Hello
Where do I set the preheat temp to 0?
On the other hand... It does not work.
I have plugged the sensor to the Zmin, and assigned the z probe pin to the z min pin. Then, when I tell the printer to home Z, It homes X, Y, and beging moving z in a strange way:
-It lowers Z a little
- It rises Z by some cm
-Then it begins lowering Z
And it stops where the Z axis was when I turned on the printer, (where repetier thinks the Z=0 is). It does not lower the Z until it finds an endstop,without using the Sensor.
I am missing someting?
thanks
