<my working directory>/CuraEngine/default/print that is the directory path to the config files for CuraEngine.
<my working directory> is replaced by the name of the working directory you have set up in preferences , whatever that might be.
I checked for the file locations by making a configuration file in CuraEngine and naming it snappy. Then I just searched for that file name in the search window on the main windows screen. In that subdirectory was the default.ini and the snappy.ini file.
I don't know what else to tell you.
