Now that I finally got Repetier up and running, I need a bit of help setting up a Z probe. so far I have it attached and wired, the led lights up as expected, but, it is not stopping, there are so many settings in there I get lost.
The probe is an IR probe.
Here is what I have set, I am sure it is all wrong ,but at least the printer still runs.
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 1.99
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 30
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define Z_PROBE_START_SCRIPT ""G32
#define Z_PROBE_FINISHED_SCRIPT "" G28 10
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 280
#define Z_PROBE_Y2 280
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 300
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 200
#define BED_MOTOR_3_Y 300
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
