I also have the problem of some files not being rendered. Repetier-Version 1.2.0:
(As far as I remember, older Repetier-versions 1.0.x did the job correctly.)
On the Repetieron Raspi with Printers connected:
[22.11.2021
19:30:56] : While
executing:/usr/local/Repetier-Server/bin/RepetierRenderer -i
"/var/lib/Repetier-Server/projects/JM.dir/Masken.dir/Earband-Halter.dir/Diverse/.models/Diverse
Earband Halter 2021.01.rmf" -p
/var/lib/Repetier-Server/projects/JM.dir/Masken.dir/Earband-Halter.dir/Diverse/.computed
-c /var/lib/Repetier-Server/database/renderer.json
On the "Offload-Repetier" (on faster Server) just for rendering-work:
[22.11.2021 19:30:56] : While
"/var/lib/Repetier-Server/tmp/5adefb81-5138-4be9-9993-5e23abf1aeb4/Diverse
Earband Halter 2021.01.rmf" -c
/var/lib/Repetier-Server/tmp/5adefb81-5138-4be9-9993-5e23abf1aeb4/renderer.json
