StijnA Hi, for a project I had the task of changing the steps per mm in arduino code.Where can i find this parameter?I changed the value in the configuration.h map but this didn't do anything.Kind regards,A new guy to this stuf
MartinH If the eeprom is enabled on your controller board then the steps/mm stored in eeprom will take preference over the configuration.h.You can update the eeprom with the values you changed the configuration.h by sending M502 ;read default settingsM500 ;store to eeprom
StijnA Thanks man, you saved my ass (and the printer from being thrown against a wall from frustration)
