Dear All,
<br style="box-sizing: border-box;">
Could you please kindly help me to solve a problem with Z-probe (auto leveling)?
I build a H-bot printer (X, Y on the top of machine; the bed moves from top to bottom so Z probe is located at min) with Z probe (Inductive Proximity Sensor Autonics PSN17-8DN). It means that the bed will go up until the probe turn on to set Z = 0.
The problem is when I send G32 S0 (after G28 - the probe works for this command) the probe moves to three points, at each point the bed go down and up but not measure (the light on the probe not turn on), the result shows:
18:27:08.352 : Z correction disabled
18:27:08.352 : Info:Autoleveling disabled
18:27:10.383 : Z-probe:0.50 X:20.00 Y:20.00 zCorr:0.00
18:27:14.506 : Z-probe:0.50 X:160.00 Y:20.00 zCorr:0.00
18:27:18.710 : Z-probe:0.50 X:100.00 Y:160.00 zCorr:0.00
18:27:20.587 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
18:27:20.587 : Info:Autoleveling enabled
18:27:20.587 : X:100.00 Y:160.00 Z:0.500 E:0.0000
In the EEPROM, I set the probe parameters as below:
18:57:30.759 : EPR:3 808 2.000 Z-probe height [mm]
18:57:30.759 : EPR:3 929 200.000 Max. z-probe - bed dist. [mm]
18:57:30.759 : EPR:3 812 10.000 Z-probe speed [mm/s]
18:57:30.759 : EPR:3 840 150.000 Z-probe x-y-speed [mm/s]
18:57:30.759 : EPR:3 800 0.000 Z-probe offset x [mm]
18:57:30.759 : EPR:3 804 30.000 Z-probe offset y [mm]
18:57:30.759 : EPR:3 816 20.000 Z-probe X1
18:57:30.759 : EPR:3 820 20.000 Z-probe Y1
18:57:30.759 : EPR:3 824 160.000 Z-probe X2
18:57:30.759 : EPR:3 828 20.000 Z-probe Y2
18:57:30.759 : EPR:3 832 100.000 Z-probe X3
18:57:30.759 : EPR:3 836 160.000 Z-probe Y3
18:57:30.759 : EPR:0 880 1 Autolevel active (1/0)
Thank you very much for your help.
Best Regards,
Minh Hien BUI
