This is interesting, and doable.
I would need to furnish the data for the CTE of ALCA5 at 1/4” in real um’s.
Our machines are calibrated and monitored to very exact tolerances, and we have determined with a reasonable conclusion, that the ALCA5 is the biggest variable and here’s why.
Our printer only prints PLA so it’s very specific for our manufacturing. It’s not a do-all machine.
We have no heated bed and our sides and top are all completely open. We have specialized hotends that incorporate 3 print heads that have a specific insulation factor and are precisely controlled with an optimized PID specifically for this head design. What this does, is maintain a constant that is rock solid once operating temperature is reached. Each head is torqued and set with a deviance between each head of +/- .001 mm at operating temperature. The frame and body add no discernible changes to the Z axis over a 10deg f swing +/- the mediant temperature of 72deg f. The PLA spooling actually changes more over this temp range than the machine does.
So in the final results, the ALCA5 has the biggest change through expansion and contraction.
We discovered that this expansion is also localized on the ALCA5 plate itself. We use two blowers ducted and compressed to 3 vents that cool the printed parts. This action actually warms the bed up in this general area and adjacent printing areas, but not the sides of the bed.
We have found that morning prints have a very prominent concentric first layer pattern then afternoon prints, which have almost no pattern at all in the first layer. The temperature swing is the variable that is causing the change. This all boils down to consistency in our quality control. The first layer is what the consumer will see everyday.
