Ah. well luckily they used a build on your firmware, so i have taken screen shots of that data. Not the best format to record the data. :( i cannot find the menu choice to use the host program to make a backup file. sure i am missing something simple.
if you have the steps, i would appreciate it.
also since i will have to build and compile from scratch, is there anything else i should run (G-Code, M-Code?) and record the results before the board gets flashed and is gone forever? the original vendor has not been forthcoming with any data or parameters. (they say they are still "Tweaking Settings" and not to update the firmware.
well its a standard delta design, and doesn't have a heated bed at the moment.
Its a standard atmega 2560 v1.0 board, with standard ramps etc.
thermistor is probably the only thing i will have to experiment with to start. i will be adding a display etc after.
i just wondered if you have any other advice, for people who are starting from scratch.
i think the pid settings were bad anyway because this thing would make one good-(ish) print and then be all gummed up and clogged for the next one. i am tired of having to rebuild the hot-end after every print.
in general i want to start from scratch, but i don't want to make it worse.
