Ok I will try that.. That is the flow rate - correct! I looked at Repetire - CuraEngine, the Filament settings display and I see FLOW and reduced it to 100. It was 103. Also, a small add-on question. To tried to upgrade the CuraEngine software, I can find the CuraEngine.exe to move into the Repetier, pluggins, CuraEngine folder but I can not find the CuraEngine.dll, Do you know where that may be found.
Thanks for the help. Richard
