swapsan I want to disable any manual movement until homing is done on my repetier server how can I do this ?
RAyWB you should do that in Firmware.in configuration.h#define MOVE_X_WHEN_HOMED 0#define MOVE_Y_WHEN_HOMED 0#define MOVE_Z_WHEN_HOMED 0change Value from 0 to 1 that should do the trick
Repetier Use dev version, that is 1.0.4 and has the potions. 1.0.3 is official stable and also has it.
