When I Activate my pro license from the register menu, the my repetier server locks up/loads forever
I just bought a pro version of repetier server, and I'm trying to activate my license on my servers. However, whenever I try to activate the license, the server virtually freezes up while its trying to activate. It seems be stuck trying to activate itself. What should I do?
1.1.0 is latest but that is not important for activation.
[22.07.2021 13:22:49] : error in postRequest:DNS error: Temporary DNS error while resolving: licence.internetloesungen.com
/run/dnsmasq/resolv.conf
and you see the nameservers that get used.
You can manually add more nameservers like 8.8.8.8 to /etc/resolv.conf I think.
Once name can get resolved activating should get possible if you have internet access. 2 test must succeed to be sure:
Actually if this works you are done. The other one is ping the ip directly to check if you have internet access at all:
If this one also fails, you have no internet access. Make sure it is part of your intranet and your firewall allows outgoing connections form that device.
