What leads you to think that I use Marlin? Isn't Marlin a firmware as Repetier is? If I am using Marlin I am unaware of it or how to use it. Perhaps that is my trouble, but I don't think that I am using Marlin. My third picture shows Repetier firmware.
I set my temp in manual control with the slide button as well as the digits to 285. As soon as I ticked on the nozzle the temp dropped to 270.
I then changed the temps in filament settings to 285 nozzle and 100 bed. Then saved settings and loaded an object in slicer, sliced and clicked print. In manual control tab it shows temp settings of 110 bed and 270 nozzle. Another thing that I noticed is the temp shown on the screen of the printer showed bed temp of 115. I don't have a bed temp of 115 setting anywhere that I am aware of.
I let the bed temp run for some time to see if the temps would change. They didn't. At a bed temp of 72 I clicked on Kill Print the bed continued to rise until 79 when I clicked on Emergency Stop. The bed temp continued to rise I let it go to see how long it would take before stopping. The bed temp went all the way up to 115 then the nozzle started heating. At that point I turned off the printer with the power switch.
I did try again to set the temp after setting the firmware to create a log. I then set the temp to 285 nozzle. and clicked the nozzle on. the temp dropped to 270. Here is part of what I see in the log,
> 10:08:55.544 : T:20.25 / 0 B:37.48 / 0 B@:0 @:0
> 10:08:56.531 : wait
< 10:08:56.747 : N36 M104 T0 S28527
> 10:08:56.747 : ok 36
> 10:08:56.747 : TargetExtr 0:270
> 10:08:57.751 : wait
< 10:08:58.538 : N37 M10519
> 10:08:58.538 : ok 37
> 10:08:58.553 : T:20.25 /270 B:37.10 / 0 B@:0 @:255
> 10:08:59.541 : wait
> 10:09:00.529 : wait
> 10:09:01.532 : wait
< 10:09:01.648 : N38 M10528
> 10:09:01.648 : ok 38
> 10:09:01.664 : T:21.00 /270 B:37.18 / 0 B@:0 @:255
> 10:09:02.636 : wait
> 10:09:03.639 : wait
> 10:09:04.643 : wait
< 10:09:04.658 : N39 M10529
> 10:09:04.658 : ok 39
> 10:09:04.674 : T:23.62 /270 B:37.18 / 0 B@:0 @:255
> 10:09:05.662 : wait
> 10:09:06.665 : wait
> 10:09:07.653 : wait
< 10:09:07.684 : N40 M10519
> 10:09:07.684 : ok 40
> 10:09:07.699 : T:28.19 /270 B:37.18 / 0 B@:0 @:255
> 10:09:08.687 : wait
> 10:09:09.675 : wait
I do see the M104 TO S285*27 command that must correspond to when I set that temp. Then it bumped down to 270. I scrolled down the log and next M104 I found,
> 10:13:05.923 : T:235.30 /270 B:34.27 / 0 B@:0 @:255
> 10:13:06.911 : wait
> 10:13:07.899 : wait
< 10:13:08.871 : N119 M104 T0 S27144
> 10:13:08.871 : ok 119
> 10:13:08.871 : TargetExtr 0:270
< 10:13:08.933 : N120 M10536
> 10:13:08.933 : ok 120
> 10:13:08.933 : T:236.26 /270 B:34.20 / 0 B@:0 @:255
< 10:13:09.118 : N121 M104 T0 S27139
> 10:13:09.118 : ok 121
> 10:13:09.118 : TargetExtr 0:270
< 10:13:09.372 : N122 M104 T0 S272*39
Here is a link to the log,
https://drive.google.com/file/d/1xcJ236jDmZopG7-nnA3z85bcRGKIXSc9/view?usp=sharing</div><div><br/></div><br/><br/>
