Thank you Repetier for the reply :)
When i'm using G30, Z goes down, when i trigger Z probe, Z returns to the position he had before the G30, and when i start the job, the job starts at the current position, not where the Z probe was triggered.
I would like that works like a G28 Z, i would like that when i trigger Z-probe, Z axis stay where Z-probe was triggered, i remove the Z-probe, i start the job, and the end mill goes at the real 0 Z with a Z offset set at the probe thikness.
Is it possible ?
Thank you :)
