37510 Suddenly host has stopped connecting to server "Could not connect to server. Check IP......"I can connect via browser and control printer so there is no network issue. Uninstalled and reinstalled Host.Windows 10. Raspberry Pi server. Standard home wifi. Thanks.
Repetier The way you describe it, it should work. Unless e.g. firewall/virus scanner blocks that communication or you made a change like different api key, new server ip or port.
37510 I can connect via browser from same computer that is running Host. I did get a new API key AFTER problem started. Rebooted host computer and server. What else can I try?
