CS is chip select pin. You have that also in marlin. For the ST920 chip (which is what reprapdiscount graphic controler also uses) you need these pins set correctly
// SCK Pin: UI_DISPLAY_D4_PIN
// Mosi Pin: UI_DISPLAY_ENABLE_PIN
// CD Pin: UI_DISPLAY_RS_PINLeft is function right is which name gets it. Not very intutive I know, the firmware names come from charater displays and these had the right pin numbers for RRD display so we refunctioned them for u8glib.
// ST7920 with software SPI
#define U8GLIB_ST7920
// SSD1306 with software SPI
//#define U8GLIB_SSD1306_SW_SPI
// SH1106 with software SPI
// U8GLIB_SH1106_SW_SPI
// SSD1306 over I2C using hardware I2C pins
// #define U8GLIB_MINI12864_2X_SW_SPI
//#define U8GLIB_SSD1306_I2C
// For the 8 bit ks0108 display you need to set these pins
// UI_DISPLAY_D0_PIN,UI_DISPLAY_D1_PIN,UI_DISPLAY_D2_PIN,UI_DISPLAY_D3_PIN,UI_DISPLAY_D4_PIN,UI_DISPLAY_D5_PIN,UI_DISPLAY_D6_PIN,UI_DISPLAY_D7_PIN
// UI_DISPLAY_ENABLE_PIN,UI_DISPLAY_CS1,UI_DISPLAY_CS2,
// UI_DISPLAY_DI,UI_DISPLAY_RW_PIN,UI_DISPLAY_RESET_PIN
//#define U8GLIB_KS0108
//#define U8GLIB_KS0108_FAST
// UI_DISPLAY_RS_PIN = CS
// UI_DISPLAY_D5_PIN = A0
//#define U8GLIB_ST7565_NHD_C2832_HW_SPI
You may only use one of these defines. It tells u8glib which driver to use and that must match the midi display driver, which is why I asked. But your infos did not help here. U8GLIB_MINI12864_2X_SW_SPI might be the right from the name, but that is often misleading.
