Aaarg. I made the changes, uploaded OK. Cut power, pulled the USB and restarted.
The only difference is that the E1 turns when prompted before running a print, before it wouldn't until printing.
E1 is still connected to Z and always goes retraction direction when Homing or Raising Z.
It turns the correct direction when printing.
I'd be OK with it if it just would never go retraction - ever. I don't need it.
Here's all Config h.
This
file is part of Repetier-Firmware.
Repetier-Firmware
is free software: you can redistribute it and/or modify
it
under the terms of the GNU General Public License as published by
the
Free Software Foundation, either version 3 of the License, or
(at
your option) any later version.
Repetier-Firmware
is distributed in the hope that it will be useful,
but
WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY
or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU
General Public License for more details.
You
should have received a copy of the GNU General Public License
along
with Repetier-Firmware. If not, see <http://www.gnu.org/licenses/>.
#ifndef
CONFIGURATION_H
#define
CONFIGURATION_H
READ FIRST ************************
This
configuration file was created with the configuration tool. For that
reason,
it does not contain the same informations as the original
Configuration.h file.
It
misses the comments and unused parts. Open this file file in the
config tool
to
see and change the data. You can also upload it to newer/older
versions. The system
will
silently add new options, so compilation continues to work.
This
file is optimized for version 1.0.3
generator:
http://www.repetier.com/firmware/dev/
If
you are in doubt which named functions use which pins on your board,
please check the
pins.h
for the used name->pin assignments and your board documentation to
verify it is
as
you expect.
#define
NUM_EXTRUDER 2
#define
MOTHERBOARD 301
#include
"pins.h"
################## EDIT THESE SETTINGS MANUALLY ################
Microstepping mode of your RAMBO board
#define
MICROSTEP_MODES { 8,8,8,8,8 } // [1,2,4,8,16]
Motor Current setting (Only functional when motor driver current ref
pins are connected to a digital trimpot on supported boards)
#define
MOTOR_CURRENT_PERCENT { 55,55,50,60,60 }
################ END MANUAL SETTINGS ##########################
#undef
FAN_BOARD_PIN
#define
FAN_BOARD_PIN -1
#define
BOARD_FAN_SPEED 255
#define
BOARD_FAN_MIN_SPEED 0
#define
FAN_THERMO_PIN -1
#define
FAN_THERMO_MIN_PWM 128
#define
FAN_THERMO_MAX_PWM 255
#define
FAN_THERMO_MIN_TEMP 45
#define
FAN_THERMO_MAX_TEMP 60
#define
FAN_THERMO_THERMISTOR_PIN -1
#define
FAN_THERMO_THERMISTOR_TYPE 1
//#define
EXTERNALSERIAL use Arduino serial library instead of build in.
Requires more ram, has only 63 byte input buffer.
Uncomment the following line if you are using Arduino compatible
firmware made for Arduino version earlier then 1.0
If it is incompatible you will get compiler errors about write
functions not being compatible!
//#define
COMPAT_PRE1
#define
BLUETOOTH_SERIAL -1
#define
BLUETOOTH_BAUD 115200
#define
MIXING_EXTRUDER 0
#define
DRIVE_SYSTEM 0
#define
XAXIS_STEPS_PER_MM 64.24
#define
YAXIS_STEPS_PER_MM 64.24
#define
ZAXIS_STEPS_PER_MM 631.56
#define
EXTRUDER_FAN_COOL_TEMP 50
#define
PDM_FOR_EXTRUDER 0
#define
PDM_FOR_COOLER 0
#define
DECOUPLING_TEST_MAX_HOLD_VARIANCE 20
#define
DECOUPLING_TEST_MIN_TEMP_RISE 1
#define
KILL_IF_SENSOR_DEFECT 0
#define
RETRACT_ON_PAUSE 2
#define
PAUSE_START_COMMANDS ""
#define
PAUSE_END_COMMANDS ""
#define
SHARED_EXTRUDER_HEATER 0
#define
EXT0_X_OFFSET 0
#define
EXT0_Y_OFFSET 0
#define
EXT0_Z_OFFSET 0
#define
EXT0_STEPS_PER_MM 370
#define
EXT0_TEMPSENSOR_TYPE 1
#define
EXT0_TEMPSENSOR_PIN TEMP_0_PIN
#define
EXT0_HEATER_PIN HEATER_0_PIN
#define
EXT0_STEP_PIN ORIG_E0_STEP_PIN
#define
EXT0_DIR_PIN ORIG_E0_DIR_PIN
#define
EXT0_INVERSE 0
#define
EXT0_ENABLE_PIN ORIG_E0_ENABLE_PIN
#define
EXT0_ENABLE_ON 0
#define
EXT0_MIRROR_STEPPER 1
#define
EXT0_STEP2_PIN ORIG_E1_STEP_PIN
#define
EXT0_DIR2_PIN ORIG_E1_DIR_PIN
#define
EXT0_INVERSE2 1
#define
EXT0_ENABLE2_PIN ORIG_E1_ENABLE_PIN
#define
EXT0_MAX_FEEDRATE 40
#define
EXT0_MAX_START_FEEDRATE 20
#define
EXT0_MAX_ACCELERATION 3000
#define
EXT0_HEAT_MANAGER 3
#define
EXT0_PREHEAT_TEMP 230
#define
EXT0_WATCHPERIOD 1
#define
EXT0_PID_INTEGRAL_DRIVE_MAX 230
#define
EXT0_PID_INTEGRAL_DRIVE_MIN 40
#define
EXT0_PID_PGAIN_OR_DEAD_TIME 7
#define
EXT0_PID_I 2
#define
EXT0_PID_D 40
#define
EXT0_PID_MAX 255
#define
EXT0_ADVANCE_K 0
#define
EXT0_ADVANCE_L 0
#define
EXT0_ADVANCE_BACKLASH_STEPS 0
#define
EXT0_WAIT_RETRACT_TEMP 150
#define
EXT0_WAIT_RETRACT_UNITS 0
#define
EXT0_SELECT_COMMANDS ""
#define
EXT0_DESELECT_COMMANDS ""
#define
EXT0_EXTRUDER_COOLER_PIN -1
#define
EXT0_EXTRUDER_COOLER_SPEED 255
#define
EXT0_DECOUPLE_TEST_PERIOD 24000
#define
EXT0_JAM_PIN -1
#define
EXT0_JAM_PULLUP 0
#define
EXT1_X_OFFSET 0
#define
EXT1_Y_OFFSET 0
#define
EXT1_Z_OFFSET 0
#define
EXT1_STEPS_PER_MM 370
#define
EXT1_TEMPSENSOR_TYPE 1
#define
EXT1_TEMPSENSOR_PIN TEMP_2_PIN
#define
EXT1_HEATER_PIN HEATER_2_PIN
#define
EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define
EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define
EXT1_INVERSE 0
#define
EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define
EXT1_ENABLE_ON 0
#define
EXT1_MIRROR_STEPPER 1
#define
EXT1_STEP2_PIN ORIG_E0_STEP_PIN
#define
EXT1_DIR2_PIN ORIG_E0_DIR_PIN
#define
EXT1_INVERSE2 0
#define
EXT1_ENABLE2_PIN ORIG_E0_ENABLE_PIN
#define
EXT1_MAX_FEEDRATE 40
#define
EXT1_MAX_START_FEEDRATE 20
#define
EXT1_MAX_ACCELERATION 3000
#define
EXT1_HEAT_MANAGER 3
#define
EXT1_PREHEAT_TEMP 230
#define
EXT1_WATCHPERIOD 1
#define
EXT1_PID_INTEGRAL_DRIVE_MAX 230
#define
EXT1_PID_INTEGRAL_DRIVE_MIN 40
#define
EXT1_PID_PGAIN_OR_DEAD_TIME 7
#define
EXT1_PID_I 2
#define
EXT1_PID_D 40
#define
EXT1_PID_MAX 255
#define
EXT1_ADVANCE_K 0
#define
EXT1_ADVANCE_L 0
#define
EXT1_ADVANCE_BACKLASH_STEPS 0
#define
EXT1_WAIT_RETRACT_TEMP 150
#define
EXT1_WAIT_RETRACT_UNITS 0
#define
EXT1_SELECT_COMMANDS ""
#define
EXT1_DESELECT_COMMANDS ""
#define
EXT1_EXTRUDER_COOLER_PIN -1
#define
EXT1_EXTRUDER_COOLER_SPEED 255
#define
EXT1_DECOUPLE_TEST_PERIOD 24000
#define
EXT1_JAM_PIN -1
#define
EXT1_JAM_PULLUP 0
#define
FEATURE_RETRACTION 1
#define
AUTORETRACT_ENABLED 0
#define
RETRACTION_LENGTH 3
#define
RETRACTION_LONG_LENGTH 13
#define
RETRACTION_SPEED 40
#define
RETRACTION_Z_LIFT 0
#define
RETRACTION_UNDO_EXTRA_LENGTH 0
#define
RETRACTION_UNDO_EXTRA_LONG_LENGTH 0
#define
RETRACTION_UNDO_SPEED 20
#define
FILAMENTCHANGE_X_POS 0
#define
FILAMENTCHANGE_Y_POS 0
#define
FILAMENTCHANGE_Z_ADD 2
#define
FILAMENTCHANGE_REHOME 1
#define
FILAMENTCHANGE_SHORTRETRACT 5
#define
FILAMENTCHANGE_LONGRETRACT 50
#define
JAM_METHOD 1
#define
JAM_STEPS 220
#define
JAM_SLOWDOWN_STEPS 320
#define
JAM_SLOWDOWN_TO 70
#define
JAM_ERROR_STEPS 500
#define
JAM_MIN_STEPS 10
#define
JAM_ACTION 1
#define
RETRACT_DURING_HEATUP true
#define
PID_CONTROL_RANGE 20
#define
SKIP_M109_IF_WITHIN 2
#define
SCALE_PID_TO_MAX 0
#define
TEMP_HYSTERESIS 2
#define
EXTRUDE_MAXLENGTH 160
#define
NUM_TEMPS_USERTHERMISTOR0 0
#define
USER_THERMISTORTABLE0 {}
#define
NUM_TEMPS_USERTHERMISTOR1 0
#define
USER_THERMISTORTABLE1 {}
#define
NUM_TEMPS_USERTHERMISTOR2 0
#define
USER_THERMISTORTABLE2 {}
#define
GENERIC_THERM_VREF 5
#define
GENERIC_THERM_NUM_ENTRIES 33
#define
HEATER_PWM_SPEED 0
#define
COOLER_PWM_SPEED 0
############# Heated bed configuration ########################
#define
HAVE_HEATED_BED 1
#define
HEATED_BED_PREHEAT_TEMP 75
#define
HEATED_BED_MAX_TEMP 135
#define
SKIP_M190_IF_WITHIN 3
#define
HEATED_BED_SENSOR_TYPE 1
#define
HEATED_BED_SENSOR_PIN TEMP_1_PIN
#define
HEATED_BED_HEATER_PIN HEATER_1_PIN
#define
HEATED_BED_SET_INTERVAL 5000
#define
HEATED_BED_HEAT_MANAGER 0
#define
HEATED_BED_PID_INTEGRAL_DRIVE_MAX 255
#define
HEATED_BED_PID_INTEGRAL_DRIVE_MIN 80
#define
HEATED_BED_PID_PGAIN_OR_DEAD_TIME 196
#define
HEATED_BED_PID_IGAIN 33
#define
HEATED_BED_PID_DGAIN 290
#define
HEATED_BED_PID_MAX 255
#define
HEATED_BED_DECOUPLE_TEST_PERIOD 300000
#define
MIN_EXTRUDER_TEMP 180
#define
MAXTEMP 275
#define
MIN_DEFECT_TEMPERATURE -10
#define
MAX_DEFECT_TEMPERATURE 290
#define
MILLISECONDS_PREHEAT_TIME 30000
## Laser configuration
If
the firmware is in laser mode, it can control a laser output to cut
or engrave materials.
Please
use this feature only if you know about safety and required
protection. Lasers are
dangerous
and can hurt or make you blind!!!
The
default laser driver only supports laser on and off. Here you control
the intensity with
your
feedrate. For exchangeable diode lasers this is normally enough. If
you need more control
you
can set the intensity in a range 0-255 with a custom extension to the
driver. See driver.h
and
comments on how to extend the functions non invasive with our event
system.
If
you have a laser - powder system you will like your E override. If
moves contain a
increasing
extruder position it will laser that move. With this trick you can
use
existing fdm slicers to laser the output. Laser width is extrusion
width.
Other
tools may use M3 and M5 to enable/disable laser. Here G1/G2/G3 moves
have laser enabled
and
G0 moves have it disables.
In
any case, laser only enables while moving. At the end of a move it
gets
automatically
disabled.
#define
SUPPORT_LASER 0
#define
LASER_PIN -1
#define
LASER_ON_HIGH 1
#define
LASER_WARMUP_TIME 0
#define
LASER_PWM_MAX 255
#define
LASER_WATT 2
## CNC configuration
If
the firmware is in CNC mode, it can control a mill with M3/M4/M5. It
works
similar
to laser mode, but mill keeps enabled during G0 moves and it allows
setting
rpm (only with event extension that supports this) and milling
direction.
It
also can add a delay to wait for spindle to run on full speed.
/</span>
#define
SUPPORT_CNC 0
#define
CNC_WAIT_ON_ENABLE 300
#define
CNC_WAIT_ON_DISABLE 0
#define
CNC_ENABLE_PIN -1
#define
CNC_ENABLE_WITH 1
#define
CNC_DIRECTION_PIN -1
#define
CNC_DIRECTION_CW 1
#define
CNC_PWM_MAX 255
#define
CNC_RPM_MAX 8000
#define
CNC_SAFE_Z 150
#define
DEFAULT_PRINTER_MODE 0
################ Endstop configuration #####################
#define
MULTI_ZENDSTOP_HOMING 0
#define
ENDSTOP_PULLUP_X_MIN true
#define
ENDSTOP_X_MIN_INVERTING true
#define
MIN_HARDWARE_ENDSTOP_X true
#define
ENDSTOP_PULLUP_Y_MIN true
#define
ENDSTOP_Y_MIN_INVERTING true
#define
MIN_HARDWARE_ENDSTOP_Y true
#define
ENDSTOP_PULLUP_Z_MIN true
#define
ENDSTOP_Z_MIN_INVERTING true
#define
MIN_HARDWARE_ENDSTOP_Z true
#define
ENDSTOP_PULLUP_Z2_MINMAX true
#define
ENDSTOP_Z2_MINMAX_INVERTING false
#define
MINMAX_HARDWARE_ENDSTOP_Z2 false
#define
ENDSTOP_PULLUP_X_MAX true
#define
ENDSTOP_X_MAX_INVERTING false
#define
MAX_HARDWARE_ENDSTOP_X false
#define
ENDSTOP_PULLUP_Y_MAX true
#define
ENDSTOP_Y_MAX_INVERTING false
#define
MAX_HARDWARE_ENDSTOP_Y false
#define
ENDSTOP_PULLUP_Z_MAX true
#define
ENDSTOP_Z_MAX_INVERTING false
#define
MAX_HARDWARE_ENDSTOP_Z false
#define
ENDSTOP_PULLUP_X2_MIN true
#define
ENDSTOP_PULLUP_Y2_MIN true
#define
#define
ENDSTOP_PULLUP_X2_MAX true
#define
ENDSTOP_PULLUP_Y2_MAX true
#define
ENDSTOP_X2_MIN_INVERTING false
#define
ENDSTOP_Y2_MIN_INVERTING false
#define
ENDSTOP_X2_MAX_INVERTING false
#define
ENDSTOP_Y2_MAX_INVERTING false
#define
MIN_HARDWARE_ENDSTOP_X2 false
#define
MIN_HARDWARE_ENDSTOP_Y2 false
#define
MAX_HARDWARE_ENDSTOP_X2 false
#define
MAX_HARDWARE_ENDSTOP_Y2 false
#define
X2_MIN_PIN -1
#define
X2_MAX_PIN -1
#define
Y2_MIN_PIN -1
#define
Y2_MAX_PIN -1
#define
Z2_MINMAX_PIN -1
#define
max_software_endstop_r true
#define
min_software_endstop_x false
#define
min_software_endstop_y false
#define
min_software_endstop_z false
#define
max_software_endstop_x true
#define
max_software_endstop_y true
#define
max_software_endstop_z true
#define
DOOR_PIN -1
#define
DOOR_PULLUP 1
#define
DOOR_INVERTING 1
#define
ENDSTOP_X_BACK_MOVE 5
#define
ENDSTOP_Y_BACK_MOVE 5
#define
ENDSTOP_Z_BACK_MOVE 2
#define
ENDSTOP_X_RETEST_REDUCTION_FACTOR 3
#define
ENDSTOP_Y_RETEST_REDUCTION_FACTOR 3
#define
ENDSTOP_Z_RETEST_REDUCTION_FACTOR 3
#define
ENDSTOP_X_BACK_ON_HOME 1
#define
ENDSTOP_Y_BACK_ON_HOME 1
#define
ENDSTOP_Z_BACK_ON_HOME 0
#define
ALWAYS_CHECK_ENDSTOPS 1
#define
MOVE_X_WHEN_HOMED 1
#define
MOVE_Y_WHEN_HOMED 1
#define
MOVE_Z_WHEN_HOMED 1
################# XYZ movements ###################
#define
X_ENABLE_ON 0
#define
Y_ENABLE_ON 0
#define
Z_ENABLE_ON 0
#define
DISABLE_X 0
#define
DISABLE_Y 0
#define
DISABLE_Z 0
#define
DISABLE_E 0
#define
INVERT_X_DIR 0
#define
INVERT_X2_DIR 0
#define
INVERT_Y_DIR 0
#define
INVERT_Y2_DIR 0
#define
INVERT_Z_DIR 0
#define
INVERT_Z2_DIR 0
#define
INVERT_Z3_DIR 0
#define
INVERT_Z4_DIR 0
#define
X_HOME_DIR -1
#define
Y_HOME_DIR -1
#define
Z_HOME_DIR -1
#define
X_MAX_LENGTH 324
#define
Y_MAX_LENGTH 195
#define
Z_MAX_LENGTH 420
#define
X_MIN_POS 0
#define
Y_MIN_POS 0
#define
Z_MIN_POS 0
#define
PARK_POSITION_X 0
#define
PARK_POSITION_Y 5
#define
PARK_POSITION_Z_RAISE 5
#define
DISTORTION_CORRECTION 0
#define
DISTORTION_CORRECTION_POINTS 5
#define
DISTORTION_LIMIT_TO 2
#define
DISTORTION_CORRECTION_R 100
#define
DISTORTION_PERMANENT 1
#define
DISTORTION_UPDATE_FREQUENCY 15
#define
DISTORTION_START_DEGRADE 0.5
#define
DISTORTION_END_HEIGHT 1
#define
DISTORTION_EXTRAPOLATE_CORNERS 0
#define
DISTORTION_XMIN 10
#define
DISTORTION_YMIN 10
#define
DISTORTION_XMAX 190
#define
DISTORTION_YMAX 190
## Movement settings
#define
FEATURE_BABYSTEPPING 1
#define
BABYSTEP_MULTIPLICATOR 1
#define
DELTA_SEGMENTS_PER_SECOND_PRINT 180 // Move accurate setting for
print moves
#define
DELTA_SEGMENTS_PER_SECOND_MOVE 70 // Less accurate setting for other
moves
#define
EXACT_DELTA_MOVES 1
Delta settings
#define
DELTA_HOME_ON_POWER 0
#define
DELTASEGMENTS_PER_PRINTLINE 20
#define
STEPPER_INACTIVE_TIME 360L
#define
MAX_INACTIVE_TIME 0L
#define
MAX_FEEDRATE_X 400
#define
MAX_FEEDRATE_Y 400
#define
MAX_FEEDRATE_Z 10
#define
HOMING_FEEDRATE_X 50
#define
HOMING_FEEDRATE_Y 50
#define
HOMING_FEEDRATE_Z 0.05
#define
HOMING_ORDER HOME_ORDER_YXZ
#define
ZHOME_PRE_RAISE 0
#define
ZHOME_PRE_RAISE_DISTANCE 5
#define
RAISE_Z_ON_TOOLCHANGE 0
#define
ZHOME_MIN_TEMPERATURE 0
#define
ZHOME_HEAT_ALL 1
#define
ZHOME_HEAT_HEIGHT 5
#define
ZHOME_X_POS 999999
#define
ZHOME_Y_POS 999999
#define
ENABLE_BACKLASH_COMPENSATION 0
#define
X_BACKLASH 0
#define
Y_BACKLASH 0
#define
Z_BACKLASH 0
#define
RAMP_ACCELERATION 1
#define
STEPPER_HIGH_DELAY 0
#define
DIRECTION_DELAY 0
#define
STEP_DOUBLER_FREQUENCY 12000
#define
ALLOW_QUADSTEPPING 1
#define
DOUBLE_STEP_DELAY 0 // time in microseconds
#define
MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000
#define
MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1000
#define
MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
#define
MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000
#define
MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1000
#define
MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
#define
INTERPOLATE_ACCELERATION_WITH_Z 0
#define
ACCELERATION_FACTOR_TOP 100
#define
MAX_JERK 20
#define
MAX_ZJERK 0.3
#define
PRINTLINE_CACHE_SIZE 16
#define
MOVE_CACHE_LOW 10
#define
LOW_TICKS_PER_MOVE 250000
#define
EXTRUDER_SWITCH_XY_SPEED 100
#define
DUAL_X_AXIS 0
#define
DUAL_X_RESOLUTION 0
#define
X2AXIS_STEPS_PER_MM 100
#define
FEATURE_TWO_XSTEPPER 0
#define
X2_STEP_PIN ORIG_E1_STEP_PIN
#define
X2_DIR_PIN ORIG_E1_DIR_PIN
#define
X2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define
FEATURE_TWO_YSTEPPER 0
#define
Y2_STEP_PIN ORIG_E1_STEP_PIN
#define
Y2_DIR_PIN ORIG_E1_DIR_PIN
#define
Y2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define
FEATURE_TWO_ZSTEPPER 1
#define
Z2_STEP_PIN ORIG_E1_STEP_PIN
#define
Z2_DIR_PIN ORIG_E1_DIR_PIN
#define
Z2_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define
FEATURE_THREE_ZSTEPPER 0
#define
Z3_STEP_PIN ORIG_E2_STEP_PIN
#define
Z3_DIR_PIN ORIG_E2_DIR_PIN
#define
Z3_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define
FEATURE_FOUR_ZSTEPPER 0
#define
Z4_STEP_PIN ORIG_E3_STEP_PIN
#define
Z4_DIR_PIN ORIG_E3_DIR_PIN
#define
Z4_ENABLE_PIN ORIG_E3_ENABLE_PIN
#define
FEATURE_DITTO_PRINTING 1
#define
USE_ADVANCE 0
#define
ENABLE_QUADRATIC_ADVANCE 0
################# Misc. settings ##################
#define
BAUDRATE 250000
#define
ENABLE_POWER_ON_STARTUP 1
#define
POWER_INVERTING 0
#define
AUTOMATIC_POWERUP 0
#define
KILL_METHOD 1
#define
ACK_WITH_LINENUMBER 1
#define
KEEP_ALIVE_INTERVAL 2000
#define
WAITING_IDENTIFIER "wait"
#define
ECHO_ON_EXECUTE 1
#define
EEPROM_MODE 1
#undef
PS_ON_PIN
#define
PS_ON_PIN ORIG_PS_ON_PIN
#define
JSON_OUTPUT 0
======== Servos =======
Control
the servos with
M340
P<servoId> S<pulseInUS> / ServoID = 0..3 pulseInUs =
500..2500
Servos
are controlled by a pulse width normally between 500 and 2500 with
1500ms in center position. 0 turns servo off.
WARNING:
Servos can draw a considerable amount of current. Make sure your
system can handle this or you may risk your hardware!
#define
FEATURE_SERVO 0
#define
SERVO0_PIN 11
#define
SERVO1_PIN -1
#define
SERVO2_PIN -1
#define
SERVO3_PIN -1
#define
SERVO0_NEUTRAL_POS -1
#define
SERVO1_NEUTRAL_POS -1
#define
SERVO2_NEUTRAL_POS -1
#define
SERVO3_NEUTRAL_POS -1
#define
UI_SERVO_CONTROL 0
#define
FAN_KICKSTART_TIME 200
#define
MAX_FAN_PWM 255
#define
FEATURE_WATCHDOG 1
#################### Z-Probing #####################
#define
Z_PROBE_Z_OFFSET 0
#define
Z_PROBE_Z_OFFSET_MODE 0
#define
UI_BED_COATING 1
#define
FEATURE_Z_PROBE 0
#define
EXTRUDER_IS_Z_PROBE 0
#define
Z_PROBE_DISABLE_HEATERS 0
#define
Z_PROBE_BED_DISTANCE 10
#define
Z_PROBE_PIN -1
#define
Z_PROBE_PULLUP 0
#define
Z_PROBE_ON_HIGH 0
#define
Z_PROBE_X_OFFSET 0
#define
Z_PROBE_Y_OFFSET 0
#define
Z_PROBE_WAIT_BEFORE_TEST 0
#define
Z_PROBE_SPEED 2
#define
Z_PROBE_XY_SPEED 150
#define
Z_PROBE_SWITCHING_DISTANCE 1
#define
Z_PROBE_REPETITIONS 1
#define
Z_PROBE_USE_MEDIAN 0
#define
Z_PROBE_HEIGHT 40
#define
Z_PROBE_DELAY 0
#define
Z_PROBE_START_SCRIPT ""
#define
Z_PROBE_FINISHED_SCRIPT ""
#define
Z_PROBE_RUN_AFTER_EVERY_PROBE ""
#define
Z_PROBE_REQUIRES_HEATING 0
#define
Z_PROBE_MIN_TEMPERATURE 150
#define
FEATURE_AUTOLEVEL 0
#define
FEATURE_SOFTWARE_LEVELING 0
#define
Z_PROBE_X1 20
#define
Z_PROBE_Y1 20
#define
Z_PROBE_X2 160
#define
Z_PROBE_Y2 20
#define
Z_PROBE_X3 20
#define
Z_PROBE_Y3 160
#define
BED_LEVELING_METHOD 0
#define
BED_CORRECTION_METHOD 0
#define
BED_LEVELING_GRID_SIZE 5
#define
BED_LEVELING_REPETITIONS 5
#define
BED_MOTOR_1_X 0
#define
BED_MOTOR_1_Y 0
#define
BED_MOTOR_2_X 200
#define
BED_MOTOR_2_Y 0
#define
BED_MOTOR_3_X 100
#define
BED_MOTOR_3_Y 200
#define
BENDING_CORRECTION_A 0
#define
BENDING_CORRECTION_B 0
#define
BENDING_CORRECTION_C 0
#define
FEATURE_AXISCOMP 0
#define
AXISCOMP_TANXY 0
#define
AXISCOMP_TANYZ 0
#define
AXISCOMP_TANXZ 0
#ifndef
SDSUPPORT // Some boards have sd support on board. These define the
values already in pins.h
#define
SDSUPPORT 0
#undef
SDCARDDETECT
#define
SDCARDDETECT -1
#undef
SDCARDDETECTINVERTED
#define
SDCARDDETECTINVERTED 0
#endif
#define
SD_EXTENDED_DIR 1 /** Show extended directory including file length.
Don't use this with Pronterface! /
#define
SD_RUN_ON_STOP ""
#define
SD_STOP_HEATER_AND_MOTORS_ON_STOP 1
#define
ARC_SUPPORT 1
#define
FEATURE_MEMORY_POSITION 1
#define
FEATURE_CHECKSUM_FORCED 0
#define
FEATURE_FAN_CONTROL 1
#define
FEATURE_FAN2_CONTROL 1
#define
FEATURE_CONTROLLER 0
#define
ADC_KEYPAD_PIN -1
#define
LANGUAGE_EN_ACTIVE 1
#define
LANGUAGE_DE_ACTIVE 1
#define
LANGUAGE_NL_ACTIVE 0
#define
LANGUAGE_PT_ACTIVE 1
#define
LANGUAGE_IT_ACTIVE 1
#define
LANGUAGE_ES_ACTIVE 1
#define
LANGUAGE_FI_ACTIVE 0
#define
LANGUAGE_SE_ACTIVE 0
#define
LANGUAGE_FR_ACTIVE 1
#define
LANGUAGE_CZ_ACTIVE 0
#define
LANGUAGE_PL_ACTIVE 1
#define
LANGUAGE_TR_ACTIVE 1
#define
UI_PRINTER_NAME "RepRap"
#define
UI_PRINTER_COMPANY "Home made"
#define
UI_PAGES_DURATION 4000
#define
UI_SPEEDDEPENDENT_POSITIONING 0
#define
UI_DISABLE_AUTO_PAGESWITCH 1
#define
UI_AUTORETURN_TO_MENU_AFTER 30000
#define
FEATURE_UI_KEYS 0
#define
UI_ENCODER_SPEED 1
#define
UI_REVERSE_ENCODER 0
#define
UI_KEY_BOUNCETIME 10
#define
UI_KEY_FIRST_REPEAT 500
#define
UI_KEY_REDUCE_REPEAT 50
#define
UI_KEY_MIN_REPEAT 50
#define
FEATURE_BEEPER 0
#define
CASE_LIGHTS_PIN -1
#define
CASE_LIGHT_DEFAULT_ON 1
#define
UI_START_SCREEN_DELAY 1000
#define
UI_DYNAMIC_ENCODER_SPEED 1
Beeper
sound definitions for short beeps during key actions
and
longer beeps for important actions.
Parameter
is delay in microseconds and the secons is the number of repetitions.
Values
must be in range 1..255
/</span>
#define
BEEPER_SHORT_SEQUENCE 2,2
#define
BEEPER_LONG_SEQUENCE 8,8
#define
UI_SET_MIN_HEATED_BED_TEMP 30
#define
UI_SET_MAX_HEATED_BED_TEMP 120
#define
UI_SET_MIN_EXTRUDER_TEMP 170
#define
UI_SET_MAX_EXTRUDER_TEMP 260
#define
UI_SET_EXTRUDER_FEEDRATE 2
#define
UI_SET_EXTRUDER_RETRACT_DISTANCE 3
#define
NUM_MOTOR_DRIVERS 0
#endif
