I’ve been using Repetier Host on Windows with 4x 8 bit board Enders for 2 years and no trouble at all. I’ve just upgraded one machine to 32 bit and bought a 5th Ender with a 32 bit board and have developed problems when trying to print with the 32 bit machines and no problems still on 8 bit machines:
I can connect, heat the bed and hot end and jog around the print area but when I start to print, immediately the print head pauses, and moves back and forth whilst progressing on the perimeters causing a bad surface quality and bed adhesion.
I’ve narrowed it down to Repetier just not liking the 32 bit for some reason.
I have always sliced with Simplify 3D and tonight I tried the connection through their machine console and it works perfect and trouble free using the same sliced models, baud rate and USB cables that work on the 8 bit boards / machines on Repetier. I want to keep using Repetier as my preferred controller.
Am I missing some settings in Repetier that I need to change to accomodate 32 bit? Or any thing else?
Thanks in advance.
