<font face="Arial, Verdana">In my previous test, I set the mixing_extruder to 0 and num_extruder to 1 at the same time, then the problem gone. So, I guess the problem caused by mixing extruder settings, but I was wrong. </font>
In my last test, I set the mixing_extruder to 0 in configure.h to disable mixing and then keep NUM_EXTRUDER to 2 such that it just same as a normal 2 extruders 2 nozzles config. Then the problem happened.
I can sure the configuration no problem because I using it in my printer for a long time. For single extruder, it's working fine. But when I set the NUM_EXTRUDER to 2, no matter the MIXING_EXTRUDER is 0 or 1, Both extruder motor will run slowly and same slow speed for any F value
Here is my configuration : https://www.dropbox.com/s/m1a48h4hh901igg/Configuration.h?dl=0</div><div style="font-family: Arial, Verdana; font-size: 10pt; font-style: normal; font-variant: normal; font-weight: normal; line-height: normal;">
Any suggestion I can try ?
