Well Not sure what you mean ffirmware is not reading the analog input used for thermistor. I have the extruder plugted into sensor 0 the closest to the end with the power and usb plug. the bed is pluged into the sensor 1 the moddle one and currently nothing is pluged into thesensor 2 the one closest to the connector for the display. the extruder does heat up and the thermistor reads out to the display connector. last post above the settings were for the one that I found to have the closest to room temp at no power ie the -55 when i power up and call for preheat the sensor rises and the temp rises but the temp goes up way to hot. itreached a displayed 65c andit was already melting the filiment and would easly flow by hand kind of like it was at 180c. that is when i set the max temp to 99 and it would extruded fine while runing a print. the temp was reading 99 just like I set it to be in the confug tool. the extruder temp does read out on the display and the bed thermistor reads out as it should with no problems.
Today i tried anoother attempt at the 100k NTC celection and it now reads -187 at room temp and prints at a max temp set to 99 and the display shows the 99c while printing.
now am i missing something like should I have the pullup resistor installed. I have never used that and do not have one made or in place. so if i do need to have the pull up setup in place can you telll me what discription page to i follow and what size resistors. also can you tell me what should I select in the config tool if other than the NTC 100K. sORRY I have become very confused and not sure what to do. If you could explain what to make and what to set the config to it would be a big help. I am trying to get a coouple of things done for christmas. All else is working well just the problem with the thermistor. this is the confiig.h
along with Repetier-Firmware. If not, see <http://www.gnu.org/licenses/>.</div><div><br/></div><div>*/</div><div><br/></div><div>#ifndef CONFIGURATION_H
#define CONFIGURATION_H
/**************** READ FIRST *********************
This file is optimized for version 1.0.4dev
generator: http://www.repetier.com/firmware/dev/</div><div><br/></div><div> If you are in doubt which named functions use which pins on your board, please check the
as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 33
#include "pins.h"
#define HOST_RESCUE 1
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
#undef Z_MAX_PIN
#define Z_MAX_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 1600
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define DECOUPLING_TEST_MAX_HOLD_VARIANCE 60
#define KILL_IF_SENSOR_DEFECT 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 2000
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_PREHEAT_TEMP 65
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_PGAIN_OR_DEAD_TIME 50
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_DECOUPLE_TEST_PERIOD 30000
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 0
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_X_POS 15
#define FILAMENTCHANGE_Y_POS 15
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 1
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define TEMP_GAIN 0
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define HEATED_BED_PREHEAT_TEMP 50
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_HEAT_MANAGER 3
#define MIN_EXTRUDER_TEMP 60
#define MAXTEMP 99
#define MIN_DEFECT_TEMPERATURE -100
#define MAX_DEFECT_TEMPERATURE 111
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 2
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 15
#define ENDSTOP_Y_BACK_ON_HOME 15
#define ENDSTOP_Z_BACK_ON_HOME 2
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 215
#define Y_MAX_LENGTH 215
#define Z_MAX_LENGTH 160
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 0
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define Z4_STEP_PIN ORIG_E3_STEP_PIN
#define Z4_DIR_PIN ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define ENABLE_QUADRATIC_ADVANCE 1
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 2
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
<div>#define FAN_KICKSTART_TIME 200</div><div>#define MAX_FAN_PWM 255</div><div>
</div><div> #define FEATURE_WATCHDOG 1</div><div>
</div><div>// #################### Z-Probing #####################</div><div>
</div><div>#define Z_PROBE_Z_OFFSET 0</div><div>#define Z_PROBE_Z_OFFSET_MODE 0</div><div>#define UI_BED_COATING 0</div><div>#define FEATURE_Z_PROBE 0</div><div>#define EXTRUDER_IS_Z_PROBE 0</div><div>#define Z_PROBE_DISABLE_HEATERS 0</div><div>#define Z_PROBE_BED_DISTANCE 10</div><div>#define Z_PROBE_PIN -1</div><div>#define Z_PROBE_PULLUP 0</div><div>#define Z_PROBE_ON_HIGH 0</div><div>#define Z_PROBE_X_OFFSET 0</div><div>#define Z_PROBE_Y_OFFSET 0</div><div>#define Z_PROBE_WAIT_BEFORE_TEST 0</div><div>#define Z_PROBE_SPEED 2</div><div>#define Z_PROBE_XY_SPEED 150</div><div>#define Z_PROBE_SWITCHING_DISTANCE 1</div><div>#define Z_PROBE_REPETITIONS 1</div><div>#define Z_PROBE_USE_MEDIAN 0</div><div>#define Z_PROBE_HEIGHT 40</div><div>#define Z_PROBE_DELAY 0</div><div>#define Z_PROBE_START_SCRIPT ""</div><div>#define Z_PROBE_FINISHED_SCRIPT ""</div><div>#define Z_PROBE_RUN_AFTER_EVERY_PROBE ""</div><div>#define Z_PROBE_REQUIRES_HEATING 0</div><div>#define Z_PROBE_MIN_TEMPERATURE 150</div><div>#define FEATURE_AUTOLEVEL 0</div><div>#define FEATURE_SOFTWARE_LEVELING 0</div><div>#define Z_PROBE_X1 20</div><div>#define Z_PROBE_Y1 20</div><div>#define Z_PROBE_X2 160</div><div>#define Z_PROBE_Y2 20</div><div>#define Z_PROBE_X3 20</div><div>#define Z_PROBE_Y3 160</div><div>#define BED_LEVELING_METHOD 0</div><div>#define BED_CORRECTION_METHOD 0</div><div>#define BED_LEVELING_GRID_SIZE 5</div><div>#define BED_LEVELING_REPETITIONS 5</div><div>#define BED_MOTOR_1_X 0</div><div>#define BED_MOTOR_1_Y 0</div><div>#define BED_MOTOR_2_X 200</div><div>#define BED_MOTOR_2_Y 0</div><div>#define BED_MOTOR_3_X 100</div><div>#define BED_MOTOR_3_Y 200</div><div>#define BENDING_CORRECTION_A 0</div><div>#define BENDING_CORRECTION_B 0</div><div>#define BENDING_CORRECTION_C 0</div><div>#define FEATURE_AXISCOMP 0</div><div>#define AXISCOMP_TANXY 0</div><div>#define AXISCOMP_TANYZ 0</div><div>#define AXISCOMP_TANXZ 0</div><div>
</div><div>#ifndef SDSUPPORT // Some boards have sd support on board. These define the values already in pins.h</div><div>#define SDSUPPORT 1</div><div>#undef SDCARDDETECT</div><div>#define SDCARDDETECT -1</div><div>#undef SDCARDDETECTINVERTED</div><div>#define SDCARDDETECTINVERTED 0</div><div>#endif</div><div>#define SD_EXTENDED_DIR 1 /** Show extended directory including file length. Don't use this with Pronterface! /</div><div>#define SD_RUN_ON_STOP ""</div><div>#define SD_STOP_HEATER_AND_MOTORS_ON_STOP 1</div><div>#define ARC_SUPPORT 1</div><div>#define FEATURE_MEMORY_POSITION 1</div><div>#define FEATURE_CHECKSUM_FORCED 0</div><div>#define FEATURE_FAN_CONTROL 0</div><div>#define FEATURE_FAN2_CONTROL 0</div><div>#define FEATURE_CONTROLLER 11</div><div>#define ADC_KEYPAD_PIN -1</div><div>#define LANGUAGE_EN_ACTIVE 1</div><div>#define LANGUAGE_DE_ACTIVE 0</div><div>#define LANGUAGE_NL_ACTIVE 0</div><div>#define LANGUAGE_PT_ACTIVE 0</div><div>#define LANGUAGE_IT_ACTIVE 0</div><div>#define LANGUAGE_ES_ACTIVE 0</div><div>#define LANGUAGE_FI_ACTIVE 0</div><div>#define LANGUAGE_SE_ACTIVE 0</div><div>#define LANGUAGE_FR_ACTIVE 0</div><div>#define LANGUAGE_CZ_ACTIVE 0</div><div>#define LANGUAGE_PL_ACTIVE 0</div><div>#define LANGUAGE_TR_ACTIVE 0</div><div>#define LANGUAGE_RU_ACTIVE 0</div><div>#define UI_PRINTER_NAME "MendelMax"</div><div>#define UI_PRINTER_COMPANY "KillgoDidit"</div><div>#define UI_PAGES_DURATION 4000</div><div>#define UI_SPEEDDEPENDENT_POSITIONING 1</div><div>#define UI_DISABLE_AUTO_PAGESWITCH 1</div><div>#define UI_AUTORETURN_TO_MENU_AFTER 30000</div><div>#define FEATURE_UI_KEYS 0</div><div>#define UI_ENCODER_SPEED 2</div><div>#define UI_REVERSE_ENCODER 1</div><div>#define UI_KEY_BOUNCETIME 10</div><div>#define UI_KEY_FIRST_REPEAT 500</div><div>#define UI_KEY_REDUCE_REPEAT 50</div><div>#define UI_KEY_MIN_REPEAT 50</div><div>#define FEATURE_BEEPER 1</div><div>#define CASE_LIGHTS_PIN -1</div><div>#define CASE_LIGHT_DEFAULT_ON 1</div><div>#define UI_START_SCREEN_DELAY 1000</div><div>#define UI_DYNAMIC_ENCODER_SPEED 1</div><div> /**</div><div>Beeper sound definitions for short beeps during key actions</div><div>and longer beeps for important actions.</div><div>Parameter is delay in microseconds and the secons is the number of repetitions.</div><div>Values must be in range 1..255</div><div>/</div><div>#define BEEPER_SHORT_SEQUENCE 2,2</div><div>#define BEEPER_LONG_SEQUENCE 8,8</div><div>#define UI_SET_MIN_HEATED_BED_TEMP 50</div><div>#define UI_SET_MAX_HEATED_BED_TEMP 120</div><div>#define UI_SET_MIN_EXTRUDER_TEMP 180</div><div>#define UI_SET_MAX_EXTRUDER_TEMP 260</div><div>#define UI_SET_EXTRUDER_FEEDRATE 2</div><div>#define UI_SET_EXTRUDER_RETRACT_DISTANCE 3</div><div>
</div><div>
</div><div>#define NUM_MOTOR_DRIVERS 0</div><div>
</div><div>
</div><div>
</div><div>/* Below you will find the configuration string, that created this Configuration.h</div><div>
</div><div>========== Start configuration string ==========</div><div>{</div><div> "editMode": 2,</div><div> "processor": 0,</div><div> "baudrate": 115200,</div><div> "bluetoothSerial": -1,</div><div> "bluetoothBaudrate": 115200,</div><div> "xStepsPerMM": 80,</div><div> "yStepsPerMM": 80,</div><div> "zStepsPerMM": 1600,</div><div> "xInvert": 0,</div><div> "x2Invert": 0,</div><div> "xInvertEnable": 0,</div><div> "eepromMode": 2,</div><div> "yInvert": 0,</div><div> "y2Invert": 0,</div><div> "yInvertEnable": 0,</div><div> "zInvert": 0,</div><div> "z2Invert": 0,</div><div> "z3Invert": 0,</div><div> "z4Invert": 0,</div><div> "zInvertEnable": 0,</div><div> "extruder": [</div><div> {</div><div> "id": 0,</div><div> "heatManager": 3,</div><div> "pidDriveMin": 40,</div><div> "pidDriveMax": 230,</div><div> "pidMax": 255,</div><div> "sensorType": 14,</div><div> "sensorPin": "TEMP_0_PIN",</div><div> "heaterPin": "HEATER_0_PIN",</div><div> "maxFeedrate": 50,</div><div> "startFeedrate": 20,</div><div> "invert": "0",</div><div> "invertEnable": "0",</div><div> "acceleration": 5000,</div><div> "watchPeriod": 1,</div><div> "pidP": 50,</div><div> "pidI": 2,</div><div> "pidD": 40,</div><div> "advanceK": 0,</div><div> "advanceL": 0,</div><div> "waitRetractTemp": 150,</div><div> "waitRetractUnits": 0,</div><div> "waitRetract": 0,</div><div> "stepsPerMM": 2000,</div><div> "coolerPin": -1,</div><div> "coolerSpeed": 255,</div><div> "selectCommands": "",</div><div> "deselectCommands": "",</div><div> "xOffset": 0,</div><div> "yOffset": 0,</div><div> "zOffset": 0,</div><div> "xOffsetSteps": 0,</div><div> "yOffsetSteps": 0,</div><div> "zOffsetSteps": 0,</div><div> "stepper": {</div><div> "name": "Extruder 0",</div><div> "step": "ORIG_E0_STEP_PIN",</div><div> "dir": "ORIG_E0_DIR_PIN",</div><div> "enable": "ORIG_E0_ENABLE_PIN"</div><div> },</div><div> "advanceBacklashSteps": 0,</div><div> "decoupleTestPeriod": 30,</div><div> "jamPin": -1,</div><div> "jamPullup": "0",</div><div> "mirror": "0",</div><div> "invert2": "0",</div><div> "stepper2": {</div><div> "name": "Extruder 0",</div><div> "step": "ORIG_E0_STEP_PIN",</div><div> "dir": "ORIG_E0_DIR_PIN",</div><div> "enable": "ORIG_E0_ENABLE_PIN"</div><div> },</div><div> "preheat": 65</div><div> }</div><div> ],</div><div> "uiLanguage": 0,</div><div> "uiController": 0,</div><div> "xMinEndstop": 1,</div><div> "yMinEndstop": 1,</div><div> "zMinEndstop": 1,</div><div> "xMaxEndstop": 0,</div><div> "yMaxEndstop": 0,</div><div> "zMaxEndstop": 0,</div><div> "x2MinEndstop": 0,</div><div> "y2MinEndstop": 0,</div><div> "x2MaxEndstop": 0,</div><div> "y2MaxEndstop": 0,</div><div> "motherboard": 33,</div><div> "driveSystem": 0,</div><div> "xMaxSpeed": 200,</div><div> "xHomingSpeed": 40,</div><div> "xTravelAcceleration": 1000,</div><div> "xPrintAcceleration": 1000,</div><div> "yMaxSpeed": 200,</div><div> "yHomingSpeed": 40,</div><div> "yTravelAcceleration": 1000,</div><div> "yPrintAcceleration": 1000,</div><div> "zMaxSpeed": 2,</div><div> "zHomingSpeed": 2,</div><div> "zTravelAcceleration": 100,</div><div> "zPrintAcceleration": 100,</div><div> "xMotor": {</div><div> "name": "X motor",</div><div> "step": "ORIG_X_STEP_PIN",</div><div> "dir": "ORIG_X_DIR_PIN",</div><div> "enable": "ORIG_X_ENABLE_PIN"</div><div> },</div><div> "yMotor": {</div><div> "name": "Y motor",</div><div> "step": "ORIG_Y_STEP_PIN",</div><div> "dir": "ORIG_Y_DIR_PIN",</div><div> "enable": "ORIG_Y_ENABLE_PIN"</div><div> },</div><div> "zMotor": {</div><div> "name": "Z motor",</div><div> "step": "ORIG_Z_STEP_PIN",</div><div> "dir": "ORIG_Z_DIR_PIN",</div><div> "enable": "ORIG_Z_ENABLE_PIN"</div><div> },</div><div> "enableBacklash": "0",</div><div> "backlashX": 0,</div><div> "backlashY": 0,</div><div> "backlashZ": 0,</div><div> "stepperInactiveTime": 360,</div><div> "maxInactiveTime": 0,</div><div> "xMinPos": 0,</div><div> "yMinPos": 0,</div><div> "zMinPos": 0,</div><div> "xLength": 215,</div><div> "yLength": 215,</div><div> "zLength": 160,</div><div> "alwaysCheckEndstops": "1",</div><div> "disableX": "0",</div><div> "disableY": "0",</div><div> "disableZ": "0",</div><div> "disableE": "0",</div><div> "xHomeDir": "-1",</div><div> "yHomeDir": "-1",</div><div> "zHomeDir": "-1",</div><div> "xEndstopBack": 15,</div><div> "yEndstopBack": 15,</div><div> "zEndstopBack": 2,</div><div> "deltaSegmentsPerSecondPrint": 180,</div><div> "deltaSegmentsPerSecondTravel": 70,</div><div> "deltaDiagonalRod": 445,</div><div> "deltaHorizontalRadius": 209.25,</div><div> "deltaAlphaA": 210,</div><div> "deltaAlphaB": 330,</div><div> "deltaAlphaC": 90,</div><div> "deltaDiagonalCorrA": 0,</div><div> "deltaDiagonalCorrB": 0,</div><div> "deltaDiagonalCorrC": 0,</div><div> "deltaMaxRadius": 150,</div><div> "deltaFloorSafetyMarginMM": 15,</div><div> "deltaRadiusCorrA": 0,</div><div> "deltaRadiusCorrB": 0,</div><div> "deltaRadiusCorrC": 0,</div><div> "deltaXOffsetSteps": 0,</div><div> "deltaYOffsetSteps": 0,</div><div> "deltaZOffsetSteps": 0,</div><div> "deltaSegmentsPerLine": 20,</div><div> "stepperHighDelay": 0,</div><div> "directionDelay": 0,</div><div> "stepDoublerFrequency": 12000,</div><div> "allowQuadstepping": "1",</div><div> "doubleStepDelay": 0,</div><div> "maxJerk": 20,</div><div> "maxZJerk": 0.3,</div><div> "moveCacheSize": 16,</div><div> "moveCacheLow": 10,</div><div> "lowTicksPerMove": 250000,</div><div> "enablePowerOnStartup": "1",</div><div> "echoOnExecute": "1",</div><div> "sendWaits": "1",</div><div> "ackWithLineNumber": "1",</div><div> "killMethod": 1,</div><div> "useAdvance": "0",</div><div> "useQuadraticAdvance": "1",</div><div> "powerInverting": 0,</div><div> "mirrorX": 0,</div><div> "mirrorXMotor": {</div><div> "name": "Extruder 1",</div><div> "step": "ORIG_E1_STEP_PIN",</div><div> "dir": "ORIG_E1_DIR_PIN",</div><div> "enable": "ORIG_E1_ENABLE_PIN"</div><div> },</div><div> "mirrorY": 0,</div><div> "mirrorYMotor": {</div><div> "name": "Extruder 1",</div><div> "step": "ORIG_E1_STEP_PIN",</div><div> "dir": "ORIG_E1_DIR_PIN",</div><div> "enable": "ORIG_E1_ENABLE_PIN"</div><div> },</div><div> "mirrorZ": "0",</div><div> "mirrorZMotor": {</div><div> "name": "Extruder 1",</div><div> "step": "ORIG_E1_STEP_PIN",</div><div> "dir": "ORIG_E1_DIR_PIN",</div><div> "enable": "ORIG_E1_ENABLE_PIN"</div><div> },</div><div> "mirrorZ3": "0",</div><div> "mirrorZ3Motor": {</div><div> "name": "Extruder 2",</div><div> "step": "ORIG_E2_STEP_PIN",</div><div> "dir": "ORIG_E2_DIR_PIN",</div><div> "enable": "ORIG_E2_ENABLE_PIN"</div><div> },</div><div> "mirrorZ4": "0",</div><div> "mirrorZ4Motor": {</div><div> "name": "Extruder 3",</div><div> "step": "ORIG_E3_STEP_PIN",</div><div> "dir": "ORIG_E3_DIR_PIN",</div><div> "enable": "ORIG_E3_ENABLE_PIN"</div><div> },</div><div> "dittoPrinting": "0",</div><div> "featureServos": "0",</div><div> "servo0Pin": 11,</div><div> "servo1Pin": -1,</div><div> "servo2Pin": -1,</div><div> "servo3Pin": -1,</div><div> "featureWatchdog": "1",</div><div> "hasHeatedBed": "1",</div><div> "enableZProbing": "0",</div><div> "extrudeMaxLength": 160,</div><div> "homeOrder": "HOME_ORDER_ZXY",</div><div> "featureController": 11,</div><div> "uiPrinterName": "MendelMax",</div><div> "uiPrinterCompany": "KillgoDidit",</div><div> "uiPagesDuration": 4000,</div><div> "uiHeadline": "",</div><div> "uiDisablePageswitch": "1",</div><div> "uiAutoReturnAfter": 30000,</div><div> "featureKeys": "0",</div><div> "uiEncoderSpeed": 2,</div><div> "uiReverseEncoder": "1",</div><div> "uiKeyBouncetime": 10,</div><div> "uiKeyFirstRepeat": 500,</div><div> "uiKeyReduceRepeat": 50,</div><div> "uiKeyMinRepeat": 50,</div><div> "featureBeeper": "1",</div><div> "uiMinHeatedBed": 50,</div><div> "uiMaxHeatedBed": 120,</div><div> "uiMinEtxruderTemp": 180,</div><div> "uiMaxExtruderTemp": 260,</div><div> "uiExtruderFeedrate": 2,</div><div> "uiExtruderRetractDistance": 3,</div><div> "uiSpeeddependentPositioning": "1",</div><div> "maxBedTemperature": 120,</div><div> "bedSensorType": 1,</div><div> "bedSensorPin": "TEMP_1_PIN",</div><div> "bedHeaterPin": "HEATER_1_PIN",</div><div> "bedHeatManager": 3,</div><div> "bedPreheat": 50,</div><div> "bedUpdateInterval": 5000,</div><div> "bedPidDriveMin": 80,</div><div> "bedPidDriveMax": 255,</div><div> "bedPidP": 196,</div><div> "bedPidI": 33,</div><div> "bedPidD": 290,</div><div> "bedPidMax": 255,</div><div> "bedDecoupleTestPeriod": 300,</div><div> "caseLightPin": -1,</div><div> "caseLightDefaultOn": "1",</div><div> "bedSkipIfWithin": 3,</div><div> "gen1T0": 25,</div><div> "gen1R0": 100000,</div><div> "gen1Beta": 4036,</div><div> "gen1MinTemp": -20,</div><div> "gen1MaxTemp": 300,</div><div> "gen1R1": 0,</div><div> "gen1R2": 4700,</div><div> "gen2T0": 25,</div><div> "gen2R0": 100000,</div><div> "gen2Beta": 4036,</div><div> "gen2MinTemp": -20,</div><div> "gen2MaxTemp": 300,</div><div> "gen2R1": 0,</div><div> "gen2R2": 4700,</div><div> "gen3T0": 25,</div><div> "gen3R0": 100000,</div><div> "gen3Beta": 4036,</div><div> "gen3MinTemp": -20,</div><div> "gen3MaxTemp": 300,</div><div> "gen3R1": 0,</div><div> "gen3R2": 4700,</div><div> "userTable0": {</div><div> "r1": 0,</div><div> "r2": 4700,</div><div> "temps": [],</div><div> "numEntries": 0</div><div> },</div><div> "userTable1": {</div><div> "r1": 0,</div><div> "r2": 4700,</div><div> "temps": [],</div><div> "numEntries": 0</div><div> },</div><div> "userTable2": {</div><div> "r1": 0,</div><div> "r2": 4700,</div><div> "temps": [],</div><div> "numEntries": 0</div><div> },</div><div> "tempHysteresis": 0,</div><div> "pidControlRange": 20,</div><div> "skipM109Within": 2,</div><div> "extruderFanCoolTemp": 50,</div><div> "minTemp": 60,</div><div> "maxTemp": 99,</div><div> "minDefectTemp": -100,</div><div> "maxDefectTemp": 111,</div><div> "arcSupport": "1",</div><div> "featureMemoryPositionWatchdog": "1",</div><div> "forceChecksum": "0",</div><div> "sdExtendedDir": "1",</div><div> "featureFanControl": "0",</div><div> "fanPin": "ORIG_FAN_PIN",</div><div> "featureFan2Control": "0",</div><div> "fan2Pin": "ORIG_FAN2_PIN",</div><div> "fanThermoPin": -1,</div><div> "fanThermoMinPWM": 128,</div><div> "fanThermoMaxPWM": 255,</div><div> "fanThermoMinTemp": 45,</div><div> "fanThermoMaxTemp": 60,</div><div> "fanThermoThermistorPin": -1,</div><div> "fanThermoThermistorType": 1,</div><div> "scalePidToMax": "1",</div><div> "zProbePin": -1,</div><div> "zProbeBedDistance": 10,</div><div> "zProbeDisableHeaters": "0",</div><div> "zProbePullup": "0",</div><div> "zProbeOnHigh": "0",</div><div> "zProbeXOffset": 0,</div><div> "zProbeYOffset": 0,</div><div> "zProbeWaitBeforeTest": "0",</div><div> "zProbeSpeed": 2,</div><div> "zProbeXYSpeed": 150,</div><div> "zProbeHeight": 40,</div><div> "zProbeStartScript": "",</div><div> "zProbeFinishedScript": "",</div><div> "featureAutolevel": "0",</div><div> "zProbeX1": 20,</div><div> "zProbeY1": 20,</div><div> "zProbeX2": 160,</div><div> "zProbeY2": 20,</div><div> "zProbeX3": 20,</div><div> "zProbeY3": 160,</div><div> "zProbeSwitchingDistance": 1,</div><div> "zProbeRepetitions": 1,</div><div> "zProbeMedian": "0",</div><div> "zProbeEveryPoint": "",</div><div> "sdSupport": "1",</div><div> "sdCardDetectPin": -1,</div><div> "sdCardDetectInverted": "0",</div><div> "uiStartScreenDelay": 1000,</div><div> "xEndstopBackMove": 5,</div><div> "yEndstopBackMove": 5,</div><div> "zEndstopBackMove": 2,</div><div> "xEndstopRetestFactor": 3,</div><div> "yEndstopRetestFactor": 3,</div><div> "zEndstopRetestFactor": 3,</div><div> "xMinPin": "ORIG_X_MIN_PIN",</div><div> "yMinPin": "ORIG_Y_MIN_PIN",</div><div> "zMinPin": "ORIG_Z_MIN_PIN",</div><div> "xMaxPin": "ORIG_X_MAX_PIN",</div><div> "yMaxPin": "ORIG_Y_MAX_PIN",</div><div> "zMaxPin": -1,</div><div> "x2MinPin": -1,</div><div> "y2MinPin": -1,</div><div> "x2MaxPin": -1,</div><div> "y2MaxPin": -1,</div><div> "deltaHomeOnPower": "0",</div><div> "fanBoardPin": -1,</div><div> "heaterPWMSpeed": 0,</div><div> "featureBabystepping": "1",</div><div> "babystepMultiplicator": 1,</div><div> "pdmForHeater": "0",</div><div> "pdmForCooler": "0",</div><div> "psOn": "ORIG_PS_ON_PIN",</div><div> "mixingExtruder": "0",</div><div> "decouplingTestMaxHoldVariance": 60,</div><div> "decouplingTestMinTempRise": 1,</div><div> "featureAxisComp": "0",</div><div> "axisCompTanXY": 0,</div><div> "axisCompTanXZ": 0,</div><div> "axisCompTanYZ": 0,</div><div> "retractOnPause": 2,</div><div> "pauseStartCommands": "",</div><div> "pauseEndCommands": "",</div><div> "distortionCorrection": "0",</div><div> "distortionCorrectionPoints": 5,</div><div> "distortionCorrectionR": 100,</div><div> "distortionPermanent": "1",</div><div> "distortionUpdateFrequency": 15,</div><div> "distortionStartDegrade": 0.5,</div><div> "distortionEndDegrade": 1,</div><div> "distortionExtrapolateCorners": "0",</div><div> "distortionXMin": 10,</div><div> "distortionXMax": 190,</div><div> "distortionYMin": 10,</div><div> "distortionYMax": 190,</div><div> "sdRunOnStop": "",</div><div> "sdStopHeaterMotorsOnStop": "1",</div><div> "featureRetraction": "0",</div><div> "autoretractEnabled": "0",</div><div> "retractionLength": 3,</div><div> "retractionLongLength": 13,</div><div> "retractionSpeed": 40,</div><div> "retractionZLift": 0,</div><div> "retractionUndoExtraLength": 0,</div><div> "retractionUndoExtraLongLength": 0,</div><div> "retractionUndoSpeed": 20,</div><div> "filamentChangeXPos": 15,</div><div> "filamentChangeYPos": 15,</div><div> "filamentChangeZAdd": 2,</div><div> "filamentChangeRehome": 1,</div><div> "filamentChangeShortRetract": 5,</div><div> "filamentChangeLongRetract": 50,</div><div> "fanKickstart": 200,</div><div> "servo0StartPos": -1,</div><div> "servo1StartPos": -1,</div><div> "servo2StartPos": -1,</div><div> "servo3StartPos": -1,</div><div> "uiDynamicEncoderSpeed": "1",</div><div> "uiServoControl": 0,</div><div> "killIfSensorDefect": "1",</div><div> "jamSteps": 220,</div><div> "jamSlowdownSteps": 320,</div><div> "jamSlowdownTo": 70,</div><div> "jamErrorSteps": 500,</div><div> "jamMinSteps": 10,</div><div> "jamAction": 1,</div><div> "jamMethod": 1,</div><div> "primaryPort": 0,</div><div> "numMotorDrivers": 0,</div><div> "motorDrivers": [</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1,</div><div> "endstopPin": -1,</div><div> "invertEndstop": "0",</div><div> "minEndstop": "1",</div><div> "endstopPullup": "1",</div><div> "maxDistance": 20</div><div> },</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1,</div><div> "endstopPin": -1,</div><div> "invertEndstop": "0",</div><div> "minEndstop": "1",</div><div> "endstopPullup": "1",</div><div> "maxDistance": 20</div><div> },</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1,</div><div> "endstopPin": -1,</div><div> "invertEndstop": "0",</div><div> "minEndstop": "1",</div><div> "endstopPullup": "1",</div><div> "maxDistance": 20</div><div> },</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1,</div><div> "endstopPin": -1,</div><div> "invertEndstop": "0",</div><div> "minEndstop": "1",</div><div> "endstopPullup": "1",</div><div> "maxDistance": 20</div><div> },</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1,</div><div> "endstopPin": -1,</div><div> "invertEndstop": "0",</div><div> "minEndstop": "1",</div><div> "endstopPullup": "1",</div><div> "maxDistance": 20</div><div> },</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1,</div><div> "endstopPin": -1,</div><div> "invertEndstop": "0",</div><div> "minEndstop": "1",</div><div> "endstopPullup": "1",</div><div> "maxDistance": 20</div><div> }</div><div> ],</div><div> "manualConfig": "",</div><div> "zHomeMinTemperature": 0,</div><div> "zHomeXPos": 999999,</div><div> "zHomeYPos": 999999,</div><div> "zHomeHeatHeight": 20,</div><div> "zHomeHeatAll": "1",</div><div> "zProbeZOffsetMode": 0,</div><div> "zProbeZOffset": 0,</div><div> "zProbeDelay": 0,</div><div> "uiBedCoating": "0",</div><div> "langEN": "1",</div><div> "langDE": "0",</div><div> "langNL": "0",</div><div> "langPT": "0",</div><div> "langIT": "0",</div><div> "langES": "0",</div><div> "langFI": "0",</div><div> "langSE": "0",</div><div> "langFR": "0",</div><div> "langCZ": "0",</div><div> "langPL": "0",</div><div> "langTR": "0",</div><div> "langRU": "0",</div><div> "interpolateAccelerationWithZ": 0,</div><div> "accelerationFactorTop": 100,</div><div> "bendingCorrectionA": 0,</div><div> "bendingCorrectionB": 0,</div><div> "bendingCorrectionC": 0,</div><div> "preventZDisableOnStepperTimeout": "0",</div><div> "supportLaser": "0",</div><div> "laserPin": -1,</div><div> "laserOnHigh": "1",</div><div> "laserWarmupTime": 0,</div><div> "defaultPrinterMode": 0,</div><div> "laserPwmMax": 255,</div><div> "laserWatt": 2,</div><div> "supportCNC": "0",</div><div> "cncWaitOnEnable": 300,</div><div> "cncWaitOnDisable": 0,</div><div> "cncEnablePin": -1,</div><div> "cncEnableWith": "1",</div><div> "cncDirectionPin": -1,</div><div> "cncDirectionCW": "1",</div><div> "cncPwmMax": 255,</div><div> "cncRpmMax": 8000,</div><div> "cncSafeZ": 150,</div><div> "startupGCode": "",</div><div> "jsonOutput": "0",</div><div> "bedLevelingMethod": 0,</div><div> "bedCorrectionMethod": 0,</div><div> "bedLevelingGridSize": 5,</div><div> "bedLevelingRepetitions": 5,</div><div> "bedMotor1X": 0,</div><div> "bedMotor1Y": 0,</div><div> "bedMotor2X": 200,</div><div> "bedMotor2Y": 0,</div><div> "bedMotor3X": 100,</div><div> "bedMotor3Y": 200,</div><div> "zProbeRequiresHeating": "0",</div><div> "zProbeMinTemperature": 150,</div><div> "adcKeypadPin": -1,</div><div> "sharedExtruderHeater": "0",</div><div> "extruderSwitchXYSpeed": 100,</div><div> "dualXAxis": "0",</div><div> "boardFanSpeed": 255,</div><div> "keepAliveInterval": 2000,</div><div> "moveXWhenHomed": "0",</div><div> "moveYWhenHomed": "0",</div><div> "moveZWhenHomed": "0",</div><div> "preheatTime": 30000,</div><div> "multiZEndstopHoming": "0",</div><div> "z2MinMaxPin": -1,</div><div> "z2MinMaxEndstop": 0,</div><div> "extruderIsZProbe": "0",</div><div> "boardFanMinSpeed": 0,</div><div> "doorPin": -1,</div><div> "doorEndstop": 1,</div><div> "zhomePreRaise": 0,</div><div> "zhomePreRaiseDistance": 10,</div><div> "dualXResolution": "0",</div><div> "x2axisStepsPerMM": 100,</div><div> "coolerPWMSpeed": 0,</div><div> "maxFanPWM": 255,</div><div> "raiseZOnToolchange": 0,</div><div> "distortionLimitTo": 2,</div><div> "automaticPowerup": 0,</div><div> "hasTMC2130": "0",</div><div> "TMC2130Sensorless": "0",</div><div> "TMC2130Steathchop": "1",</div><div> "TMC2130Interpolate256": "1",</div><div> "TMC2130StallguardSensitivity": 0,</div><div> "TMC2130PWMAmpl": 255,</div><div> "TMC2130PWMGrad": 1,</div><div> "TMC2130PWMAutoscale": "1",</div><div> "TMC2130PWMFreq": 2,</div><div> "TMC2130CSX": -1,</div><div> "TMC2130CSY": -1,</div><div> "TMC2130CSZ": -1,</div><div> "TMC2130CSE0": -1,</div><div> "TMC2130CSE1": -1,</div><div> "TMC2130CSE2": -1,</div><div> "TMC2130CSE3": -1,</div><div> "TMC2130CSE4": -1,</div><div> "TMC2130CurrentX": 1000,</div><div> "TMC2130CurrentY": 1000,</div><div> "TMC2130CurrentZ": 1000,</div><div> "TMC2130CurrentE0": 1000,</div><div> "TMC2130CurrentE1": 1000,</div><div> "TMC2130CurrentE2": 1000,</div><div> "TMC2130CurrentE3": 1000,</div><div> "TMC2130CurrentE4": 1000,</div><div> "TMC2130CoolstepTresholdX": 300,</div><div> "TMC2130CoolstepTresholdY": 300,</div><div> "TMC2130CoolstepTresholdZ": 300,</div><div> "microstepX": 16,</div><div> "microstepY": 16,</div><div> "microstepZ": 16,</div><div> "microstepE0": 16,</div><div> "microstepE1": 16,</div><div> "microstepE2": 16,</div><div> "microstepE3": 16,</div><div> "microstepE4": 16,</div><div> "parkPosX": 0,</div><div> "parkPosY": 0,</div><div> "parkPosZ": 10,</div><div> "emergencyParser": -1,</div><div> "hostRescue": "1",</div><div> "MAX31855SwCS": -1,</div><div> "MAX31855SwCLK": -1,</div><div> "tempGain": "0",</div><div> "safeHoming": "1",</div><div> "zProbeIIS2DH": "0",</div><div> "hasMAX6675": false,</div><div> "hasMAX31855": false,</div><div> "hasMAX31855SW": false,</div><div> "hasGeneric1": false,</div><div> "hasGeneric2": false,</div><div> "hasGeneric3": false,</div><div> "hasUser0": false,</div><div> "hasUser1": false,</div><div> "hasUser2": false,</div><div> "numExtruder": 1,</div><div> "version": 100.4,</div><div> "primaryPortName": ""</div><div>}</div><div>========== End configuration string ==========</div><div>
</div><div>*/
Thandks a lot
Mark</div><div>
</div>
