So I've finally got my home built printer up and running. But I've run into an issue with the heated bed. I have it set to pre-heat to 60° C, but it overshoots and levels at 120° C. Here is my current setup:
Firmware - 1.0.3 Dev
Controller - RADDS 1.5
Bed Heater - 750w@110v controlled via SSR
Bed Thermister - NTC 100K 3950
Initial Firmware Settings:
#define HAVE_HEATED_BED 1
#define HEATED_BED_PREHEAT_TEMP 60
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
It doesn't matter if I pre-heat from the RADDS display or Octoprint. Either way it heats to, and stays around max temp.
I tried lowering the max temp to 60° C using the following settings:
#define HEATED_BED_MAX_TEMP 60
#define MAXTEMP 275
With these settings, the bed hits around 70° C and then generates a sensor error.
At room temperature, I'm seeing the following temps:
Room: 26.5° C
Enclosure: 27.6° C
HotEnd: 28.1° C
Bed: 28.4° C
