along with Repetier-Firmware. If not, see <http://www.gnu.org/licenses/>.</div><div><br/></div><div>*/</div><div><br/></div><div>#ifndef CONFIGURATION_H
#define CONFIGURATION_H
/**************** READ FIRST *********************
generator: http://www.repetier.com/firmware/v092/</div><div><br/></div><div> If you are in doubt which named functions use which pins on your board, please check the
as you expect.
#define NUM_EXTRUDER 2
#define MOTHERBOARD 402
#define RFSERIAL Serial
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 1280
#define YAXIS_STEPS_PER_MM 1280
#define ZAXIS_STEPS_PER_MM 6400
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define KILL_IF_SENSOR_DEFECT 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET -11520
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 320
#define EXT0_STEP_PIN ORIG_E1_STEP_PIN
#define EXT0_DIR_PIN ORIG_E1_DIR_PIN
#define EXT0_INVERSE 0
#define EXT0_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define EXT0_ENABLE_ON 1
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 320
#define EXT1_TEMPSENSOR_TYPE 1
#define EXT1_STEP_PIN ORIG_E2_STEP_PIN
#define EXT1_DIR_PIN ORIG_E2_DIR_PIN
#define EXT1_INVERSE 0
#define EXT1_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define EXT1_ENABLE_ON 1
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 3
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_REHOME 2
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 10
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 1
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
// ## Laser configuration ##
The default laser driver only supports laser on and off. Here you control the e??ntensity with
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 10
#define ENDSTOP_Y_BACK_ON_HOME 5
#define ENDSTOP_Z_BACK_ON_HOME 2
#define X_ENABLE_ON 1
#define Y_ENABLE_ON 1
#define Z_ENABLE_ON 1
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 1
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 210
#define Y_MAX_LENGTH 210
#define Z_MAX_LENGTH 230
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_PERMANENT 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 20
#define HOMING_FEEDRATE_X 100
#define HOMING_FEEDRATE_Y 100
#define HOMING_FEEDRATE_Z 5
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 2
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 2
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
<div>#define BED_MOTOR_2_X 200</div><div>#define BED_MOTOR_2_Y 0</div><div>#define BED_MOTOR_3_X 100</div><div>#define BED_MOTOR_3_Y 200</div><div>#define BENDING_CORRECTION_A 0</div><div>#define BENDING_CORRECTION_B 0</div><div>#define BENDING_CORRECTION_C 0</div><div>#define FEATURE_AXISCOMP 0</div><div>#define AXISCOMP_TANXY 0</div><div>#define AXISCOMP_TANYZ 0</div><div>#define AXISCOMP_TANXZ 0</div><div>
</div><div>#ifndef SDSUPPORT // Some boards have sd support on board. These define the values already in pins.h</div><div>#define SDSUPPORT 1</div><div>#undef SDCARDDETECT</div><div>#define SDCARDDETECT -1</div><div>#define SDCARDDETECTINVERTED 0</div><div>#endif</div><div>#define SD_EXTENDED_DIR 1 /** Show extended directory including file length. Don't use this with Pronterface! /</div><div>#define SD_RUN_ON_STOP ""</div><div>#define SD_STOP_HEATER_AND_MOTORS_ON_STOP 1</div><div>#define ARC_SUPPORT 1</div><div>#define FEATURE_MEMORY_POSITION 1</div><div>#define FEATURE_CHECKSUM_FORCED 0</div><div>#define FEATURE_FAN_CONTROL 1</div><div>#define FEATURE_FAN2_CONTROL 1</div><div>#define FEATURE_CONTROLLER 7</div><div>#define ADC_KEYPAD_PIN -1</div><div>#define LANGUAGE_EN_ACTIVE 1</div><div>#define LANGUAGE_DE_ACTIVE 0</div><div>#define LANGUAGE_NL_ACTIVE 0</div><div>#define LANGUAGE_PT_ACTIVE 0</div><div>#define LANGUAGE_IT_ACTIVE 0</div><div>#define LANGUAGE_ES_ACTIVE 0</div><div>#define LANGUAGE_FI_ACTIVE 0</div><div>#define LANGUAGE_SE_ACTIVE 0</div><div>#define LANGUAGE_FR_ACTIVE 0</div><div>#define LANGUAGE_CZ_ACTIVE 0</div><div>#define LANGUAGE_PL_ACTIVE 1</div><div>#define LANGUAGE_TR_ACTIVE 0</div><div>#define UI_PRINTER_NAME "Dave MKIII"</div><div>#define UI_PRINTER_COMPANY "Urban Observatory"</div><div>#define UI_PAGES_DURATION 4000</div><div>#define UI_ANIMATION 1</div><div>#define UI_SPEEDDEPENDENT_POSITIONING 0</div><div>#define UI_DISABLE_AUTO_PAGESWITCH 0</div><div>#define UI_AUTORETURN_TO_MENU_AFTER 5000</div><div>#define FEATURE_UI_KEYS 0</div><div>#define UI_ENCODER_SPEED 1</div><div>#define UI_REVERSE_ENCODER 0</div><div>#define UI_KEY_BOUNCETIME 10</div><div>#define UI_KEY_FIRST_REPEAT 500</div><div>#define UI_KEY_REDUCE_REPEAT 50</div><div>#define UI_KEY_MIN_REPEAT 50</div><div>#define FEATURE_BEEPER 1</div><div>#define CASE_LIGHTS_PIN -1</div><div>#define CASE_LIGHT_DEFAULT_ON 1</div><div>#define UI_START_SCREEN_DELAY 4000</div><div>#define UI_DYNAMIC_ENCODER_SPEED 1</div><div> /**</div><div>Beeper sound definitions for short beeps during key actions</div><div>and longer beeps for important actions.</div><div>Parameter is delay in microseconds and the secons is the number of repetitions.</div><div>Values must be in range 1..255</div><div>/</div><div>#define BEEPER_SHORT_SEQUENCE 2,2</div><div>#define BEEPER_LONG_SEQUENCE 8,8</div><div>#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 60</div><div>#define UI_SET_PRESET_EXTRUDER_TEMP_PLA 200</div><div>#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 110</div><div>#define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240</div><div>#define UI_SET_MIN_HEATED_BED_TEMP 30</div><div>#define UI_SET_MAX_HEATED_BED_TEMP 120</div><div>#define UI_SET_MIN_EXTRUDER_TEMP 170</div><div>#define UI_SET_MAX_EXTRUDER_TEMP 260</div><div>#define UI_SET_EXTRUDER_FEEDRATE 2</div><div>#define UI_SET_EXTRUDER_RETRACT_DISTANCE 3</div><div>
</div><div>
</div><div>#define NUM_MOTOR_DRIVERS 0</div><div>
</div><div>
</div><div>
</div><div>/* Below you will find the configuration string, that created this Configuration.h</div><div>
</div><div>========== Start configuration string ==========</div><div>{</div><div> "editMode": 2,</div><div> "processor": 1,</div><div> "baudrate": 115200,</div><div> "bluetoothSerial": -1,</div><div> "bluetoothBaudrate": 115200,</div><div> "xStepsPerMM": 1280,</div><div> "yStepsPerMM": 1280,</div><div> "zStepsPerMM": 6400,</div><div> "xInvert": 0,</div><div> "xInvertEnable": "1",</div><div> "eepromMode": 2,</div><div> "yInvert": 0,</div><div> "yInvertEnable": "1",</div><div> "zInvert": "1",</div><div> "zInvertEnable": "1",</div><div> "extruder": [</div><div> {</div><div> "id": 0,</div><div> "heatManager": 3,</div><div> "pidDriveMin": 40,</div><div> "pidDriveMax": 230,</div><div> "pidMax": 255,</div><div> "sensorType": 1,</div><div> "sensorPin": "TEMP_0_PIN",</div><div> "heaterPin": "HEATER_0_PIN",</div><div> "maxFeedrate": 50,</div><div> "startFeedrate": 20,</div><div> "invert": "0",</div><div> "invertEnable": "1",</div><div> "acceleration": 5000,</div><div> "watchPeriod": 1,</div><div> "pidP": 7,</div><div> "pidI": 2,</div><div> "pidD": 40,</div><div> "advanceK": 0,</div><div> "advanceL": 0,</div><div> "waitRetractTemp": 150,</div><div> "waitRetractUnits": 0,</div><div> "waitRetract": 0,</div><div> "stepsPerMM": 320,</div><div> "coolerPin": -1,</div><div> "coolerSpeed": 255,</div><div> "selectCommands": "",</div><div> "deselectCommands": "",</div><div> "xOffset": -9,</div><div> "yOffset": 0,</div><div> "zOffset": 0,</div><div> "xOffsetSteps": -11520,</div><div> "yOffsetSteps": 0,</div><div> "zOffsetSteps": 0,</div><div> "stepper": {</div><div> "name": "Extruder 1",</div><div> "step": "ORIG_E1_STEP_PIN",</div><div> "dir": "ORIG_E1_DIR_PIN",</div><div> "enable": "ORIG_E1_ENABLE_PIN"</div><div> },</div><div> "advanceBacklashSteps": 0,</div><div> "decoupleTestPeriod": 12,</div><div> "jamPin": -1,</div><div> "jamPullup": "0",</div><div> "mirror": "0",</div><div> "invert2": "0",</div><div> "stepper2": {</div><div> "name": "Extruder 0",</div><div> "step": "ORIG_E0_STEP_PIN",</div><div> "dir": "ORIG_E0_DIR_PIN",</div><div> "enable": "ORIG_E0_ENABLE_PIN"</div><div> }</div><div> },</div><div> {</div><div> "id": 1,</div><div> "heatManager": 3,</div><div> "pidDriveMin": 40,</div><div> "pidDriveMax": 230,</div><div> "pidMax": 255,</div><div> "sensorType": 1,</div><div> "sensorPin": "TEMP_2_PIN",</div><div> "heaterPin": "HEATER_2_PIN",</div><div> "maxFeedrate": 50,</div><div> "startFeedrate": 20,</div><div> "invert": "0",</div><div> "invertEnable": "1",</div><div> "acceleration": 5000,</div><div> "watchPeriod": 1,</div><div> "pidP": 7,</div><div> "pidI": 2,</div><div> "pidD": 40,</div><div> "advanceK": 0,</div><div> "advanceL": 0,</div><div> "waitRetractTemp": 150,</div><div> "waitRetractUnits": 0,</div><div> "waitRetract": 0,</div><div> "stepsPerMM": 320,</div><div> "coolerPin": -1,</div><div> "coolerSpeed": 255,</div><div> "selectCommands": "",</div><div> "deselectCommands": "",</div><div> "xOffset": 0,</div><div> "yOffset": 0,</div><div> "zOffset": 0,</div><div> "xOffsetSteps": 0,</div><div> "yOffsetSteps": 0,</div><div> "zOffsetSteps": 0,</div><div> "stepper": {</div><div> "name": "Extruder 2",</div><div> "step": "ORIG_E2_STEP_PIN",</div><div> "dir": "ORIG_E2_DIR_PIN",</div><div> "enable": "ORIG_E2_ENABLE_PIN"</div><div> },</div><div> "advanceBacklashSteps": 0,</div><div> "decoupleTestPeriod": 12,</div><div> "jamPin": -1,</div><div> "jamPullup": "0",</div><div> "mirror": "0",</div><div> "invert2": "0",</div><div> "stepper2": {</div><div> "name": "Extruder 1",</div><div> "step": "ORIG_E1_STEP_PIN",</div><div> "dir": "ORIG_E1_DIR_PIN",</div><div> "enable": "ORIG_E1_ENABLE_PIN"</div><div> }</div><div> }</div><div> ],</div><div> "uiLanguage": 0,</div><div> "uiController": 0,</div><div> "xMinEndstop": 1,</div><div> "yMinEndstop": 1,</div><div> "zMinEndstop": 1,</div><div> "xMaxEndstop": 0,</div><div> "yMaxEndstop": 0,</div><div> "zMaxEndstop": 0,</div><div> "motherboard": 402,</div><div> "driveSystem": 0,</div><div> "xMaxSpeed": 200,</div><div> "xHomingSpeed": 100,</div><div> "xTravelAcceleration": 1000,</div><div> "xPrintAcceleration": 1000,</div><div> "yMaxSpeed": 200,</div><div> "yHomingSpeed": 100,</div><div> "yTravelAcceleration": 1000,</div><div> "yPrintAcceleration": 1000,</div><div> "zMaxSpeed": 20,</div><div> "zHomingSpeed": 5,</div><div> "zTravelAcceleration": 100,</div><div> "zPrintAcceleration": 100,</div><div> "xMotor": {</div><div> "name": "X motor",</div><div> "step": "ORIG_X_STEP_PIN",</div><div> "dir": "ORIG_X_DIR_PIN",</div><div> "enable": "ORIG_X_ENABLE_PIN"</div><div> },</div><div> "yMotor": {</div><div> "name": "Y motor",</div><div> "step": "ORIG_Y_STEP_PIN",</div><div> "dir": "ORIG_Y_DIR_PIN",</div><div> "enable": "ORIG_Y_ENABLE_PIN"</div><div> },</div><div> "zMotor": {</div><div> "name": "Z motor",</div><div> "step": "ORIG_Z_STEP_PIN",</div><div> "dir": "ORIG_Z_DIR_PIN",</div><div> "enable": "ORIG_Z_ENABLE_PIN"</div><div> },</div><div> "enableBacklash": "0",</div><div> "backlashX": 0,</div><div> "backlashY": 0,</div><div> "backlashZ": 0,</div><div> "stepperInactiveTime": 360,</div><div> "maxInactiveTime": 0,</div><div> "xMinPos": 0,</div><div> "yMinPos": 0,</div><div> "zMinPos": 0,</div><div> "xLength": 210,</div><div> "yLength": 210,</div><div> "zLength": 230,</div><div> "alwaysCheckEndstops": "1",</div><div> "disableX": "0",</div><div> "disableY": "0",</div><div> "disableZ": "0",</div><div> "disableE": "1",</div><div> "xHomeDir": "-1",</div><div> "yHomeDir": "-1",</div><div> "zHomeDir": "-1",</div><div> "xEndstopBack": 10,</div><div> "yEndstopBack": 5,</div><div> "zEndstopBack": 2,</div><div> "deltaSegmentsPerSecondPrint": 180,</div><div> "deltaSegmentsPerSecondTravel": 70,</div><div> "deltaDiagonalRod": 445,</div><div> "deltaHorizontalRadius": 209.25,</div><div> "deltaAlphaA": 210,</div><div> "deltaAlphaB": 330,</div><div> "deltaAlphaC": 90,</div><div> "deltaDiagonalCorrA": 0,</div><div> "deltaDiagonalCorrB": 0,</div><div> "deltaDiagonalCorrC": 0,</div><div> "deltaMaxRadius": 150,</div><div> "deltaFloorSafetyMarginMM": 15,</div><div> "deltaRadiusCorrA": 0,</div><div> "deltaRadiusCorrB": 0,</div><div> "deltaRadiusCorrC": 0,</div><div> "deltaXOffsetSteps": 0,</div><div> "deltaYOffsetSteps": 0,</div><div> "deltaZOffsetSteps": 0,</div><div> "deltaSegmentsPerLine": 24,</div><div> "stepperHighDelay": 2,</div><div> "directionDelay": 0,</div><div> "stepDoublerFrequency": 80000,</div><div> "allowQuadstepping": "1",</div><div> "doubleStepDelay": 0,</div><div> "maxJerk": 20,</div><div> "maxZJerk": 0.3,</div><div> "moveCacheSize": 16,</div><div> "moveCacheLow": 10,</div><div> "lowTicksPerMove": 250000,</div><div> "enablePowerOnStartup": "1",</div><div> "echoOnExecute": "1",</div><div> "sendWaits": "1",</div><div> "ackWithLineNumber": "1",</div><div> "killMethod": 1,</div><div> "useAdvance": "0",</div><div> "useQuadraticAdvance": "0",</div><div> "powerInverting": 0,</div><div> "mirrorX": 0,</div><div> "mirrorXMotor": {</div><div> "name": "Extruder 1",</div><div> "step": "ORIG_E1_STEP_PIN",</div><div> "dir": "ORIG_E1_DIR_PIN",</div><div> "enable": "ORIG_E1_ENABLE_PIN"</div><div> },</div><div> "mirrorY": 0,</div><div> "mirrorYMotor": {</div><div> "name": "Extruder 1",</div><div> "step": "ORIG_E1_STEP_PIN",</div><div> "dir": "ORIG_E1_DIR_PIN",</div><div> "enable": "ORIG_E1_ENABLE_PIN"</div><div> },</div><div> "mirrorZ": "0",</div><div> "mirrorZMotor": {</div><div> "name": "Extruder 1",</div><div> "step": "ORIG_E1_STEP_PIN",</div><div> "dir": "ORIG_E1_DIR_PIN",</div><div> "enable": "ORIG_E1_ENABLE_PIN"</div><div> },</div><div> "mirrorZ3": "0",</div><div> "mirrorZ3Motor": {</div><div> "name": "Extruder 2",</div><div> "step": "ORIG_E2_STEP_PIN",</div><div> "dir": "ORIG_E2_DIR_PIN",</div><div> "enable": "ORIG_E2_ENABLE_PIN"</div><div> },</div><div> "dittoPrinting": "0",</div><div> "featureServos": "0",</div><div> "servo0Pin": 11,</div><div> "servo1Pin": -1,</div><div> "servo2Pin": -1,</div><div> "servo3Pin": -1,</div><div> "featureWatchdog": "1",</div><div> "hasHeatedBed": "1",</div><div> "enableZProbing": "0",</div><div> "extrudeMaxLength": 160,</div><div> "homeOrder": "HOME_ORDER_XYZ",</div><div> "featureController": 7,</div><div> "uiPrinterName": "Dave MKIII",</div><div> "uiPrinterCompany": "Urban Observatory",</div><div> "uiPagesDuration": 4000,</div><div> "uiAnimation": "1",</div><div> "uiDisablePageswitch": "0",</div><div> "uiAutoReturnAfter": 5000,</div><div> "featureKeys": "0",</div><div> "uiEncoderSpeed": 1,</div><div> "uiReverseEncoder": "0",</div><div> "uiKeyBouncetime": 10,</div><div> "uiKeyFirstRepeat": 500,</div><div> "uiKeyReduceRepeat": 50,</div><div> "uiKeyMinRepeat": 50,</div><div> "featureBeeper": "1",</div><div> "uiPresetBedTempPLA": 60,</div><div> "uiPresetBedABS": 110,</div><div> "uiPresetExtruderPLA": 200,</div><div> "uiPresetExtruderABS": 240,</div><div> "uiMinHeatedBed": 30,</div><div> "uiMaxHeatedBed": 120,</div><div> "uiMinEtxruderTemp": 170,</div><div> "uiMaxExtruderTemp": 260,</div><div> "uiExtruderFeedrate": 2,</div><div> "uiExtruderRetractDistance": 3,</div><div> "uiSpeeddependentPositioning": "0",</div><div> "maxBedTemperature": 120,</div><div> "bedSensorType": 1,</div><div> "bedSensorPin": "TEMP_1_PIN",</div><div> "bedHeaterPin": "HEATER_1_PIN",</div><div> "bedHeatManager": 0,</div><div> "bedUpdateInterval": 5000,</div><div> "bedPidDriveMin": 80,</div><div> "bedPidDriveMax": 255,</div><div> "bedPidP": 196,</div><div> "bedPidI": 33,</div><div> "bedPidD": 290,</div><div> "bedPidMax": 255,</div><div> "bedDecoupleTestPeriod": 300,</div><div> "caseLightPin": -1,</div><div> "caseLightDefaultOn": "1",</div><div> "bedSkipIfWithin": 3,</div><div> "gen1T0": 25,</div><div> "gen1R0": 100000,</div><div> "gen1Beta": 4036,</div><div> "gen1MinTemp": -20,</div><div> "gen1MaxTemp": 300,</div><div> "gen1R1": 0,</div><div> "gen1R2": 4700,</div><div> "gen2T0": 25,</div><div> "gen2R0": 100000,</div><div> "gen2Beta": 4036,</div><div> "gen2MinTemp": -20,</div><div> "gen2MaxTemp": 300,</div><div> "gen2R1": 0,</div><div> "gen2R2": 4700,</div><div> "gen3T0": 25,</div><div> "gen3R0": 100000,</div><div> "gen3Beta": 4036,</div><div> "gen3MinTemp": -20,</div><div> "gen3MaxTemp": 300,</div><div> "gen3R1": 0,</div><div> "gen3R2": 4700,</div><div> "userTable0": {</div><div> "r1": 0,</div><div> "r2": 4700,</div><div> "temps": [],</div><div> "numEntries": 0</div><div> },</div><div> "userTable1": {</div><div> "r1": 0,</div><div> "r2": 4700,</div><div> "temps": [],</div><div> "numEntries": 0</div><div> },</div><div> "userTable2": {</div><div> "r1": 0,</div><div> "r2": 4700,</div><div> "temps": [],</div><div> "numEntries": 0</div><div> },</div><div> "tempHysteresis": 0,</div><div> "pidControlRange": 10,</div><div> "skipM109Within": 2,</div><div> "extruderFanCoolTemp": 50,</div><div> "minTemp": 150,</div><div> "maxTemp": 275,</div><div> "minDefectTemp": -10,</div><div> "maxDefectTemp": 290,</div><div> "arcSupport": "1",</div><div> "featureMemoryPositionWatchdog": "1",</div><div> "forceChecksum": "0",</div><div> "sdExtendedDir": "1",</div><div> "featureFanControl": "1",</div><div> "fanPin": "ORIG_FAN_PIN",</div><div> "featureFan2Control": "1",</div><div> "fan2Pin": "ORIG_FAN2_PIN",</div><div> "fanThermoPin": -1,</div><div> "fanThermoMinPWM": 128,</div><div> "fanThermoMaxPWM": 255,</div><div> "fanThermoMinTemp": 45,</div><div> "fanThermoMaxTemp": 60,</div><div> "fanThermoThermistorPin": -1,</div><div> "fanThermoThermistorType": 1,</div><div> "scalePidToMax": "1",</div><div> "zProbePin": -1,</div><div> "zProbeBedDistance": 10,</div><div> "zProbePullup": "0",</div><div> "zProbeOnHigh": "0",</div><div> "zProbeXOffset": 0,</div><div> "zProbeYOffset": 0,</div><div> "zProbeWaitBeforeTest": "0",</div><div> "zProbeSpeed": 2,</div><div> "zProbeXYSpeed": 150,</div><div> "zProbeHeight": 40,</div><div> "zProbeStartScript": "",</div><div> "zProbeFinishedScript": "",</div><div> "featureAutolevel": "1",</div><div> "zProbeX1": 20,</div><div> "zProbeY1": 20,</div><div> "zProbeX2": 160,</div><div> "zProbeY2": 20,</div><div> "zProbeX3": 100,</div><div> "zProbeY3": 160,</div><div> "zProbeSwitchingDistance": 1,</div><div> "zProbeRepetitions": 1,</div><div> "sdSupport": "1",</div><div> "sdCardDetectPin": -1,</div><div> "sdCardDetectInverted": "0",</div><div> "uiStartScreenDelay": 4000,</div><div> "xEndstopBackMove": 5,</div><div> "yEndstopBackMove": 5,</div><div> "zEndstopBackMove": 2,</div><div> "xEndstopRetestFactor": 3,</div><div> "yEndstopRetestFactor": 3,</div><div> "zEndstopRetestFactor": 3,</div><div> "xMinPin": "ORIG_X_MIN_PIN",</div><div> "yMinPin": "ORIG_Y_MIN_PIN",</div><div> "zMinPin": "ORIG_Z_MIN_PIN",</div><div> "xMaxPin": "ORIG_X_MAX_PIN",</div><div> "yMaxPin": "ORIG_Y_MAX_PIN",</div><div> "zMaxPin": "ORIG_Z_MAX_PIN",</div><div> "deltaHomeOnPower": "0",</div><div> "fanBoardPin": -1,</div><div> "heaterPWMSpeed": 0,</div><div> "featureBabystepping": "1",</div><div> "babystepMultiplicator": 1,</div><div> "pdmForHeater": "0",</div><div> "pdmForCooler": "0",</div><div> "psOn": "ORIG_PS_ON_PIN",</div><div> "mixingExtruder": "0",</div><div> "decouplingTestMaxHoldVariance": 20,</div><div> "decouplingTestMinTempRise": 1,</div><div> "featureAxisComp": "0",</div><div> "axisCompTanXY": 0,</div><div> "axisCompTanXZ": 0,</div><div> "axisCompTanYZ": 0,</div><div> "retractOnPause": 2,</div><div> "pauseStartCommands": "",</div><div> "pauseEndCommands": "",</div><div> "distortionCorrection": "0",</div><div> "distortionCorrectionPoints": 5,</div><div> "distortionCorrectionR": 100,</div><div> "distortionPermanent": "0",</div><div> "distortionUpdateFrequency": 15,</div><div> "distortionStartDegrade": 0.5,</div><div> "distortionEndDegrade": 1,</div><div> "distortionExtrapolateCorners": "0",</div><div> "distortionXMin": 10,</div><div> "distortionXMax": 190,</div><div> "distortionYMin": 10,</div><div> "distortionYMax": 190,</div><div> "sdRunOnStop": "",</div><div> "sdStopHeaterMotorsOnStop": "1",</div><div> "featureRetraction": "1",</div><div> "autoretractEnabled": "0",</div><div> "retractionLength": 3,</div><div> "retractionLongLength": 13,</div><div> "retractionSpeed": 40,</div><div> "retractionZLift": 0,</div><div> "retractionUndoExtraLength": 0,</div><div> "retractionUndoExtraLongLength": 0,</div><div> "retractionUndoSpeed": 20,</div><div> "filamentChangeXPos": 0,</div><div> "filamentChangeYPos": 0,</div><div> "filamentChangeZAdd": 2,</div><div> "filamentChangeRehome": 2,</div><div> "filamentChangeShortRetract": 5,</div><div> "filamentChangeLongRetract": 50,</div><div> "fanKickstart": 200,</div><div> "servo0StartPos": -1,</div><div> "servo1StartPos": -1,</div><div> "servo2StartPos": -1,</div><div> "servo3StartPos": -1,</div><div> "uiDynamicEncoderSpeed": "1",</div><div> "uiServoControl": 0,</div><div> "killIfSensorDefect": "1",</div><div> "jamSteps": 220,</div><div> "jamSlowdownSteps": 320,</div><div> "jamSlowdownTo": 70,</div><div> "jamErrorSteps": 500,</div><div> "jamMinSteps": 10,</div><div> "jamAction": 1,</div><div> "primaryPort": 1,</div><div> "numMotorDrivers": 0,</div><div> "motorDrivers": [</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1</div><div> },</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1</div><div> },</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1</div><div> },</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1</div><div> },</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1</div><div> },</div><div> {</div><div> "t": "None",</div><div> "s": "",</div><div> "invertEnable": "0",</div><div> "invertDirection": "0",</div><div> "stepsPerMM": 100,</div><div> "speed": 10,</div><div> "dirPin": -1,</div><div> "stepPin": -1,</div><div> "enablePin": -1</div><div> }</div><div> ],</div><div> "manualConfig": "",</div><div> "zHomeMinTemperature": 0,</div><div> "zHomeXPos": 999999,</div><div> "zHomeYPos": 999999,</div><div> "zHomeHeatHeight": 20,</div><div> "zHomeHeatAll": "1",</div><div> "zProbeZOffsetMode": 0,</div><div> "zProbeZOffset": 0,</div><div> "uiBedCoating": "0",</div><div> "langEN": "1",</div><div> "langDE": "0",</div><div> "langNL": "0",</div><div> "langPT": "0",</div><div> "langIT": "0",</div><div> "langES": "0",</div><div> "langFI": "0",</div><div> "langSE": "0",</div><div> "langFR": "0",</div><div> "langCZ": "0",</div><div> "langPL": "1",</div><div> "langTR": "0",</div><div> "interpolateAccelerationWithZ": 0,</div><div> "accelerationFactorTop": 100,</div><div> "bendingCorrectionA": 0,</div><div> "bendingCorrectionB": 0,</div><div> "bendingCorrectionC": 0,</div><div> "preventZDisableOnStepperTimeout": "0",</div><div> "supportLaser": "0",</div><div> "laserPin": -1,</div><div> "laserOnHigh": "1",</div><div> "defaultPrinterMode": 0,</div><div> "supportCNC": "0",</div><div> "cncWaitOnEnable": 300,</div><div> "cncWaitOnDisable": 0,</div><div> "cncEnablePin": -1,</div><div> "cncEnableWith": "1",</div><div> "cncDirectionPin": -1,</div><div> "cncDirectionCW": "1",</div><div> "startupGCode": "",</div><div> "jsonOutput": "0",</div><div> "bedLevelingMethod": 0,</div><div> "bedCorrectionMethod": 0,</div><div> "bedLevelingGridSize": 5,</div><div> "bedLevelingRepetitions": 5,</div><div> "bedMotor1X": 0,</div><div> "bedMotor1Y": 0,</div><div> "bedMotor2X": 200,</div><div> "bedMotor2Y": 0,</div><div> "bedMotor3X": 100,</div><div> "bedMotor3Y": 200,</div><div> "zProbeRequiresHeating": "0",</div><div> "zProbeMinTemperature": 150,</div><div> "adcKeypadPin": -1,</div><div> "sharedExtruderHeater": "0",</div><div> "extruderSwitchXYSpeed": 100,</div><div> "dualXAxis": "0",</div><div> "boardFanSpeed": 255,</div><div> "hasMAX6675": false,</div><div> "hasMAX31855": false,</div><div> "hasGeneric1": false,</div><div> "hasGeneric2": false,</div><div> "hasGeneric3": false,</div><div> "hasUser0": false,</div><div> "hasUser1": false,</div><div> "hasUser2": false,</div><div> "numExtruder": 2,</div><div> "version": 92.9,</div><div> "primaryPortName": "Serial"</div><div>}</div><div>========== End configuration string ==========</div><div>
</div><div>*/</div>
