Hey everyone!
I am rather new to the Repetier Server. My pulse xe and my prusa are connected to it and it worked great (aside from a small issue that got fixed with an update).
But now I am quite baffled and confused.
For around 2 weeks both printers start having first-layer issues. It happens every few days that the print fails and when I start again to see what is wrong I see that the first layer prints too high up. But just by enough to lay down the first layer to disconnect the print just a bit in.
When I recalibrate the Z offset (on printer for prusa, per mattercontrol with pulse) it seems like it is actually the same offset as before, but it prints again a perfect first layer.
When I then reconnect the Printers to the Server it works like a charm until a few days pass and the print fails again because of a too high first layer.
First I thought that it is an issue with the printer, but it wouldn't make sense that both printers have the same issue at the same time.
Also that the Z offset seems to be the same as before is weird to me.
Hope one of you can help me or guide me to find out what it is!
Thank you very much~
