Hello I ‘ve
2 questions/problems to solve.
I want to
use Repetier Firmware to pilot an 3D printer for powder Laser.
I use an
MKS base V1.4 (normally fully compatible with an Arduino ATMega 2560 added Ramp
1.4). You can see the link for laser and MKS bellow
https://fr.aliexpress.com/item/High-quality-500mw-405NM-focusing-blue-purple-laser-module-laser-engraving-500mw-laser-tube-Laser-module/32704306836.html?spm=2114.13010708.0.0.13676c37pAWv7n
https://fr.aliexpress.com/item/3D-Printer-Control-Motherboard-MKS-BASE-V1-3-Compatible-RAMPS-1-4-Printer-Control-Reprap-MendelPrusa/32484708817.html?spm=2114.13010708.0.0.3a996c37SwMXrG
About movements,
everything it’s OK, it seems there’s no problem.
My problems
are the following:
To
managed powder’s hopper/reserve, I want to use electro magnet (5V) è on which pin can I connect it? What is the
command (G code) to control it? (it just work on/off)
Laser:
I used it on PWM mode (only on/off), I don’t need to adjust power. Actually it’s
connect on hotbed pin, but the result is not good because it do not work
normally, it seems to flash, it’s not work continuously.
It’s
seems to be lag with the top of the MKS and the laser (the LED of card is ever
lighted and laser work after, as there’s a delay).
Any Idea? What should I do?
