I have been using Repetier on Windows for years. I just set up Repetier for Raspberry Pi and for some reason my printer definition is not square. If I print out a 100mm x 100mm square, the x axis is fine, but the y axis of the square comes out to be 110mm. It also crashes into the limits during the set up process when it goes to 0. I have a Printrbot simple metal.
In my printer definitions on Repetier server on the Pi I have the bed defined in the general tab with
X-min:0
Y-min:0
X-max:140
Y-max:140
X-home:0
Y-home:150
In the printer shape tab I have:
X left: 0
Y front: 0
X right:140
Y rear:140
On the Repetier- host definition for the printer I have:
X-min:0
Y-min:0
X-max:140
Y-max:140
print area width 140
print area depth 140
slicer definition bed shape:
size: x: 140 y:140
Origin x:0 y:0
My start G-code:
G28 ; home all axes
G29; auto level
G1 Z5 F5000 ; lift nozzle
M92 X80
M92 Y90
M92 Z2020
M92 E93.5
anyone have any ideas what I am doing wrong??? Thanks
