jaysettle Has this bothered anyone else that we can't see the actual extruder temperature? It's obstructed by the slider. Is there any other way to view extruder temps without the slider in the way.
jaysettle And for some reason the insert image doesn't work with dropbox links. I had to insert hyperlink to get an image in this forum. :)
Repetier I agree, it is sometime hidden by slider which could be improved.As a quick solution, take a look at the status bar at the bottom. There you see temperatures as well.
