<font face="Arial, Verdana" size="2">Hello all,</font>
I am having some issues with getting my z probe to work. I am using it as the Zmin endstop and that works fine. But when I go to probe, it moves around and doesn't actually probe. Then it stops responding. I checked the endstops to see if any were activated and they were not. Also I got correct readings from the G31 command with the endstop. Below is my z-probing conf in my Configuration.h file:
<font face="Arial, Verdana" size="2">// #################### Z-Probing #####################</font>
</font>
<font face="Arial, Verdana" size="2">#define FEATURE_Z_PROBE 1</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_BED_DISTANCE 5</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_PIN ORIG_Z_MIN_PIN</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_PULLUP 1</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_ON_HIGH 0</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_X_OFFSET 28.6</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_Y_OFFSET 40</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_WAIT_BEFORE_TEST 1</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_SPEED 3</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_XY_SPEED 30</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_SWITCHING_DISTANCE 20</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_REPETITIONS 2</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_HEIGHT 0</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_START_SCRIPT ""</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_FINISHED_SCRIPT ""</font>
<font face="Arial, Verdana" size="2">#define FEATURE_AUTOLEVEL 1</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_X1 20</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_Y1 50</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_X2 120</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_Y2 50</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_X3 20</font>
<font face="Arial, Verdana" size="2">#define Z_PROBE_Y3 170</font>
<font face="Arial, Verdana" size="2">Thank you</font>
