Trouble with connection to HE3D K200 motherboard
Hello,
First, English is not my mother language so i'll try to do my best. (I'm always at school, I'm 17 years old)
I've just finished the construction of my printer. The problem is that the connection to the motherboard is impossible. I think i'm not the only who had this problem. Could you please send my the driver for the USB connection and the way to do it ? It will be really kind of you.
arnaudwautier@yahoo.com
Thanks in advance,
Arnaud
  • Sorry, I do not knwo what motherboard that printer has so can not say whcih driver required. You should have gotton one from your vendor.
    YOu could try installing arduino ide. It offers a driver installation and many printers use one of these drivers. If you see afterwards the com port appear in hardware drivers, you have installed the correct driver.
  • I finally found the right driver and installed everything. Thanks
    MOCmaniac, which driver ended up working for you? I'm having the same issue. Thanks
