WIth Repetier Host V2.1.3 i get many errrors if i do G32
04:24:46.675 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:24:46.675 : {"callback_id":-1,"data":[{"data":{"id":16330,"text":"Z-probe:6.407 X:139.60 Y:19.99","time":" 4:24:46.360","type":4},"event":"log","printer":"Arnold"},{"data":{"id":16331,"text":"busy:processing","time":" 4:24:46.519","type":2},"event":"log","printer":"Arnold"}],"eventList":true}
04:24:46.675 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:24:46.675 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:24:46.675 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:24:46.675 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:24:46.675 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:24:51.584 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:24:51.584 : {"callback_id":-1,"data":[{"data":{"id":16337,"text":"busy:processing","time":" 4:24:50.521","type":2},"event":"log","printer":"Arnold"},{"data":{"id":16338,"text":"Z-probe:6.421 X:139.60 Y:55.99","time":" 4:24:51.042","type":4},"event":"log","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":25.600000381469727,"id":0,"t":1533867891255},"event":"temp","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":24.200000762939453,"id":-1,"t":1533867891255},"event":"temp","printer":"Arnold"},{"data":{"id":16339,"text":"T:25.61 /0 B:24.17 /0 B@:0 @:0","time":" 4:24:51.255","type":2},"event":"log","printer":"Arnold"}],"eventList":true}
04:24:51.584 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:24:51.584 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:24:51.584 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:24:51.584 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:24:51.584 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:24:55.966 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:24:55.966 : {"callback_id":-1,"data":[{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":25.700000762939453,"id":0,"t":1533867895650},"event":"temp","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":24.100000381469727,"id":-1,"t":1533867895650},"event":"temp","printer":"Arnold"},{"data":{"id":16345,"text":"T:25.73 /0 B:24.06 /0 B@:0 @:0","time":" 4:24:55.650","type":2},"event":"log","printer":"Arnold"},{"data":{"id":16346,"text":"Z-probe:6.456 X:139.60 Y:92.00","time":" 4:24:55.740","type":4},"event":"log","printer":"Arnold"}],"eventList":true}
04:24:55.966 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:24:55.966 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:24:55.967 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:24:55.967 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:24:55.967 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:25:01.415 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:25:01.415 : {"callback_id":-1,"data":[{"data":{"id":16353,"text":"Z-probe:6.503 X:139.60 Y:127.99","time":" 4:25:00.454","type":4},"event":"log","printer":"Arnold"},{"data":{"id":16354,"text":"busy:processing","time":" 4:25:00.528","type":2},"event":"log","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":25.600000381469727,"id":0,"t":1533867901146},"event":"temp","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":24.200000762939453,"id":-1,"t":1533867901146},"event":"temp","printer":"Arnold"},{"data":{"id":16355,"text":"T:25.61 /0 B:24.17 /0 B@:0 @:0","time":" 4:25:01.146","type":2},"event":"log","printer":"Arnold"}],"eventList":true}
04:25:01.415 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:25:01.415 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:25:01.415 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:25:01.415 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:25:01.415 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:25:05.785 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:25:05.785 : {"callback_id":-1,"data":[{"data":{"id":16361,"text":"Z-probe:6.571 X:139.60 Y:164.00","time":" 4:25:05.198","type":4},"event":"log","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":25.600000381469727,"id":0,"t":1533867905542},"event":"temp","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":24.100000381469727,"id":-1,"t":1533867905542},"event":"temp","printer":"Arnold"},{"data":{"id":16362,"text":"T:25.61 /0 B:24.06 /0 B@:0 @:0","time":" 4:25:05.542","type":2},"event":"log","printer":"Arnold"}],"eventList":true}
04:25:05.785 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:25:05.785 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:25:05.785 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:25:05.785 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:25:05.785 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:25:10.153 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:25:10.153 : {"callback_id":-1,"data":[{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":25.600000381469727,"id":0,"t":1533867909937},"event":"temp","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":24.100000381469727,"id":-1,"t":1533867909937},"event":"temp","printer":"Arnold"},{"data":{"id":16368,"text":"T:25.61 /0 B:24.06 /0 B@:0 @:0","time":" 4:25:09.937","type":2},"event":"log","printer":"Arnold"},{"data":{"id":16369,"text":"Z-probe:6.633 X:139.60 Y:199.99","time":" 4:25:09.962","type":4},"event":"log","printer":"Arnold"}],"eventList":true}
04:25:10.153 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:25:10.153 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:25:10.153 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:25:10.153 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:25:10.153 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:25:17.792 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:25:17.792 : {"callback_id":-1,"data":[{"data":{"id":16380,"text":"Z-probe:6.455 X:171.99 Y:19.99","time":" 4:25:17.601","type":4},"event":"log","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":25.600000381469727,"id":0,"t":1533867917630},"event":"temp","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":24.200000762939453,"id":-1,"t":1533867917630},"event":"temp","printer":"Arnold"},{"data":{"id":16381,"text":"T:25.61 /0 B:24.17 /0 B@:0 @:0","time":" 4:25:17.630","type":2},"event":"log","printer":"Arnold"}],"eventList":true}
04:25:17.792 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:25:17.792 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:25:17.792 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:25:17.792 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:25:17.792 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:25:23.254 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:25:23.254 : {"callback_id":-1,"data":[{"data":{"id":16388,"text":"Z-probe:6.442 X:171.99 Y:55.99","time":" 4:25:22.291","type":4},"event":"log","printer":"Arnold"},{"data":{"id":16389,"text":"busy:processing","time":" 4:25:22.549","type":2},"event":"log","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":25.600000381469727,"id":0,"t":1533867923127},"event":"temp","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":24.100000381469727,"id":-1,"t":1533867923127},"event":"temp","printer":"Arnold"},{"data":{"id":16390,"text":"T:25.61 /0 B:24.06 /0 B@:0 @:0","time":" 4:25:23.127","type":2},"event":"log","printer":"Arnold"}],"eventList":true}
04:25:23.254 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:25:23.254 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:25:23.254 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:25:23.254 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:25:23.254 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:25:27.620 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:25:27.620 : {"callback_id":-1,"data":[{"data":{"id":16395,"text":"busy:processing","time":" 4:25:26.551","type":2},"event":"log","printer":"Arnold"},{"data":{"id":16396,"text":"Z-probe:6.452 X:171.99 Y:92.00","time":" 4:25:26.989","type":4},"event":"log","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":25.600000381469727,"id":0,"t":1533867927522},"event":"temp","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":24.100000381469727,"id":-1,"t":1533867927522},"event":"temp","printer":"Arnold"},{"data":{"id":16397,"text":"T:25.61 /0 B:24.06 /0 B@:0 @:0","time":" 4:25:27.522","type":2},"event":"log","printer":"Arnold"}],"eventList":true}
04:25:27.620 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:25:27.620 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:25:27.620 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:25:27.620 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:25:27.620 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:25:31.991 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:25:31.991 : {"callback_id":-1,"data":[{"data":{"id":16403,"text":"Z-probe:6.503 X:171.99 Y:127.99","time":" 4:25:31.704","type":4},"event":"log","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":25.600000381469727,"id":0,"t":1533867931917},"event":"temp","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":24.200000762939453,"id":-1,"t":1533867931917},"event":"temp","printer":"Arnold"},{"data":{"id":16404,"text":"T:25.61 /0 B:24.17 /0 B@:0 @:0","time":" 4:25:31.917","type":2},"event":"log","printer":"Arnold"}],"eventList":true}
04:25:31.991 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:25:31.991 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:25:31.991 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:25:31.991 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:25:31.991 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:25:37.449 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:25:37.450 : {"callback_id":-1,"data":[{"data":{"id":16411,"text":"Z-probe:6.548 X:171.99 Y:164.00","time":" 4:25:36.439","type":4},"event":"log","printer":"Arnold"},{"data":{"id":16412,"text":"busy:processing","time":" 4:25:36.558","type":2},"event":"log","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":25.500000000000000,"id":0,"t":1533867937414},"event":"temp","printer":"Arnold"},{"data":{"O":0.00000000000000000,"S":0.00000000000000000,"T":24.100000381469727,"id":-1,"t":1533867937414},"event":"temp","printer":"Arnold"},{"data":{"id":16413,"text":"T:25.49 /0 B:24.06 /0 B@:0 @:0","time":" 4:25:37.414","type":2},"event":"log","printer":"Arnold"}],"eventList":true}
04:25:37.450 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:25:37.450 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:25:37.450 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:25:37.450 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:25:37.450 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
04:25:41.270 : Exception during socket read:Der Index war außerhalb des Arraybereichs.
04:25:41.270 : {"callback_id":-1,"data":[{"data":{"id":16419,"text":"Z-probe:6.628 X:171.99 Y:199.99","time":" 4:25:41.203","type":4},"event":"log","printer":"Arnold"},{"data":{"id":16420,"text":"plane: a = 0.0019 b = 0.0020 c = 6.0138","time":" 4:25:41.208","type":4},"event":"log","printer":"Arnold"},{"data":{"id":16421,"text":"Transformation matrix: 0.999998 0.000000 -0.001873 -0.000004 0.999998 -0.001960 0.001873 0.001960 0.999996","time":" 4:25:41.216","type":4},"event":"log","printer":"Arnold"},{"data":{"id":16422,"text":"CurrentZ:6.01 atZ:5.90","time":" 4:25:41.220","type":4},"event":"log","printer":"Arnold"},{"data":{"id":16423,"text":"Info:Autoleveling enabled","time":" 4:25:41.224","type":4},"event":"log","printer":"Arnold"},{"data":{"id":16424,"text":"X:171.98 Y:199.99 Z:6.728 E:0.0000","time":" 4:25:41.224","type":4},"event":"log","printer":"Arnold"},{"data":{"id":16425,"text":"wait","time":" 4:25:41.224","type":2},"event":"log","printer":"Arnold"}],"eventList":true}
04:25:41.270 : bei RepetierHost.view.calibration.BedHeightMap.Answer(String text, LogLevel& level)
04:25:41.270 : bei RepetierHostExtender.interfaces.OnResponse.Invoke(String response, LogLevel& level)
04:25:41.270 : bei RepetierHost.model.PrinterConnection.analyzeResponse(String res, LogLevel& level)
04:25:41.270 : bei RepetierServerConnector.ServerConnector.AnalyzeResponse(String res)
04:25:41.270 : bei RepetierServerConnector.ServerConnector.WSReceive2(Object sender, MessageEventArgs e)
