<font face="Arial, Verdana">I'm pretty new to 3D printing and after about a month and a half my hot end broke. I ended up buying a new E3D after some research but I'm having trouble with the firmware. I have cautiously printed a few small things to test it without updating yet because i can't figure it out. On the E3D website it tells me to </font>
<p style="font-family: sans-serif; font-size: 14px; line-height: 22.3999996185303px; margin: 0.5em 0px; color: rgb(37, 37, 37); background-color: rgb(255, 255, 255);">
<p style="font-family: sans-serif; font-size: 14px; line-height: 22.3999996185303px; margin: 0.5em 0px; color: rgb(37, 37, 37); background-color: rgb(255, 255, 255);">Use thermistor definition number 8:
<font color="#252525" face="sans-serif">
</font>
<font color="#252525" face="sans-serif">The problem is I'm not sure where to go to change this. I asked a couple of my friends that also use Repetier and they too, were not entirely sure what to do to change this. It also says </font>
<p style="margin: 0.5em 0px; line-height: 22.3999996185303px; color: rgb(37, 37, 37); font-family: sans-serif; font-size: 14px; background-color: rgb(255, 255, 255);">
<p style="margin: 0.5em 0px; line-height: 22.3999996185303px; color: rgb(37, 37, 37); font-family: sans-serif; font-size: 14px; background-color: rgb(255, 255, 255);">For safety it is strongly recommended to do the following:
Limit the Max PWM value (EXT0_PID_MAX xxx in the config file) to ensure that current is limited to a safe value.
Set the Minimum defect temperature to ensure that the thermistor shorting out is caught by the firmware.
</font>
<font color="#252525" face="sans-serif">I figured while I'm asking about the tables i will bring up a related question as well. Where do i change these settings also. These are probably dumb and easy questions but I didn't want to start changing settings in the configuration table unless i knew exactly what they did. Thanks. </font>
</font>
