<font face="Arial, Verdana" size="2">The Mono Version is 3.2.8. This has .NET4 and .NET4.5</font>
Running Repetier Host from Command Line (repetierHost) ... this is the result ....
</font>
<font face="Arial, Verdana" size="2">(mono:2936): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-can-change-accels after class was initialised</font>
</font>
<font face="Arial, Verdana" size="2">(mono:2936): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-menu-popup-delay after class was initialised</font>
</font>
<font face="Arial, Verdana" size="2">(mono:2936): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-menu-popdown-delay after class was initialised</font>
Lot Of These (Showing Only Parts due to space Constraints)
<div style="font-family: Arial, Verdana; font-style: italic; font-weight: bold; line-height: normal;">X11 Error encountered:
Error: BadDrawable (invalid Pixmap or Window parameter)
Request: 14 (0)
Resource ID: 0x1400104
Serial: 6060
Hwnd: Hwnd, Mapped:True ClientWindow:0x1400104, WholeWindow:0x1400103, Zombie=False, Parent:[Hwnd, Mapped:True ClientWindow:0x14000C9, WholeWindow:0x14000C8,
Unhandled Exception:
System.ArgumentException: A null reference or invalid value was found [GDI+ status: InvalidParameter]
at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000] in <filename unknown>:0
at System.Drawing.Graphics.GdipMeasureString (IntPtr graphics, System.String text, System.Drawing.Font font, System.Drawing.RectangleF& layoutRect, IntPtr stringFormat) [0x00000] in <filename unknown>:0
at System.Drawing.Graphics.MeasureString (System.String text, System.Drawing.Font font, Int32 width, System.Drawing.StringFormat format) [0x00000] in <filename unknown>:0
at (wrapper remoting-invoke-with-check) System.Drawing.Graphics:MeasureString (string,System.Drawing.Font,int,System.Drawing.StringFormat)
</span></div>
