Hi !I have a problem with Repetier Host. I'm on Windows 10. I have not found a solution to my problem on google.When I'm trying to connect my Scara Arm 3D Printer, this error pops up:
Details of error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.************** Exception Text ***********
System.ArgumentOutOfRangeException: The maximum baud rate for the device is 21105.
Parameter name: baudRate
at System.IO.Ports.SerialStream..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits, Int32 readTimeout, Int32 writeTimeout, Handshake handshake, Boolean dtrEnable, Boolean rtsEnable, Boolean discardNull, Byte parityReplace)
at System.IO.Ports.SerialPort.Open()
at RepetierHost.model.ProtectedSerialPort.Open()
at RepetierHost.connector.SerialConnector.Connect(Boolean failSilent)
at RepetierHost.model.PrinterConnection.open()
at RepetierHost.Main.toolConnect_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripSplitButton.OnButtonClick(EventArgs e)
at System.Windows.Forms.ToolStripSplitButton.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2115.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dllRepetierHost
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Repetier-Host/RepetierHost.exeSystem.Windows.Forms
Win32 Version: 4.7.2110.0 built by: NET47REL1LAST
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0b77a5c561934e089/System.Windows.Forms.dllSystem
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dllSystem.Drawing
Win32 Version: 4.7.2046.0 built by: NET47REL1
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0b03f5f7f11d50a3a/System.Drawing.dllRepetierHostExtender
CodeBase: file:///C:/Program%20Files/Repetier-Host/RepetierHostExtender.DLLSystem.Configuration
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dllSystem.Core
Win32 Version: 4.7.2117.0 built by: NET47REL1LAST
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0b77a5c561934e089/System.Core.dllSystem.Xml
Win32 Version: 4.7.2612.0 built by: NET471REL1LAST_B
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dllOpenTK
Assembly Version: 1.2.0.0
Win32 Version: 1.2.2336.6514-pre
CodeBase: file:///C:/Program%20Files/Repetier-Host/OpenTK.DLLAccessibility
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0b03f5f7f11d50a3a/Accessibility.dllColorSlider
CodeBase: file:///C:/Program%20Files/Repetier-Host/ColorSlider.DLLCuraEngine
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/CuraEngine/CuraEngine.dllRepetierServerConnector
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/RepetierServerConnector/RepetierServerConnector.dllRRFirmwares
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/RRFirmwares/RRFirmwares.dllSlicerSlic3r
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/SlicerSlic3r/SlicerSlic3r.dllSlicerSlic3rPE
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/SlicerSlic3rPE/SlicerSlic3rPE.dllSystem.ServiceProcess
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dllNewtonsoft.Json
Assembly Version: 6.0.0.0
Win32 Version: 6.0.8.18111
CodeBase: file:///C:/Program%20Files/Repetier-Host/Newtonsoft.Json.DLLOpenTK.GLControl
CodeBase: file:///C:/Program%20Files/Repetier-Host/OpenTK.GLControl.DLL
I have not this problem with another laptop on Windows 7.Best Regards.
