Hi guys,
I´m using the Repetier-Host 2.1.6 and after sliceing with silcr3 a message pops up and says kind of, Repetier Host can not find the G-code file.
The file gets generated and it´s in the Folder User/AppData/Local/Repetier-Host. I can copy that and Paste it into Repetier-Host. This is working but, Repetier isn´t able to load the G-Code file on it´s own. I have no idea what is causing this. I had the same problem with the older versions, too.
Can someone help me out ???
