sonam_18 Do we need to upload a start gcode and end gcode for the printer when it is newly built??And do we have to set different gcode for different model ???
Repetier Only if the default does match your wishes. Slic3r will then add a simpel defaultthat is not optimized.
sonam_18 Hmmm thank you so much for the help...well i was trying to calibrate my machine and then trying for the bed leveling and suddenly the x axis stopped in the mid point and it wont movehelp please
Repetier In such cases always use the console/log to see what is going on. Often fimrware tells you about a problem,
