Repetier said:
Is this meant to happen with that firmware? I mean M119 should show status of pin but not stow/deploy a pin. At least that is how we do it in repetier firmware. Have no marlin with that. We only deploy when we want to measure. Apart from this M119 should always signal untriggered. bltouch only holds high signal for 10ms. Except in alarm mode where it keeps being triggered.
Yeah, that is the theory, but in fact I ran the command a couple of times and also during the issue I had. The symptom is pretty clear:
- If everything is fine and bltouch works (for homing), then M119 shows "triggered" when stowed and "open" when deployed.
- If I send the M119 to the bltouch in stowed mode and it deploys, then I know there is an issue. I did a G28 then and it always failed to trigger the probe.
It happened n ow a few times when a print finished successfully, that then a G28 led to a crash into bed, even though the print just before went fine with the G28 in the startup gcode. Somehow something happens after the print.
