tpaolillo When stopping a print it doesn't cooldown the nozzle or bed. So if i have to cancel a print it leaves the nozzle and bed at the temp it was set to. I have the Ender 3 V2. Repetier Server Pro 1.0.1
Repetier In printer settings you have event dependent gcodes. Add there M104 S0M140 S0M106 S0to the print stopped event if you like that. It differs what users want here so we made it a script a universal solution.Maybe even M84 to disable motor and before a G1 move to move out of your way. Starting with 1.0.2 we create such settings by default now when you use the wizard.
tpaolillo Thank you for the reply. Ok, So i would just add in the commands that i want on what event. However i added M104 S0M140 S0M106 S0in the "Run if job is aborted" and when i aborted the job the heat still stayed on.
Repetier I think you created a quick command with that name. Look a bit higher there are tabs with "quick commands" selected first. Switch to "event dependent" and you see the box where you need to enter it.
tpaolillo That is where i have it. Under the "Run if job is aborted" box. Is that the right one if i cancel the job?
Repetier When you hit the stop print button that gets executed, yes. I have tested it yesterday to work correctly. Could see the commands in console when I hit stop (square button). On pause it is not run.
tpaolillo Works now. Not sure if it had something to do with the update or what. Working now though Thanks.
