Hello, ever since Repetier Host 2 came out, I havent been able to make it run on my windows 10 laptop. The little loading window opens up and then says that the application stopped working. It works fine on my windows 7 PC though. I've searched around and done some common fixes such as running sfc /scannow bu everything seems ok. This is the windows application error log:
Faulting application name: RepetierHost.exe, version: 1.0.0.0, time stamp: 0x597f4ac2
Faulting module name: KERNELBASE.dll, version: 10.0.16299.371, time stamp: 0x6369e29f
Exception code: 0xe0434352
Fault offset: 0x0000000000014008
Faulting process id: 0x16f0
Faulting application start time: 0x01d3d2a2b992484b
Faulting application path: C:\Program Files\Repetier-Host\RepetierHost.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: c0f36686-78f9-4b7b-8c40-1da4f2767ae4
Faulting package full name:
Faulting package-relative application ID:
Next to that error, it aways show a .NET error that says this:
Application: RepetierHost.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.ArgumentException
at System.ThrowHelper.ThrowArgumentException(System.ExceptionResource)
at System.Collections.Generic.Dictionary`2[[System.Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].Insert(System.Canon, System.Canon, Boolean)
at RepetierHost.Main..ctor()
at RepetierHost.Program.Main(System.String[])
The .NET framework version seems to be .NET Framework 4.7.1, according to the registry, as seen in this Microsoft guide https://docs.microsoft.com/en-us/dotnet/framework/migration-guide/how-to-determine-which-versions-are-installed<br/>Im not sure why the .NET error says v4.0.30319.
Any idea on how to fix it? Repetier Host 1.6.2 runs fine.
