread.
    I tried to configure the probe/nozzle offset, as the probe is 30mm away from the nozzle on the X and 7mm on the Y
    So I defined the values Z_PROBE_X_OFFSET=30 and Z_PROBE_Y_OFFSET=-7 directly in the eeprom menu from repetier host, but when I modify the values, when starting a print and the printer starts, the X homing violently hits the endstop several times and I hear the motor cracking.
    I tried several values for X offset, same problem, except when set to 0.
    I used this to find the value (my probe on the same X side, but negative for Y)
  • What version are you using?
    If you start at x home and enable z probe it will move 30mm left so it might crash into endstop. In dev it should not do that but position might then be wrong, so first do
    G1 X50 Y50
    and then enable z probe. Also consider the offset when setting the probe points. Extruder is always moved 30 left 7 front!
