Germin is ok:-)
It is a crash in the intel graphic driver. Not htat I'm surprised it is a intel card - seems what ever the problem is only affects intel cards:-(
Since it happens only with bigger objects, could it be a memory issure with graphic card memory exhausted? What level of detail are you using for gcode preview? Don't go higher then medium especially with bigger models.
If you select single layer preview, does it still happen with that object? Would need to go through all layers to test if one layer has a visualization error that causes the crash since we ruled out memory problems with only showing a single layer. If it is a single layer, please send the gcode and tell me the layer that crashes, maybe I can then find a error in visualization algorithm.
