Hello,
I've been updating my old Hesine M505 (I3 clone) and wanted to add a spare BLTOUCH.
My bltouch work and nearly everything work fine except some essential feature :
when I hit home X or Y button, it goes to mecanical endstop then add the offset of the nozzle so everything fine
but when I hit home Z, X move in the X wrong direction from a few mm (offset is X -30 Y -15 and also in the eeprom)
for home all it's even worse : x goes to zero without adding offset, Y does the same and the BLTOUCH start the probing process far from the bed...
What can I do to correct this ?
