I am running v2.2.4 of RH under Windows 7 x64 Pro with 8Gb of memory.
The printer is a Geetech i3 Pro C running Marlin v2.0.9-3 firmware.
If I click the Home All Axies button on RH then issue the "M114 D" gcode command it causes RH to clear the X & Y axies to 0 - they SHOULD be the same as after the Home.
The firmware still has the correct X and Y values but the zero values cause erroneous manual moves generated by RH.
M114 D is a debug command used to examine the firmware bed leveling parameters and doesnt change any settings or statii.
NB This happens under v2.2.4 of RH - it also happens under earlier versions (eg 2.2.2)
Regards, Dave
