Preconditions:
-Raspberry Pi Zero 2, 32GB Speicher
-Repetier Server v1.4.1
-Wifi-Verbindung
Error-Path:
- Drucker Wizard gestartet
- Klipper als Firmware ausgewählt
- Installation von Klipper über "+ Installieren" Button gestartet
Error-Description:
- Freeze beim package install. Keine Recovery. Keine Änderung binnen stunden
--2022-07-26 11:25:58--
http://download1.repetier.com/files/server/extras/klipperInstaller.sh
Resolving download1.repetier.com (download1.repetier.com)... 94.130.164.39
Connecting to download1.repetier.com (download1.repetier.com)|94.130.164.39|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5485 (5.4K) [application/octet-stream]
Saving to: '/tmp/klipperInstaller.sh'
/tmp/klipperInstaller. 100%[============================>] 5.36K --.-KB/s in 0s
2022-07-26 11:25:58 (96.5 MB/s) - '/tmp/klipperInstaller.sh' saved [5485/5485]
Install klipper with parameter: E617 tags/v0.10.0 1
https://github.com/Klipper3d/klipper.git
Shell: /bin/bash
###### Running apt-get update ######
Get:1
http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
Get:2
http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
Get:3
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
Get:4
http://archive.raspberrypi.org/debian bullseye/main armhf Packages [295 kB]
Hit:5
https://pkg.duet3d.com stable InRelease
Fetched 13.6 MB in 19s (710 kB/s)
Reading package lists... Done
###### Installing packages ######
Building dependency tree... Done
Reading state information... Done
Note, selecting 'python-dev-is-python2' instead of 'python-dev'
Note, selecting 'libusb-1.0-0-dev' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-doc' for regex 'libusb-1.0'
Note, selecting 'libusb-1.0-0' for regex 'libusb-1.0'
git is already the newest version (1:2.30.2-1).
libusb-1.0-0 is already the newest version (2:1.0.24-3).
libusb-1.0-0 set to manually installed.
The following additional packages will be installed:
dpkg-dev fakeroot g++-10 gcc gcc-10 libalgorithm-diff-perl libalgorithm-diff-xs-perl
libalgorithm-merge-perl libasan6 libcc1-0 libfakeroot libftdi1 libgcc-10-dev
libhidapi-libusb0 libnewlib-dev libpython2-dev libpython2-stdlib libpython2.7
libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libstdc++-10-dev
libstdc++-arm-none-eabi-newlib libubsan1 libusb-0.1-4 make python-is-python2 python2
python2-dev python2-minimal python2.7 python2.7-dev python2.7-minimal python3-appdirs
python3-distlib python3-filelock python3-importlib-metadata python3-more-itertools
python3-virtualenv python3-zipp
Suggested packages:
dfu-programmer avrdude-doc debian-keyring gcc-10-doc gcc-multilib autoconf automake
libtool flex bison gcc-doc gcc-10-locales ncurses-doc libnewlib-doc libstdc++-10-doc
make-doc python2-doc python-tk python2.7-doc binfmt-support
The following packages will be REMOVED:
python-is-python3
The following NEW packages will be installed:
avr-libc avrdude binutils-arm-none-eabi binutils-avr build-essential dfu-util dpkg-dev
fakeroot g++ g++-10 gcc gcc-10 gcc-arm-none-eabi gcc-avr libalgorithm-diff-perl
libalgorithm-diff-xs-perl libalgorithm-merge-perl libasan6 libcc1-0 libfakeroot
libffi-dev libftdi1 libgcc-10-dev libhidapi-libusb0 libncurses-dev
libnewlib-arm-none-eabi libnewlib-dev libpython2-dev libpython2-stdlib libpython2.7
libstdc++-arm-none-eabi-newlib libubsan1 libusb-0.1-4 libusb-1.0-0-dev libusb-1.0-doc
libusb-dev make python-dev-is-python2 python-is-python2 python2 python2-dev
python3-virtualenv python3-zipp stm32flash virtualenv
0 upgraded, 58 newly installed, 1 to remove and 9 not upgraded.
Need to get 247 MB of archives.
After this operation, 2154 MB of additional disk space will be used.
Get:1
http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian bullseye/main armhf libpython2.7-minimal armhf 2.7.18-8 [396 kB]
Get:2
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python2.7-minimal armhf 2.7.18-8 [1076 kB]
Get:3
http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian bullseye/main armhf python2-minimal armhf 2.7.18-3 [34.2 kB]
Get:5
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python2.7 armhf 2.7.18-8 [311 kB]
Get:6
http://mirror.netcologne.de/raspbian/raspbian bullseye/main armhf libpython2-stdlib armhf 2.7.18-3 [21.2 kB]
Get:7
http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf python2 armhf 2.7.18-3 [24.5 kB]
Get:8
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf binutils-avr armhf 2.26.20160125+Atmel3.6.2-2 [1049 kB]
Get:9
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gcc-avr armhf 1:5.4.0+Atmel3.6.2-1 [12.4 MB]
Get:11
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libusb-0.1-4 armhf 2:0.1.12-32 [21.6 kB]
Get:13
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libhidapi-libusb0 armhf 0.10.1+dfsg-1 [13.0 kB]
Get:14
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf avrdude armhf 6.3-20171130+svn1429-2+b1 [283 kB]
Get:24
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf g++ armhf 4:10.2.1-1+rpi1 [1632 B]
Get:15
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf binutils-arm-none-eabi armhf 2.34-4+rpi1+14 [2121 kB]
Get:23
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf g++-10 armhf 10.2.1-6+rpi1 [7341 kB]
Get:16
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcc1-0 armhf 10.2.1-6+rpi1 [38.3 kB]
Get:17
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libasan6 armhf 10.2.1-6+rpi1 [1986 kB]
Get:21
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gcc armhf 4:10.2.1-1+rpi1 [5196 B]
Get:22
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libstdc++-10-dev armhf 10.2.1-6+rpi1 [1751 kB]
Get:27
http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian bullseye/main armhf build-essential armhf 12.9 [7704 B]
Get:25
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf make armhf 4.3-4.1 [376 kB]
Get:29
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf fakeroot armhf 1.25.3-1.1 [86.2 kB]
Get:30
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gcc-arm-none-eabi armhf 15:8-2019-q3-1+b1 [27.3 MB]
Get:36
http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian bullseye/main armhf libnewlib-dev all 3.3.0-1 [262 kB]
Get:4
http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian bullseye/main armhf libpython2.7-stdlib armhf 2.7.18-8 [1802 kB]
Get:10
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf avr-libc all 1:2.0.0+Atmel3.6.2-1.1 [4878 kB]
Get:31
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libalgorithm-diff-perl all 1.201-1 [43.3 kB]
Get:33
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libalgorithm-merge-perl all 0.08-3 [12.7 kB]
Get:28
http://mirror.pyratelan.org/raspbian/raspbian bullseye/main armhf libfakeroot armhf 1.25.3-1.1 [45.1 kB]
Get:12
http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian bullseye/main armhf libftdi1 armhf 0.20-4 [17.0 kB]
Get:18
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libubsan1 armhf 10.2.1-6+rpi1 [746 kB]
Get:19
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libgcc-10-dev armhf 10.2.1-6+rpi1 [682 kB]
Get:20
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gcc-10 armhf 10.2.1-6+rpi1 [13.4 MB]
Get:26
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf dpkg-dev all 1.20.11+rpi1 [2308 kB]
Get:32
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libalgorithm-diff-xs-perl armhf 0.04-6+b1 [11.6 kB]
Get:37
http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian bullseye/main armhf libnewlib-arm-none-eabi all 3.3.0-1 [34.6 MB]
Get:34
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libffi-dev armhf 3.3-6 [58.2 kB]
Get:35
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libncurses-dev armhf 6.2+20201114-2 [288 kB]
Get:38
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libpython2.7 armhf 2.7.18-8 [865 kB]
Get:39
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libpython2.7-dev armhf 2.7.18-8 [1967 kB]
Get:40
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libpython2-dev armhf 2.7.18-3 [21.3 kB]
Get:42
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libusb-1.0-0-dev armhf 2:1.0.24-3 [70.8 kB]
Get:43
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf libusb-1.0-doc all 2:1.0.24-3 [192 kB]
Get:47
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python2-dev armhf 2.7.18-3 [1216 B]
Get:48
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python-dev-is-python2 all 2.7.18-9 [1528 B]
Get:49
http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf python3-appdirs all 1.4.4-1 [12.7 kB]
Get:45
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python-is-python2 all 2.7.18-9 [2940 B]
Get:53
http://mirror.de.leaseweb.net/raspbian/raspbian bullseye/main armhf python3-zipp all 1.0.0-3 [6060 B]
Get:46
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python2.7-dev armhf 2.7.18-8 [292 kB]
Get:54
http://mirror.netcologne.de/raspbian/raspbian bullseye/main armhf python3-importlib-metadata all 1.6.0-2 [10.3 kB]
Get:50
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python3-distlib all 0.3.2+really+0.3.1-0.1 [123 kB]
Get:52
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python3-more-itertools all 4.2.0-3 [42.7 kB]
Get:55
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf python3-virtualenv all 20.4.0+ds-2+deb11u1 [89.1 kB]
Get:56
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf stm32flash armhf 0.5+git20200914+2b0f078-1 [21.0 kB]
Get:57
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf virtualenv all 20.4.0+ds-2+deb11u1 [21.4 kB]
Get:58
http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf dfu-util armhf 0.9-1 [33.6 kB]
Get:41
http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libstdc++-arm-none-eabi-newlib all 15:8-2019-q3-1+13 [127 MB]
Get:51
http://mirror.cxserv.de/raspbian bullseye/main armhf python3-filelock all 3.0.12-2 [8036 B]
Get:44
http://mirror.netzwerge.de/raspbian/raspbian bullseye/main armhf libusb-dev armhf 2:0.1.12-32 [35.7 kB]
Fetched 247 MB in 1min 18s (3171 kB/s)
Extracting templates from packages: 100%
(Reading database ... 97876 files and directories currently installed.)
Removing python-is-python3 (3.9.2-1) ...
Selecting previously unselected package libpython2.7-minimal:armhf.
(Reading database ... 97872 files and directories currently installed.)
Preparing to unpack .../0-libpython2.7-minimal_2.7.18-8_armhf.deb ...
Unpacking libpython2.7-minimal:armhf (2.7.18-8) ...
Selecting previously unselected package python2.7-minimal.
Preparing to unpack .../1-python2.7-minimal_2.7.18-8_armhf.deb ...
Unpacking python2.7-minimal (2.7.18-8) ...
Selecting previously unselected package python2-minimal.
Preparing to unpack .../2-python2-minimal_2.7.18-3_armhf.deb ...
Unpacking python2-minimal (2.7.18-3) ...
Selecting previously unselected package libpython2.7-stdlib:armhf.
Preparing to unpack .../3-libpython2.7-stdlib_2.7.18-8_armhf.deb ...
Unpacking libpython2.7-stdlib:armhf (2.7.18-8) ...
Selecting previously unselected package python2.7.
Preparing to unpack .../4-python2.7_2.7.18-8_armhf.deb ...
Unpacking python2.7 (2.7.18-8) ...
Selecting previously unselected package libpython2-stdlib:armhf.
Preparing to unpack .../5-libpython2-stdlib_2.7.18-3_armhf.deb ...
Unpacking libpython2-stdlib:armhf (2.7.18-3) ...
Setting up libpython2.7-minimal:armhf (2.7.18-8) ...
Setting up python2.7-minimal (2.7.18-8) ...
Linking and byte-compiling packages for runtime python2.7...
Setting up python2-minimal (2.7.18-3) ...
(Reading database ... 98618 files and directories currently installed.)
Preparing to unpack .../00-python2_2.7.18-3_armhf.deb ...
Unpacking python2 (2.7.18-3) ...
Selecting previously unselected package binutils-avr.
Preparing to unpack .../01-binutils-avr_2.26.20160125+Atmel3.6.2-2_armhf.deb ...
Unpacking binutils-avr (2.26.20160125+Atmel3.6.2-2) ...
Selecting previously unselected package gcc-avr.
Preparing to unpack .../02-gcc-avr_1%3a5.4.0+Atmel3.6.2-1_armhf.deb ...
Unpacking gcc-avr (1:5.4.0+Atmel3.6.2-1) ...
Selecting previously unselected package avr-libc.
Preparing to unpack .../03-avr-libc_1%3a2.0.0+Atmel3.6.2-1.1_all.deb ...
Unpacking avr-libc (1:2.0.0+Atmel3.6.2-1.1) ...
Selecting previously unselected package libusb-0.1-4:armhf.
Preparing to unpack .../04-libusb-0.1-4_2%3a0.1.12-32_armhf.deb ...
Unpacking libusb-0.1-4:armhf (2:0.1.12-32) ...
Selecting previously unselected package libftdi1:armhf.
Preparing to unpack .../05-libftdi1_0.20-4_armhf.deb ...
Unpacking libftdi1:armhf (0.20-4) ...
Selecting previously unselected package libhidapi-libusb0:armhf.
Preparing to unpack .../06-libhidapi-libusb0_0.10.1+dfsg-1_armhf.deb ...
Unpacking libhidapi-libusb0:armhf (0.10.1+dfsg-1) ...
Selecting previously unselected package avrdude.
Preparing to unpack .../07-avrdude_6.3-20171130+svn1429-2+b1_armhf.deb ...
Unpacking avrdude (6.3-20171130+svn1429-2+b1) ...
Selecting previously unselected package binutils-arm-none-eabi.
Preparing to unpack .../08-binutils-arm-none-eabi_2.34-4+rpi1+14_armhf.deb ...
Unpacking binutils-arm-none-eabi (2.34-4+rpi1+14) ...
Selecting previously unselected package libcc1-0:armhf.
Preparing to unpack .../09-libcc1-0_10.2.1-6+rpi1_armhf.deb ...
Unpacking libcc1-0:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package libasan6:armhf.
Preparing to unpack .../10-libasan6_10.2.1-6+rpi1_armhf.deb ...
Unpacking libasan6:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package libubsan1:armhf.
Preparing to unpack .../11-libubsan1_10.2.1-6+rpi1_armhf.deb ...
Unpacking libubsan1:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package libgcc-10-dev:armhf.
Preparing to unpack .../12-libgcc-10-dev_10.2.1-6+rpi1_armhf.deb ...
Unpacking libgcc-10-dev:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package gcc-10.
Preparing to unpack .../13-gcc-10_10.2.1-6+rpi1_armhf.deb ...
Unpacking gcc-10 (10.2.1-6+rpi1) ...
Selecting previously unselected package gcc.
Preparing to unpack .../14-gcc_4%3a10.2.1-1+rpi1_armhf.deb ...
Unpacking gcc (4:10.2.1-1+rpi1) ...
Selecting previously unselected package libstdc++-10-dev:armhf.
Preparing to unpack .../15-libstdc++-10-dev_10.2.1-6+rpi1_armhf.deb ...
Unpacking libstdc++-10-dev:armhf (10.2.1-6+rpi1) ...
Selecting previously unselected package g++-10.
Preparing to unpack .../16-g++-10_10.2.1-6+rpi1_armhf.deb ...
Unpacking g++-10 (10.2.1-6+rpi1) ...
Selecting previously unselected package g++.
Preparing to unpack .../17-g++_4%3a10.2.1-1+rpi1_armhf.deb ...
Unpacking g++ (4:10.2.1-1+rpi1) ...
Selecting previously unselected package make.
Preparing to unpack .../18-make_4.3-4.1_armhf.deb ...
Unpacking make (4.3-4.1) ...
Selecting previously unselected package dpkg-dev.
Preparing to unpack .../19-dpkg-dev_1.20.11+rpi1_all.deb ...
Unpacking dpkg-dev (1.20.11+rpi1) ...
Selecting previously unselected package build-essential.
Preparing to unpack .../20-build-essential_12.9_armhf.deb ...
Unpacking build-essential (12.9) ...
Selecting previously unselected package libfakeroot:armhf.
Preparing to unpack .../21-libfakeroot_1.25.3-1.1_armhf.deb ...
Unpacking libfakeroot:armhf (1.25.3-1.1) ...
Selecting previously unselected package fakeroot.
Preparing to unpack .../22-fakeroot_1.25.3-1.1_armhf.deb ...
Unpacking fakeroot (1.25.3-1.1) ...
Selecting previously unselected package gcc-arm-none-eabi.
Preparing to unpack .../23-gcc-arm-none-eabi_15%3a8-2019-q3-1+b1_armhf.deb ...
Unpacking gcc-arm-none-eabi (15:8-2019-q3-1+b1) ...
