I am relatively new to 3D printing so apologies if I am asking simple questions, but I can't find answers using Google.
I have a 3DR Delta RepRap printer which I have inherited, so I do not know how it was built or which Arduino board it has on it. The Z Probe is absent, but if the nozzle hits the bed, it rises slightly and breaks a contact, which I assume achieves the same thing.
I am using Repetier host connected to a Raspberry Pi running Repetier server. The software is using Marlin Firmware - the other two do not work at all. I want to follow the instructions (https://youtu.be/L9URtv2LqKc) to level the bed as it is not right at the moment.
1) Do I need to have Repetier firmware on the printer's Arduino board for this to work properly? If not, can I do the same process using the Marlin firmware?
2) If so and I follow the guide on installing the firmware on the Repetier site, how do I know which Arduino board I have and if it will work?
Andrew
