Hello,
I'm able to do a G32, then enable autolevel.
Then I want to run a bed height map from repetier host, which gives me the following matrix (this is on a PCB):
X: 42,00 81,50 121,00 160,50 200,00
y: 200,00 23,08 23,05 22,93 22,72 22,47
y: 175,00 23,08 23,08 22,97 22,79 22,56
y: 150,00 23,12 23,11 23,00 22,82 22,62
y: 125,00 23,19 23,14 23,00 22,82 22,69
y: 100,00 23,25 23,14 23,04 22,79 22,68
but how to enable this correction without running manually 25 G33 Xxxx Yxxxx Zxxxx commands ??
I thought after a "bed height map", this was enabled by default :(
if I run a G33 L0, I see correction Z 0.00
22:47:51.979 : g33 l0
22:47:52.079 : ok 209
22:47:52.079 : G33 X10.00 Y10.00 Z0.000
22:47:52.199 : G33 X10.00 Y55.00 Z0.000
22:47:52.199 : G33 X10.00 Y100.00 Z0.000
22:47:52.199 : G33 X10.00 Y145.00 Z0.000
22:47:52.199 : G33 X10.00 Y190.00 Z0.000
22:47:52.199 : G33 X55.00 Y10.00 Z0.000
22:47:52.199 : G33 X55.00 Y55.00 Z0.000
22:47:52.199 : G33 X55.00 Y100.00 Z0.000
if I run a M323 S1 or P1, and run a G33 L0, same story.
if I run a G33 without any option, the cnc goes to home, then move a bit, then fails
22:51:53.396 : g33
22:51:53.506 : ok 263
22:51:55.539 : busy:processing
22:51:57.532 : busy:processing
22:51:57.993 : Z correction disabled
22:51:57.993 : Reference Z for measurement:29.000
22:52:00.516 : busy:processing
22:52:01.638 : busy:processing
22:52:02.559 : Error:z-probe triggered before starting probing.
22:52:02.559 : Error:Stopping distortion measurement due to errors.
22:52:02.559 : ;@stop
22:52:02.559 : RequestStop:
22:52:03.801 : busy:processing
22:52:04.802 : fatal:G33 failed! - Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
this is a sample of the full run :
22:43:43.441 : wait
22:43:44.162 : G1 X42.00 Y100.00 Z4.240 F1200
22:43:44.162 : G30 P1
22:43:44.162 : G1 X81.50 Y100.00 Z4.240 F1200
22:43:44.162 : G30 P0
22:43:44.162 : G1 X121.00 Y100.00 Z4.240 F1200
22:43:44.162 : G1 X160.50 Y100.00 Z4.240 F1200
22:43:44.162 : G1 X200.00 Y100.00 Z4.240 F1200
22:43:44.162 : G1 X42.00 Y125.00 Z4.240 F1200
22:43:44.162 : G1 X81.50 Y125.00 Z4.240 F1200
22:43:44.162 : G1 X121.00 Y125.00 Z4.240 F1200
22:43:44.162 : G1 X160.50 Y125.00 Z4.240 F1200
22:43:44.162 : G1 X200.00 Y125.00 Z4.240 F1200
22:43:44.162 : G1 X42.00 Y150.00 Z4.240 F1200
22:43:44.162 : G1 X81.50 Y150.00 Z4.240 F1200
22:43:44.162 : G1 X121.00 Y150.00 Z4.240 F1200
22:43:44.162 : G1 X160.50 Y150.00 Z4.240 F1200
22:43:44.162 : G1 X200.00 Y150.00 Z4.240 F1200
22:43:44.172 : G1 X42.00 Y175.00 Z4.240 F1200
22:43:44.172 : G30 P0
22:43:44.172 : G1 X81.50 Y175.00 Z4.240 F1200
22:43:44.172 : G1 X121.00 Y175.00 Z4.240 F1200
22:43:44.172 : G1 X160.50 Y175.00 Z4.240 F1200
22:43:44.172 : G1 X200.00 Y175.00 Z4.240 F1200
22:43:44.172 : G1 X42.00 Y200.00 Z4.240 F1200
22:43:44.172 : G1 X81.50 Y200.00 Z4.240 F1200
22:43:44.172 : G1 X121.00 Y200.00 Z4.240 F1200
22:43:44.172 : G1 X160.50 Y200.00 Z4.240 F1200
22:43:44.172 : G1 X200.00 Y200.00 Z4.240 F1200
22:43:44.172 : G30 P2
22:43:44.293 : ok 159
22:43:44.293 : ok 160
22:43:46.305 : busy:processing
22:43:48.348 : busy:processing
22:43:50.351 : busy:processing
22:43:52.364 : busy:processing
22:43:54.597 : busy:processing
22:43:56.670 : busy:processing
22:43:58.383 : Z-probe:23.249 X:42.00 Y:100.00 zCorr:0.000
22:43:58.383 : ok 161
22:43:58.383 : ok 162
22:44:00.406 : busy:processing
22:44:02.419 : busy:processing
22:44:04.412 : busy:processing
22:44:04.872 : Z-probe:23.137 X:81.50 Y:100.00 zCorr:0.000
22:44:04.872 : ok 163
22:44:04.872 : ok 164
22:44:06.885 : busy:processing
22:44:08.888 : busy:processing
22:44:10.901 : busy:processing
22:44:12.663 : Z-probe:23.040 X:121.00 Y:100.00 zCorr:0.000
22:44:12.663 : ok 165
22:44:12.663 : ok 166
22:44:14.716 : busy:processing
22:44:16.629 : busy:processing
22:44:18.682 : busy:processing
22:44:19.694 : Z-probe:22.791 X:160.50 Y:100.00 zCorr:0.000
22:44:19.694 : ok 167
22:44:19.694 : ok 168
22:44:21.646 : busy:processing
22:44:23.699 : busy:processing
22:44:25.602 : busy:processing
22:44:26.884 : Z-probe:22.688 X:200.00 Y:100.00 zCorr:0.000
22:44:26.884 : ok 169
22:44:26.884 : ok 170
22:44:28.887 : busy:processing
22:44:30.840 : busy:processing
22:44:32.842 : busy:processing
22:44:34.925 : busy:processing
22:44:36.808 : busy:processing
22:44:38.861 : busy:processing
22:44:39.983 : Z-probe:23.184 X:42.00 Y:125.00 zCorr:0.000
22:44:39.983 : ok 171
22:44:39.983 : ok 172
22:44:41.925 : busy:processing
22:44:49.787 : busy:processing
22:44:51.750 : busy:processing
22:44:53.472 : Z-probe:23.132 X:81.50 Y:125.00 zCorr:0.000
22:44:53.472 : ok 173
22:44:53.582 : ok 174
22:44:55.475 : busy:processing
22:44:57.488 : busy:processing
22:44:59.831 : busy:processing
22:45:00.502 : Z-probe:23.002 X:121.00 Y:125.00 zCorr:0.000
22:45:00.502 : ok 175
22:45:00.502 : ok 176
22:45:02.505 : busy:processing
22:45:04.508 : busy:processing
22:45:06.521 : busy:processing
22:45:06.691 : Z-probe:22.820 X:160.50 Y:125.00 zCorr:0.000
22:45:06.691 : ok 177
22:45:06.691 : ok 178
22:45:08.644 : busy:processing
22:45:10.647 : busy:processing
22:45:12.660 : busy:processing
22:45:12.880 : Z-probe:22.697 X:200.00 Y:125.00 zCorr:0.000
22:45:12.880 : ok 179
22:45:12.880 : ok 180
22:45:14.883 : busy:processing
22:45:16.846 : busy:processing
22:45:18.899 : busy:processing
22:45:20.902 : busy:processing
22:45:22.914 : busy:processing
22:45:24.917 : busy:processing
22:45:25.929 : Z-probe:23.115 X:42.00 Y:150.00 zCorr:0.000
22:45:25.929 : ok 181
22:45:25.929 : ok 182
22:45:27.922 : busy:processing
22:45:33.059 : busy:processing
22:45:34.962 : busy:processing
22:45:38.547 : Z-probe:23.107 X:81.50 Y:150.00 zCorr:0.000
22:45:38.547 : ok 183
22:45:38.547 : ok 184
22:45:38.777 : busy:processing
22:45:40.780 : busy:processing
22:45:42.793 : busy:processing
22:45:43.684 : Z-probe:22.994 X:121.00 Y:150.00 zCorr:0.000
22:45:43.684 : ok 185
22:45:43.684 : ok 186
22:45:45.697 : busy:processing
22:45:47.690 : busy:processing
22:45:49.703 : busy:processing
22:45:50.614 : Z-probe:22.818 X:160.50 Y:150.00 zCorr:0.000
22:45:50.614 : ok 187
22:45:50.614 : ok 188
22:45:52.607 : busy:processing
22:45:54.720 : busy:processing
22:45:56.723 : busy:processing
22:45:58.175 : Z-probe:22.622 X:200.00 Y:150.00 zCorr:0.000
22:45:58.175 : ok 189
22:45:58.175 : ok 190
22:46:00.098 : busy:processing
22:46:02.171 : busy:processing
22:46:04.114 : busy:processing
22:46:06.107 : busy:processing
22:46:08.119 : busy:processing
22:46:10.132 : busy:processing
22:46:11.805 : Z-probe:23.086 X:42.00 Y:175.00 zCorr:0.000
22:46:11.805 : ok 191
22:46:11.985 : ok 192
22:46:15.600 : busy:processing
22:46:17.713 : busy:processing
22:46:19.386 : Z-probe:23.087 X:81.50 Y:175.00 zCorr:0.000
22:46:19.396 : ok 193
22:46:19.396 : ok 194
22:46:21.378 : busy:processing
22:46:23.391 : busy:processing
22:46:25.404 : busy:processing
22:46:25.765 : Z-probe:22.980 X:121.00 Y:175.00 zCorr:0.000
22:46:25.765 : ok 195
22:46:25.765 : ok 196
22:46:27.748 : busy:processing
22:46:29.761 : busy:processing
22:46:31.763 : busy:processing
22:46:32.535 : Z-probe:22.798 X:160.50 Y:175.00 zCorr:0.000
22:46:32.535 : ok 197
22:46:32.655 : ok 198
22:46:34.668 : busy:processing
22:46:36.560 : busy:processing
22:46:38.573 : busy:processing
22:46:39.565 : Z-probe:22.558 X:200.00 Y:175.00 zCorr:0.000
22:46:39.565 : ok 199
22:46:39.565 : ok 200
22:46:42.269 : busy:processing
22:46:43.580 : busy:processing
22:46:45.583 : busy:processing
22:46:47.586 : busy:processing
22:46:49.599 : busy:processing
22:46:51.712 : busy:processing
22:46:51.932 : Z-probe:23.089 X:42.00 Y:200.00 zCorr:0.000
22:46:51.932 : ok 201
22:46:51.932 : ok 202
22:46:53.945 : busy:processing
22:46:55.968 : busy:processing
22:46:59.824 : busy:processing
22:46:59.824 : Z-probe:23.055 X:81.50 Y:200.00 zCorr:0.000
22:46:59.824 : ok 203
22:46:59.824 : ok 204
22:47:00.635 : busy:processing
22:47:02.648 : busy:processing
22:47:04.651 : busy:processing
22:47:05.191 : Z-probe:22.938 X:121.00 Y:200.00 zCorr:0.000
22:47:05.191 : ok 205
22:47:05.191 : ok 206
22:47:07.154 : busy:processing
22:47:09.217 : busy:processing
22:47:11.220 : busy:processing
22:47:11.781 : Z-probe:22.723 X:160.50 Y:200.00 zCorr:0.000
22:47:11.781 : ok 207
22:47:11.781 : ok 208
22:47:13.894 : busy:processing
22:47:15.907 : busy:processing
22:47:18.020 : busy:processing
22:47:18.030 : Z-probe:22.474 X:200.00 Y:200.00 zCorr:0.000
22:47:18.030 : wait
22:47:19.031 : wait
22:47:50.146 : wait
22:47:51.148 : wait
22:47:52.199 : G33 X55.00 Y145.00 Z0.000
22:47:52.199 : G33 X55.00 Y190.00 Z0.000
22:47:52.199 : G33 X100.00 Y10.00 Z0.000
22:47:52.199 : G33 X100.00 Y55.00 Z0.000
22:47:52.199 : G33 X100.00 Y100.00 Z0.000
22:47:52.199 : G33 X100.00 Y145.00 Z0.000
22:47:52.199 : G33 X100.00 Y190.00 Z0.000
22:47:52.199 : G33 X145.00 Y10.00 Z0.000
22:47:52.199 : G33 X145.00 Y55.00 Z0.000
22:47:52.199 : G33 X145.00 Y100.00 Z0.000
22:47:52.199 : G33 X145.00 Y145.00 Z0.000
22:47:52.199 : G33 X145.00 Y190.00 Z0.000
22:47:52.199 : G33 X190.00 Y10.00 Z0.000
22:47:52.199 : G33 X190.00 Y55.00 Z0.000
22:47:52.199 : G33 X190.00 Y100.00 Z0.000
22:47:52.199 : G33 X190.00 Y145.00 Z0.000
22:47:52.199 : G33 X190.00 Y190.00 Z0.000
22:47:53.040 : wait
22:47:54.052 : wait
22:47:55.053 : wait
22:47:56.055 : wait
22:47:57.056 : wait
22:47:58.178 : wait
22:47:59.179 : wait
22:48:00.181 : wait
22:48:00.852 : m323 s1
22:48:00.962 : ok 210
22:48:00.962 : Z correction enabled
22:48:01.973 : wait
22:48:03.075 : wait
22:48:04.086 : wait
22:48:05.088 : wait
22:48:06.089 : wait
22:48:07.090 : wait
22:48:08.132 : wait
22:48:08.913 : m323 p1
22:48:09.023 : ok 211
22:48:09.023 : Z correction enabled
22:48:10.115 : wait
22:48:11.106 : wait
22:48:12.108 : wait
22:48:13.109 : wait
22:48:14.081 : wait
22:48:15.022 : wait
22:48:15.232 : G1 X42.00 Y100.00 Z4.240 F1200
22:48:15.232 : G30 P1
22:48:15.232 : G1 X81.50 Y100.00 Z4.240 F1200
22:48:15.232 : G30 P0
22:48:15.232 : G1 X121.00 Y100.00 Z4.240 F1200
22:48:15.232 : G1 X160.50 Y100.00 Z4.240 F1200
22:48:15.232 : G1 X200.00 Y100.00 Z4.240 F1200
22:48:15.232 : G1 X42.00 Y125.00 Z4.240 F1200
22:48:15.232 : G1 X81.50 Y125.00 Z4.240 F1200
22:48:15.232 : G1 X121.00 Y125.00 Z4.240 F1200
22:48:15.232 : G1 X160.50 Y125.00 Z4.240 F1200
22:48:15.232 : G1 X200.00 Y125.00 Z4.240 F1200
22:48:15.232 : G1 X42.00 Y150.00 Z4.240 F1200
22:48:15.232 : G1 X81.50 Y150.00 Z4.240 F1200
22:48:15.232 : G1 X121.00 Y150.00 Z4.240 F1200
22:48:15.232 : G1 X160.50 Y150.00 Z4.240 F1200
22:48:15.232 : G1 X200.00 Y150.00 Z4.240 F1200
22:48:15.232 : G1 X42.00 Y175.00 Z4.240 F1200
22:48:15.232 : G1 X81.50 Y175.00 Z4.240 F1200
22:48:15.232 : G1 X121.00 Y175.00 Z4.240 F1200
22:48:15.232 : G1 X160.50 Y175.00 Z4.240 F1200
22:48:15.232 : G1 X200.00 Y175.00 Z4.240 F1200
22:48:15.232 : G1 X42.00 Y200.00 Z4.240 F1200
22:48:15.232 : G1 X81.50 Y200.00 Z4.240 F1200
22:48:15.232 : G1 X121.00 Y200.00 Z4.240 F1200
22:48:15.232 : G1 X160.50 Y200.00 Z4.240 F1200
22:48:15.232 : G1 X200.00 Y200.00 Z4.240 F1200
22:48:15.232 : G30 P2
22:48:15.362 : ok 212
22:48:15.362 : ok 213
22:48:17.315 : busy:processing
22:48:19.478 : busy:processing
22:48:21.481 : busy:processing
22:48:23.484 : busy:processing
22:48:26.058 : busy:processing
22:48:28.061 : busy:processing
22:48:29.963 : Z-probe:23.252 X:42.00 Y:100.00 zCorr:0.000
22:48:29.963 : ok 214
22:48:29.963 : ok 215
22:48:31.846 : busy:processing
22:48:33.979 : busy:processing
22:48:35.862 : busy:processing
22:48:36.543 : Z-probe:23.139 X:81.50 Y:100.00 zCorr:0.000
22:48:36.543 : ok 216
22:48:36.543 : ok 217
22:48:38.436 : busy:processing
22:48:41.009 : busy:processing
22:48:43.012 : busy:processing
22:48:44.574 : Z-probe:23.041 X:121.00 Y:100.00 zCorr:0.000
22:48:44.574 : ok 218
22:48:44.574 : ok 219
22:48:46.577 : busy:processing
22:48:49.552 : busy:processing
22:48:50.823 : busy:processing
22:48:52.265 : Z-probe:22.792 X:160.50 Y:100.00 zCorr:0.000
22:48:52.265 : ok 220
22:48:52.265 : ok 221
22:48:54.388 : busy:processing
22:48:56.391 : busy:processing
22:48:59.806 : busy:processing
22:48:59.806 : Z-probe:22.684 X:200.00 Y:100.00 zCorr:0.000
22:48:59.806 : ok 222
22:48:59.806 : ok 223
22:49:00.748 : busy:processing
22:49:02.690 : busy:processing
22:49:04.753 : busy:processing
22:49:06.756 : busy:processing
22:49:08.759 : busy:processing
22:49:10.772 : busy:processing
22:49:11.553 : Z-probe:23.187 X:42.00 Y:125.00 zCorr:0.000
22:49:11.553 : ok 224
22:49:11.553 : ok 225
22:49:13.566 : busy:processing
22:49:15.569 : busy:processing
22:49:17.532 : busy:processing
22:49:18.583 : Z-probe:23.135 X:81.50 Y:125.00 zCorr:0.000
22:49:18.583 : ok 226
22:49:18.583 : ok 227
22:49:20.506 : busy:processing
22:49:22.479 : busy:processing
22:49:24.482 : busy:processing
22:49:25.163 : Z-probe:23.004 X:121.00 Y:125.00 zCorr:0.000
22:49:25.163 : ok 228
22:49:25.163 : ok 229
22:49:27.176 : busy:processing
22:49:29.169 : busy:processing
22:49:31.292 : busy:processing
22:49:31.842 : Z-probe:22.822 X:160.50 Y:125.00 zCorr:0.000
22:49:31.842 : ok 230
22:49:31.842 : ok 231
22:49:33.855 : busy:processing
22:49:35.858 : busy:processing
22:49:37.811 : busy:processing
22:49:38.031 : Z-probe:22.691 X:200.00 Y:125.00 zCorr:0.000
22:49:38.031 : ok 232
22:49:38.031 : ok 233
22:49:40.094 : busy:processing
22:49:42.097 : busy:processing
22:49:44.100 : busy:processing
22:49:46.113 : busy:processing
22:49:48.086 : busy:processing
22:49:50.008 : busy:processing
22:49:50.579 : Z-probe:23.120 X:42.00 Y:150.00 zCorr:0.000
22:49:50.579 : ok 234
22:49:50.579 : ok 235
22:49:53.153 : busy:processing
22:49:54.585 : busy:processing
22:49:56.598 : busy:processing
22:49:57.669 : Z-probe:23.112 X:81.50 Y:150.00 zCorr:0.000
22:49:57.669 : ok 236
22:49:57.669 : ok 237
22:49:59.722 : busy:processing
22:50:01.665 : busy:processing
22:50:03.728 : busy:processing
22:50:05.300 : Z-probe:22.997 X:121.00 Y:150.00 zCorr:0.000
22:50:05.300 : ok 238
22:50:05.300 : ok 239
22:50:07.293 : busy:processing
22:50:09.306 : busy:processing
22:50:11.319 : busy:processing
22:50:12.541 : Z-probe:22.820 X:160.50 Y:150.00 zCorr:0.000
22:50:12.541 : ok 240
22:50:12.541 : ok 241
22:50:14.624 : busy:processing
22:50:16.567 : busy:processing
22:50:18.580 : busy:processing
22:50:20.142 : Z-probe:22.621 X:200.00 Y:150.00 zCorr:0.000
22:50:20.142 : ok 242
22:50:20.142 : ok 243
22:50:22.245 : busy:processing
22:50:24.148 : busy:processing
22:50:26.150 : busy:processing
22:50:28.604 : busy:processing
22:50:30.617 : busy:processing
22:50:32.279 : Z-probe:23.083 X:42.00 Y:175.00 zCorr:0.000
22:50:32.279 : ok 244
22:50:32.279 : ok 245
22:50:34.282 : busy:processing
22:50:36.295 : busy:processing
22:50:38.258 : busy:processing
22:50:38.869 : Z-probe:23.082 X:81.50 Y:175.00 zCorr:0.000
22:50:38.869 : ok 246
22:50:38.869 : ok 247
22:50:40.892 : busy:processing
22:50:42.864 : busy:processing
22:50:44.917 : busy:processing
22:50:45.368 : Z-probe:22.974 X:121.00 Y:175.00 zCorr:0.000
22:50:45.368 : ok 248
22:50:45.368 : ok 249
22:50:47.371 : busy:processing
22:50:49.714 : busy:processing
22:50:51.717 : busy:processing
22:50:53.219 : Z-probe:22.793 X:160.50 Y:175.00 zCorr:0.000
22:50:53.219 : ok 250
22:50:53.219 : ok 251
22:50:56.835 : busy:processing
22:50:57.175 : busy:processing
22:50:59.799 : busy:processing
22:50:59.799 : Z-probe:22.555 X:200.00 Y:175.00 zCorr:0.000
22:50:59.799 : ok 252
22:50:59.799 : ok 253
22:51:01.451 : busy:processing
22:51:03.464 : busy:processing
22:51:05.457 : busy:processing
22:51:07.470 : busy:processing
22:51:09.473 : busy:processing
22:51:11.486 : busy:processing
22:51:11.716 : Z-probe:23.084 X:42.00 Y:200.00 zCorr:0.000
22:51:11.716 : ok 254
22:51:11.716 : ok 255
22:51:13.739 : busy:processing
22:51:15.762 : busy:processing
22:51:17.755 : busy:processing
22:51:18.155 : Z-probe:23.050 X:81.50 Y:200.00 zCorr:0.000
22:51:18.155 : ok 256
22:51:18.155 : ok 257
22:51:20.198 : busy:processing
22:51:22.101 : busy:processing
22:51:24.104 : busy:processing
22:51:24.675 : Z-probe:22.931 X:121.00 Y:200.00 zCorr:0.000
22:51:24.675 : ok 258
22:51:24.675 : ok 259
22:51:26.667 : busy:processing
22:51:28.680 : busy:processing
22:51:30.693 : busy:processing
22:51:31.745 : Z-probe:22.721 X:160.50 Y:200.00 zCorr:0.000
22:51:31.745 : ok 260
22:51:31.745 : ok 261
22:51:33.808 : busy:processing
22:51:35.710 : busy:processing
22:51:37.713 : Z-probe:22.471 X:200.00 Y:200.00 zCorr:0.000
22:51:37.713 : wait
22:51:38.625 : wait
22:51:39.716 : wait
22:51:40.618 : wait
22:51:41.619 : wait
22:51:42.620 : wait
22:51:43.622 : wait
22:51:44.623 : wait
22:51:45.615 : wait
22:51:46.636 : wait
22:51:47.638 : wait
22:51:47.748 : g33 l0
22:51:47.868 : ok 262
22:51:47.868 : G33 X10.00 Y10.00 Z0.000
22:51:47.868 : G33 X10.00 Y55.00 Z0.000
22:51:47.868 : G33 X10.00 Y100.00 Z0.000
22:51:47.868 : G33 X10.00 Y145.00 Z0.000
22:51:47.868 : G33 X10.00 Y190.00 Z0.000
22:51:47.868 : G33 X55.00 Y10.00 Z0.000
22:51:47.868 : G33 X55.00 Y55.00 Z0.000
22:51:47.868 : G33 X55.00 Y100.00 Z0.000
22:51:47.868 : G33 X55.00 Y145.00 Z0.000
22:51:47.868 : G33 X55.00 Y190.00 Z0.000
22:51:47.868 : G33 X100.00 Y10.00 Z0.000
22:51:47.868 : G33 X100.00 Y55.00 Z0.000
22:51:47.868 : G33 X100.00 Y100.00 Z0.000
22:51:47.868 : G33 X100.00 Y145.00 Z0.000
22:51:47.868 : G33 X100.00 Y190.00 Z0.000
22:51:47.868 : G33 X145.00 Y10.00 Z0.000
22:51:47.868 : G33 X145.00 Y55.00 Z0.000
22:51:47.868 : G33 X145.00 Y100.00 Z0.000
22:51:47.868 : G33 X145.00 Y145.00 Z0.000
22:51:47.868 : G33 X145.00 Y190.00 Z0.000
22:51:47.868 : G33 X190.00 Y10.00 Z0.000
22:51:47.868 : G33 X190.00 Y55.00 Z0.000
22:51:47.968 : G33 X190.00 Y100.00 Z0.000
22:51:47.968 : G33 X190.00 Y145.00 Z0.000
22:51:47.968 : G33 X190.00 Y190.00 Z0.000
22:51:48.859 : wait
22:51:49.861 : wait
22:51:50.862 : wait
22:51:51.864 : wait
22:51:52.865 : wait
22:51:53.396 : g33
22:52:04.802 : wait
22:52:05.804 : wait
22:52:06.805 : wait
22:52:07.807 : wait
22:52:08.808 : wait
22:52:09.820 : wait
22:52:10.340 : M999
22:52:10.460 : ok 264
22:52:10.460 : DebugLevel:6
22:52:10.460 : info:Continue from fatal state
22:52:10.460 : ok
22:52:11.342 : M110 N1
22:52:11.442 : ok
22:52:11.442 : ok
22:52:11.442 : ok
22:52:12.483 : wait
22:52:13.395 : g33
22:52:13.505 : wait
22:52:13.505 : ok 2
22:52:13.505 : Z correction disabled
22:52:15.498 : busy:processing
22:52:17.511 : busy:processing
22:52:19.503 : busy:processing
22:52:21.516 : busy:processing
22:52:22.628 : X:-0.00 Y:0.00 Z:49.804 E:0.0000
22:52:23.469 : busy:processing
22:52:25.522 : busy:processing
22:52:26.423 : Z correction disabled
22:52:26.534 : Reference Z for measurement:29.000
22:52:27.205 : Error:z-probe triggered before starting probing.
22:52:27.205 : Error:Stopping distortion measurement due to errors.
22:52:27.205 : ;@stop
22:52:27.205 : RequestStop:
22:52:27.535 : busy:processing
22:52:29.328 : fatal:G33 failed! - Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:52:29.328 : wait
22:52:30.319 : wait
22:52:31.330 : wait
22:52:32.342 : wait
22:52:33.293 : wait
22:52:33.494 : M999
22:52:33.604 : ok 3
22:52:33.604 : DebugLevel:6
22:52:33.604 : info:Continue from fatal state
22:52:33.604 : ok
22:52:34.495 : M110 N1
22:52:34.605 : ok
22:52:34.605 : ok
22:52:34.605 : ok
22:52:34.605 : ok
22:52:35.677 : wait
22:52:48.675 : wait
22:52:48.675 : g1 x42
22:52:48.796 : ok 2
22:52:55.876 : wait
22:52:56.867 : wait
22:52:59.341 : g1 x42 y100
22:53:10.036 : wait
22:53:10.747 : g92 x0 y0
22:53:10.847 : ok 4
22:53:10.847 : X_OFFSET:-42.000 Y_OFFSET:-100.000 Z_OFFSET:0.000
22:53:11.809 : wait
22:53:12.810 : wait
22:53:13.882 : wait
22:53:14.062 : g33
22:53:14.172 : ok 5
22:53:14.172 : Z correction disabled
22:53:16.165 : busy:processing
22:53:18.278 : busy:processing
22:53:20.301 : busy:processing
22:53:22.294 : busy:processing
22:53:24.307 : busy:processing
22:53:26.420 : busy:processing
22:53:28.202 : X:-0.00 Y:0.00 Z:49.804 E:0.0000
22:53:28.322 : busy:processing
22:53:30.325 : busy:processing
22:53:31.988 : Z correction disabled
22:53:31.988 : Reference Z for measurement:29.000
22:53:32.328 : busy:processing
22:53:32.659 : Error:z-probe triggered before starting probing.
22:53:32.659 : Error:Stopping distortion measurement due to errors.
22:53:32.659 : ;@stop
22:53:32.659 : RequestStop:
22:53:34.451 : busy:processing
22:53:34.782 : fatal:G33 failed! - Printer stopped and heaters disabled due to this error. Fix error and restart with M999.
22:53:34.782 : wait
22:53:35.773 : wait
22:53:36.785 : wait
22:53:37.786 : wait
22:53:38.747 : wait
22:53:39.799 : wait
22:53:40.139 : M999
22:53:40.250 : ok 6
22:53:40.250 : DebugLevel:6
22:53:40.250 : info:Continue from fatal state
22:53:40.250 : ok
22:53:41.141 : M110 N1
22:53:41.251 : ok
22:53:41.251 : ok
22:53:41.251 : ok
22:53:41.251 : ok
22:53:41.251 : ok
thanks in advance !
