Captured this earlier today as part or the crash. More info (the full crashlog) is available if desired. Potentially the stack size needs to be increased.
ProblemType: Crash
Architecture: amd64
CrashCounter: 1
CurrentDesktop: Unity
Date: Sat Apr 18 10:55:20 2015
DistroRelease: Ubuntu 14.04
ExecutablePath: /usr/bin/mono-sgen
ExecutableTimestamp: 1426882905
ProcCmdline: mono RepetierHost.exe -home
7fa811988000-7fa8119c4000 r-xp 00000000 08:07 426310 /usr/lib/libMonoPosixHelper.so
7fa8119c4000-7fa811bc3000 ---p 0003c000 08:07 426310 /usr/lib/libMonoPosixHelper.so
7fa811bc3000-7fa811bc4000 r--p 0003b000 08:07 426310 /usr/lib/libMonoPosixHelper.so
7fa811bc4000-7fa811bc5000 rw-p 0003c000 08:07 426310 /usr/lib/libMonoPosixHelper.so
InstallationMedia: Ubuntu 14.04.1 LTS "Trusty Tahr" - Release amd64 (20140722.2)
Package: mono-runtime-sgen 3.2.8+dfsg-4ubuntu1.1
PackageArchitecture: amd64
ProcVersionSignature: Ubuntu 3.13.0-49.83-generic 3.13.11-ckt17
SegvAnalysis:
Segfault happened at: 0x7fa834cf8688: cmpb $0x48,(%rdx)
PC (0x7fa834cf8688) ok
source "$0x48" ok
destination "(%rdx)" (0x7fa8368e23) not located in a known VMA region (needed writable region)!
Stack memory exhausted (SP below stack segment)
SegvReason: writing unknown VMA
SourcePackage: mono
Stacktrace:
#0 0x00007fa834cf8688 in ?? () from /lib/x86_64-linux-gnu/libgcc_s.so.1
No symbol table info available.
#1 0x00007fa834cf96f8 in Unwind_Backtrace () from /lib/x86_64-linux-gnu/libgcc_s.so.1
#2 0x00007fa84877de26 in GIbacktrace (array=array@entry=0x7fa8494841a0, size=size@entry=256) at ../sysdeps/x86_64/backtrace.c:109
arg = {array = 0x7fa8494841a0, cfa = 140360760707776, cnt = 4, size = 256}
once = 2
#3 0x00000000004b73d8 in mono_handle_native_sigsegv (signal=signal@entry=11, ctx=ctx@entry=0x7fa849484ac0) at mini-exceptions.c:2268
array = {0x4b73d8 <mono_handle_native_sigsegv+200>, 0x50f13b <mono_arch_handle_altstack_exception+187>, 0x423d22 <mono_sigsegv_signal_handler+242>, 0x7fa848a48340 <restore_rt>, 0x0 <repeats 227 times>, 0x5a6fb3 <jit_info_table_chunk_index+83>, 0x0, 0x7fa84950d048, 0x7fa8368e23, 0x149, 0x5ab0a00, 0x1, 0x7fa84738bc48, 0x5a7070 <jit_info_table_find+112>, 0x0, 0x15800000000, 0x0, 0x7fa84950d048, 0x27872d0, 0x7fa8368e23, 0x27872d0, 0x1, 0x7fa84738bc48, 0x5a7da0 <mono_jit_info_table_find_internal+64>, 0x0, 0x27872d0, 0x0, 0x7fa8368e23, 0x7fa845fd02e0, 0x4b45e5 <mini_jit_info_table_find+101>}
names = <optimized out>
i = <optimized out>
size = <optimized out>
sa = {sigaction_handler = {sa_handler = 0x4b73d8 <mono_handle_native_sigsegv+200>, sa_sigaction = 0x4b73d8 <mono_handle_native_sigsegv+200>}, sa_mask = {__val = {5304635, 4341026, 140360749974336, 0 <repeats 13 times>}}, sa_flags = 0, sa_restorer = 0x0}
jit_tls = 0x7fa82c0021f0
signal_str = 0x655436 "SIGSEGV"
#4 0x000000000050f13b in mono_arch_handle_altstack_exception (sigctx=sigctx@entry=0x7fa849484ac0, fault_addr=<optimized out>, stack_ovf=stack_ovf@entry=0) at exceptions-amd64.c:908
exc = <optimized out>
ctx = 0x7fa849484ac0
ji = 0x0
sp = <optimized out>
frame_size = <optimized out>
copied_ctx = <optimized out>
#5 0x0000000000423d22 in mono_sigsegv_signal_handler (_dummy=11, info=0x7fa849484bf0, context=0x7fa849484ac0) at mini.c:6769
ji = 0x0
fault_addr = <optimized out>
#6 <signal handler called>
No locals.
#7 0x0000007fa8368e23 in ?? ()
#8 0x0000000041295113 in ?? ()
#9 0x0000000000000000 in ?? ()
