I've just set up a Repetier Server 1.03 Pro instance on an Orange Pi LTS, using the latest Armbian build.
I have loaded up some small gcodes which should each take well less than an hour, but the server is reporting that they expect to take 22-29 hours (!)
The server has all been set with default, with it querying the printer for all the settings. The printer itself is running Repetier 1.0.3 firmware, so this should be the most vanilla of all setups I can think of.
