In general set mode to expert mode or you will not see the options. Options are in mechanics tab.
Delay stepper high signalSTEPPER_HIGH_DELAY
[microseconds] Needed for gantry systems and due boards.
Delay stepper direction signalDIRECTION_DELAY
[microseconds] Needed only for slow stepper drivers.
are the fields you most likely need. Start with 1us as you get the extra delay from running code anyway. If you still loose steps increase to 2. Higher values reduce firmware speed so do never add more then required.
